[Darshan-commits] [Darshan] branch, dev-modular,	updated. darshan-2.3.1-176-g86d1744
    Service Account
    git at mcs.anl.gov
    Thu Sep 10 18:58:50 CDT 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
       via  86d174406f55abe938044a28eca0ce5c52b33e04 (commit)
      from  ae15d896720a92d229119944890da28a9f4a2038 (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit 86d174406f55abe938044a28eca0ce5c52b33e04
Author: Shane Snyder <ssnyder at mcs.anl.gov>
Date:   Thu Sep 10 18:58:10 2015 -0500
    cleanup code in utility component
Summary of changes:
 darshan-util/Makefile.in                           |    4 +-
 darshan-util/configure                             |   14 +-
 darshan-util/configure.in                          |   10 +-
 darshan-util/darshan-bgq-parser.c                  |  217 --------------------
 .../bin/darshan-job-summary.pl.in                  |    4 +-
 darshan-util/darshan-logutils.c                    |    2 +-
 darshan-util/maint/darshan-util.pc.in              |    8 +-
 7 files changed, 21 insertions(+), 238 deletions(-)
 delete mode 100644 darshan-util/darshan-bgq-parser.c
Diff of changes:
diff --git a/darshan-util/Makefile.in b/darshan-util/Makefile.in
index aad652e..6dbe9b3 100644
--- a/darshan-util/Makefile.in
+++ b/darshan-util/Makefile.in
@@ -23,8 +23,8 @@ VPATH = $(srcdir)
 ifeq ($(DARSHAN_ENABLE_SHARED),1)
 all: libdarshan-util.so
 endif
-cp_zlib_link_flags = @__CP_ZLIB_LINK_FLAGS@
-cp_zlib_include_flags = @__CP_ZLIB_INCLUDE_FLAGS@
+cp_zlib_link_flags = @__DARSHAN_ZLIB_LINK_FLAGS@
+cp_zlib_include_flags = @__DARSHAN_ZLIB_INCLUDE_FLAGS@
 # deliberately avoid large file support for host side utilities to avoid
 # potentially buggy libz 64 bit offset support
diff --git a/darshan-util/configure b/darshan-util/configure
index 16d470e..b96c730 100755
--- a/darshan-util/configure
+++ b/darshan-util/configure
@@ -623,9 +623,9 @@ ac_subst_vars='LTLIBOBJS
 LIBOBJS
 DARSHAN_UTIL_VERSION
-__CP_PDFLATEX_HALT_ON_ERROR
-__CP_ZLIB_INCLUDE_FLAGS
-__CP_ZLIB_LINK_FLAGS
+__DARSHAN_PDFLATEX_HALT_ON_ERROR
+__DARSHAN_ZLIB_INCLUDE_FLAGS
+__DARSHAN_ZLIB_LINK_FLAGS
 HAVE_PDFLATEX
 PRI_MACROS_BROKEN
 LIBBZ2
@@ -3431,8 +3431,8 @@ if test "${with_zlib+set}" = set; then :
     ZLIB_HOME="$withval"
     LDFLAGS="$LDFLAGS -L${ZLIB_HOME}/lib"
     CPPFLAGS="$CPPFLAGS -I${ZLIB_HOME}/include"
-    __CP_ZLIB_LINK_FLAGS="-L${ZLIB_HOME}/lib"
-    __CP_ZLIB_INCLUDE_FLAGS="-I${ZLIB_HOME}/include"
+    __DARSHAN_ZLIB_LINK_FLAGS="-L${ZLIB_HOME}/lib"
+    __DARSHAN_ZLIB_INCLUDE_FLAGS="-I${ZLIB_HOME}/include"
   else
     { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: Sorry, $withval does not exist, checking usual places" >&5
 $as_echo "$as_me: WARNING: Sorry, $withval does not exist, checking usual places" >&2;}
@@ -3805,9 +3805,9 @@ $as_echo_n "checking for -halt-on-error argument to pdflatex... " >&6; }
     if test "x$PDFLATEX_GREP" != "x"; then
         { $as_echo "$as_me:${as_lineno-$LINENO}: result: yes" >&5
 $as_echo "yes" >&6; }
-        __CP_PDFLATEX_HALT_ON_ERROR="-halt-on-error"
+        __DARSHAN_PDFLATEX_HALT_ON_ERROR="-halt-on-error"
     else
-        __CP_PDFLATEX_HALT_ON_ERROR=""
+        __DARSHAN_PDFLATEX_HALT_ON_ERROR=""
         { $as_echo "$as_me:${as_lineno-$LINENO}: result: no" >&5
 $as_echo "no" >&6; }
     fi
diff --git a/darshan-util/configure.in b/darshan-util/configure.in
index 4fd750b..3b78097 100644
--- a/darshan-util/configure.in
+++ b/darshan-util/configure.in
@@ -30,9 +30,9 @@ if test x$HAVE_PDFLATEX == xyes; then
     PDFLATEX_GREP=`pdflatex --help |grep halt-on-error`
         AC_MSG_RESULT(yes)
     else
         AC_MSG_RESULT(no)
     fi
 fi
@@ -82,9 +82,9 @@ AC_CHECK_FUNCS([strndup])
 DARSHAN_UTIL_VERSION="AC_PACKAGE_VERSION"
-AC_SUBST(__CP_ZLIB_LINK_FLAGS)
-AC_SUBST(__CP_ZLIB_INCLUDE_FLAGS)
-AC_SUBST(__CP_PDFLATEX_HALT_ON_ERROR)
+AC_SUBST(__DARSHAN_ZLIB_LINK_FLAGS)
+AC_SUBST(__DARSHAN_ZLIB_INCLUDE_FLAGS)
+AC_SUBST(__DARSHAN_PDFLATEX_HALT_ON_ERROR)
 AC_SUBST(DARSHAN_ENABLE_SHARED)
 AC_SUBST(DARSHAN_UTIL_VERSION)
 AC_OUTPUT(Makefile
diff --git a/darshan-util/darshan-bgq-parser.c b/darshan-util/darshan-bgq-parser.c
deleted file mode 100644
index 03fdc27..0000000
--- a/darshan-util/darshan-bgq-parser.c
+++ /dev/null
@@ -1,217 +0,0 @@
- * Copyright (C) 2015 University of Chicago.
- * See COPYRIGHT notice in top-level directory.
-#include <stdio.h>
-#include <sys/types.h>
-#include <sys/stat.h>
-#include <fcntl.h>
-#include <unistd.h>
-#include <string.h>
-#include <zlib.h>
-#include <time.h>
-#include <stdlib.h>
-#include <getopt.h>
-#include <assert.h>
-#include "darshan-logutils.h"
-#include "darshan-bgq-logutils.h"
-#include "uthash-1.9.2/src/uthash.h"
-int main(int argc, char **argv)
-    int ret;
-    int i;
-    char *filename;
-    char tmp_string[4096];
-    darshan_fd fd;
-    struct darshan_header header;
-    struct darshan_job job;
-    struct darshan_record_ref *rec_hash = NULL;
-    struct darshan_record_ref *ref;
-    int mount_count;
-    char** mnt_pts;
-    char** fs_types;
-    time_t tmp_time = 0;
-    char *token;
-    char *save;
-    char buffer[DARSHAN_JOB_METADATA_LEN];
-    struct darshan_bgq_record next_file;
-    assert(argc == 2);
-    filename = argv[1];
-    struct stat sbuf;
-    stat(filename, &sbuf);
-    fd = darshan_log_open(filename, "r");
-    if(!fd)
-        fprintf(stderr, "darshan_log_open() failed to open %s\n.", filename);
-        return(-1);
-    /* read darshan log header */
-    ret = darshan_log_getheader(fd, &header);
-    if(ret < 0)
-        fprintf(stderr, "darshan_log_getheader() failed to read log header.\n");
-        darshan_log_close(fd);
-        return(-1);
-    /* read darshan job info */
-    ret = darshan_log_getjob(fd, &job);
-    if(ret < 0)
-        fprintf(stderr, "darshan_log_getjob() failed to read job data.\n");
-        return(-1);
-    /* get the original command line for this job */
-    ret = darshan_log_getexe(fd, tmp_string);
-    if(ret < 0)
-        fprintf(stderr, "Error: unable to read trailing job information.\n");
-        return(-1);
-    /* print job summary */
-    printf("# darshan log version: %s\n", header.version_string);
-    printf("# size of BGQ file statistics: %zu bytes\n", sizeof(struct darshan_bgq_record));
-    printf("# size of job statistics: %zu bytes\n", sizeof(struct darshan_job));
-    printf("# exe: %s\n", tmp_string);
-    printf("# uid: %" PRId64 "\n", job.uid);
-    printf("# jobid: %" PRId64 "\n", job.jobid);
-    printf("# start_time: %" PRId64 "\n", job.start_time);
-    tmp_time += job.start_time;
-    printf("# start_time_asci: %s", ctime(&tmp_time));
-    printf("# end_time: %" PRId64 "\n", job.end_time);
-    tmp_time = 0;
-    tmp_time += job.end_time;
-    printf("# end_time_asci: %s", ctime(&tmp_time));
-    printf("# nprocs: %" PRId64 "\n", job.nprocs);
-    printf("# run time: %" PRId64 "\n", job.end_time - job.start_time + 1);
-    for(token=strtok_r(job.metadata, "\n", &save);
-        token != NULL;
-        token=strtok_r(NULL, "\n", &save))
-        char *key;
-        char *value;
-        /* NOTE: we intentionally only split on the first = character.
-         * There may be additional = characters in the value portion
-         * (for example, when storing mpi-io hints).
-        strcpy(buffer, token);
-        key = buffer;
-        value = index(buffer, '=');
-        if(!value)
-            continue;
-        /* convert = to a null terminator to split key and value */
-        value[0] = '\0';
-        value++;
-        printf("# metadata: %s = %s\n", key, value);
-    /* get the mount information for this log */
-    ret = darshan_log_getmounts(fd, &mnt_pts, &fs_types, &mount_count);
-    if(ret < 0)
-        fprintf(stderr, "darshan_log_getmounts() failed to read mount information.\n");
-        return(-1);
-    /* print table of mounted file systems */
-    printf("\n# mounted file systems (mount point and fs type)\n");
-    printf("# -------------------------------------------------------\n");
-    for(i=0; i<mount_count; i++)
-        printf("# mount entry:\t%s\t%s\n", mnt_pts[i], fs_types[i]);
-    /* read hash of darshan records */
-    ret = darshan_log_gethash(fd, &rec_hash);
-    if(ret < 0)
-        fprintf(stderr, "darshan_log_getmap() failed to read record map.\n");
-        return(-1);
-    printf("\n*** FILE RECORD DATA ***\n");
-    ret = darshan_log_get_bgq_file(fd, &next_file);
-    if(ret < 0)
-        fprintf(stderr, "darshan_log_get_posix_file() failed to read next record.\n");
-        return(-1);
-    if(ret == 0)
-        printf("# no files opened.\n");
-        return(0);
-    /* loop over each stored POSIX file record and print counters */
-    i = 1;
-    do
-        /* get the pathname for this record */
-        HASH_FIND(hlink, rec_hash, &next_file.f_id, sizeof(darshan_record_id), ref);
-        assert(ref);
-        printf("\tRecord %d: id=%"PRIu64" (path=%s, rank=%"PRId64")\n",
-            i, next_file.f_id, ref->rec.name, next_file.rank);
-        printf(
-            "\t\tBGQ_CSJOBID:\t%"PRIu64"\n"
-            "\t\tBGQ_NNODES:\t%"PRIu64"\n"
-            "\t\tBGQ_RPN:\t%"PRIu64"\n"
-            "\t\tBGQ_DDRPERNODE:\t%"PRIu64"\n"
-            "\t\tBGQ_INODES:\t%"PRIu64"\n"
-            "\t\tBGQ_ANODES:\t%"PRIu64"\n"
-            "\t\tBGQ_BNODES:\t%"PRIu64"\n"
-            "\t\tBGQ_CNODES:\t%"PRIu64"\n"
-            "\t\tBGQ_DNODES:\t%"PRIu64"\n"
-            "\t\tBGQ_ENODES:\t%"PRIu64"\n"
-            "\t\tBGQ_TORUSEN:\t%"PRIx64"\n"
-            "\t\tBGQ_TIMESTAMP:\t%lf\n",
-            next_file.counters[BGQ_CSJOBID],
-            next_file.counters[BGQ_NNODES],
-            next_file.counters[BGQ_RANKSPERNODE],
-            next_file.counters[BGQ_DDRPERNODE],
-            next_file.counters[BGQ_INODES],
-            next_file.counters[BGQ_ANODES],
-            next_file.counters[BGQ_BNODES],
-            next_file.counters[BGQ_CNODES],
-            next_file.counters[BGQ_DNODES],
-            next_file.counters[BGQ_ENODES],
-            next_file.counters[BGQ_TORUSENABLED],
-            next_file.fcounters[BGQ_F_TIMESTAMP]);
-        i++;
-    } while((ret = darshan_log_get_bgq_file(fd, &next_file)) == 1);
-    /* free mount info */
-        free(mnt_pts[i]);
-        free(fs_types[i]);
-    if(mount_count > 0)
-        free(mnt_pts);
-        free(fs_types);
-    return(0);
diff --git a/darshan-util/darshan-job-summary/bin/darshan-job-summary.pl.in b/darshan-util/darshan-job-summary/bin/darshan-job-summary.pl.in
index 4fcb1c6..4826009 100755
--- a/darshan-util/darshan-job-summary/bin/darshan-job-summary.pl.in
+++ b/darshan-util/darshan-job-summary/bin/darshan-job-summary.pl.in
@@ -928,7 +928,7 @@ system "$epstopdf pattern.eps";
 # generate summary PDF
 # NOTE: we pass arguments to the latex template using '\def' commands
 # NOTE: an autoconf test determines if -halt-on-error is available and sets
-# __CP_PDFLATEX_HALT_ON_ERROR accordingly
+# __DARSHAN_PDFLATEX_HALT_ON_ERROR accordingly
 my $latex_cmd_line = "\"\\def\\titlecmd{$cmd} \\
     \\def\\titlemon{$mon} \\
     \\def\\titlemday{$mday} \\
@@ -949,7 +949,7 @@ my $latex_cmd_line = "\"\\def\\titlecmd{$cmd} \\
     \\def\\filecmi{$cmi} \\
     \\def\\filecms{$cms} \\
     \\input{summary.tex}\" \\
-    @__CP_PDFLATEX_HALT_ON_ERROR@";
+    @__DARSHAN_PDFLATEX_HALT_ON_ERROR@";
 if (defined $summary{MPIIO_INDEP_OPENS})
diff --git a/darshan-util/darshan-logutils.c b/darshan-util/darshan-logutils.c
index 3a4327e..b4a9ed8 100644
--- a/darshan-util/darshan-logutils.c
+++ b/darshan-util/darshan-logutils.c
@@ -602,7 +602,7 @@ int darshan_log_gethash(darshan_fd fd, struct darshan_record_ref **hash)
         hash_buf, &hash_buf_sz, fd->comp_type);
     if(ret < 0)
-        fprintf(stderr, "Error: unable to decompress darshan job data.\n");
+        fprintf(stderr, "Error: unable to decompress darshan record map data.\n");
         free(comp_buf);
         free(hash_buf);
         return(-1);
diff --git a/darshan-util/maint/darshan-util.pc.in b/darshan-util/maint/darshan-util.pc.in
index 6fd4f3e..7e58689 100644
--- a/darshan-util/maint/darshan-util.pc.in
+++ b/darshan-util/maint/darshan-util.pc.in
@@ -3,8 +3,8 @@ exec_prefix = @exec_prefix@
 libdir = @libdir@
 includedir = @includedir@
 abs_top_builddir = @abs_top_builddir@
+darshan_zlib_include_flags = @__DARSHAN_ZLIB_INCLUDE_FLAGS@
+darshan_zlib_link_flags = @__DARSHAN_ZLIB_LINK_FLAGS@
 LIBBZ2 = @LIBBZ2@
@@ -13,5 +13,5 @@ Version: @DARSHAN_UTIL_VERSION@
 URL: http://trac.mcs.anl.gov/projects/darshan/
 Requires:
 Libs: -L${libdir} -ldarshan-util
-Libs.private: ${cp_zlib_link_flags} -lz ${LIBBZ2}
-Cflags: -I${includedir} ${cp_zlib_include_flags}
+Libs.private: ${darshan_zlib_link_flags} -lz ${LIBBZ2}
+Cflags: -I${includedir} ${darshan_zlib_include_flags}
hooks/post-receive
More information about the Darshan-commits
