[Darshan-commits] [Darshan] branch, dev-modular, updated. darshan-2.3.1-174-g22bc23f
Service Account
git at mcs.anl.gov
Thu Sep 10 10:52:26 CDT 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
via 22bc23f2782273ebe8c65eb559f67d9b4b8004e4 (commit)
from 57cb76241543beb5fbbdd28b220940f068465a75 (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit 22bc23f2782273ebe8c65eb559f67d9b4b8004e4
Author: Shane Snyder <ssnyder at mcs.anl.gov>
Date: Thu Sep 10 09:56:08 2015 -0500
drop CP_ prefixes in runtime code
Summary of changes:
darshan-runtime/configure | 30 ++++++++++----------
darshan-runtime/configure.in | 26 +++++++++---------
darshan-runtime/darshan-core.h | 17 +++++------
darshan-runtime/darshan-mk-log-dirs.pl.in | 2 +-
darshan-runtime/darshan-runtime-config.h.in | 16 +++++-----
darshan-runtime/doc/darshan-runtime.txt | 2 +-
darshan-runtime/lib/darshan-core.c | 40 +++++++++++++-------------
maint/config/check_zlib.m4 | 4 +-
8 files changed, 68 insertions(+), 69 deletions(-)
Diff of changes:
diff --git a/darshan-runtime/configure b/darshan-runtime/configure
index b7929bc..be3e002 100755
--- a/darshan-runtime/configure
+++ b/darshan-runtime/configure
@@ -625,7 +625,7 @@ DARSHAN_USE_BGQ
MPICH_LIB_OLD
DARSHAN_VERSION
DISABLE_LDPRELOAD
-__CP_LOG_PATH
+__DARSHAN_LOG_PATH
darshan_share_path
darshan_lib_path
PRI_MACROS_BROKEN
@@ -3467,8 +3467,8 @@ if test "${with_zlib+set}" = set; then :
ZLIB_HOME="$withval"
LDFLAGS="$LDFLAGS -L${ZLIB_HOME}/lib"
CPPFLAGS="$CPPFLAGS -I${ZLIB_HOME}/include"
- __CP_ZLIB_LINK_FLAGS="-L${ZLIB_HOME}/lib"
- __CP_ZLIB_INCLUDE_FLAGS="-I${ZLIB_HOME}/include"
+ __DARSHAN_ZLIB_LINK_FLAGS="-L${ZLIB_HOME}/lib"
+ __DARSHAN_ZLIB_INCLUDE_FLAGS="-I${ZLIB_HOME}/include"
else
{ $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: Sorry, $withval does not exist, checking usual places" >&5
$as_echo "$as_me: WARNING: Sorry, $withval does not exist, checking usual places" >&2;}
@@ -3561,7 +3561,7 @@ fi
if test "${enable_group_readable_logs+set}" = set; then :
enableval=$enable_group_readable_logs; if test "x$enableval" = "xyes" ; then
-$as_echo "#define __CP_GROUP_READABLE_LOGS 1" >>confdefs.h
+$as_echo "#define __DARSHAN_GROUP_READABLE_LOGS 1" >>confdefs.h
fi
@@ -3576,7 +3576,7 @@ if test "${with_mem_align+set}" = set; then :
else
cat >>confdefs.h <<_ACEOF
-#define __CP_MEM_ALIGNMENT ${withval}
+#define __DARSHAN_MEM_ALIGNMENT ${withval}
_ACEOF
GOT_ALIGNMENT=1
@@ -3593,10 +3593,10 @@ if test "${with_log_path_by_env+set}" = set; then :
else
-#define __CP_LOG_ENV "${withval}"
+#define __DARSHAN_LOG_ENV "${withval}"
_ACEOF
- __CP_LOG_ENV="${withval}"
+ __DARSHAN_LOG_ENV="${withval}"
GOT_LOG_PATH=1
fi
@@ -3611,10 +3611,10 @@ if test "${with_log_hints+set}" = set; then :
else
-#define __CP_LOG_HINTS "${withval}"
+#define __DARSHAN_LOG_HINTS "${withval}"
_ACEOF
- __CP_LOG_HINTS="${withval}"
+ __DARSHAN_LOG_HINTS="${withval}"
GOT_LOG_HINTS=1
fi
@@ -3629,10 +3629,10 @@ if test "${with_log_path+set}" = set; then :
else
-#define __CP_LOG_PATH "${withval}"
+#define __DARSHAN_LOG_PATH "${withval}"
_ACEOF
- __CP_LOG_PATH="${withval}"
+ __DARSHAN_LOG_PATH="${withval}"
GOT_LOG_PATH=1
fi
@@ -3647,10 +3647,10 @@ if test "${with_jobid_env+set}" = set; then :
else
-#define CP_JOBID "${withval}"
+#define __DARSHAN_JOBID "${withval}"
_ACEOF
- CP_JOBID="${withval}"
+ __DARSHAN_JOBID="${withval}"
GOT_JOBID=1
fi
@@ -3666,11 +3666,11 @@ fi
if test x$GOT_JOBID != x1; then
as_fn_error $? "must provide --with-jobid-env=<name> argument to configure." "$LINENO" 5
fi
-__CP_LOG_HINTS_DEFAULT="romio_no_indep_rw=true;cb_nodes=4"
+__DARSHAN_LOG_HINTS_DEFAULT="romio_no_indep_rw=true;cb_nodes=4"
if test x$GOT_LOG_HINTS != x1; then
-#define __CP_LOG_HINTS "$__CP_LOG_HINTS_DEFAULT"
+#define __DARSHAN_LOG_HINTS "$__DARSHAN_LOG_HINTS_DEFAULT"
_ACEOF
fi
diff --git a/darshan-runtime/configure.in b/darshan-runtime/configure.in
index 210c5db..d88b8f7 100644
--- a/darshan-runtime/configure.in
+++ b/darshan-runtime/configure.in
@@ -46,7 +46,7 @@ fi]
AC_ARG_ENABLE(group-readable-logs,
[ --enable-group-readable-logs Set log files to be group readable],
[if test "x$enableval" = "xyes" ; then
- AC_DEFINE(__CP_GROUP_READABLE_LOGS, 1, Define if Darshan should set log files to be group readable)
+ AC_DEFINE(__DARSHAN_GROUP_READABLE_LOGS, 1, Define if Darshan should set log files to be group readable)
fi]
@@ -55,7 +55,7 @@ AC_ARG_WITH(mem-align,
if test x$withval = xyes; then
AC_MSG_ERROR(--with-mem-align must be given a number in bytes)
else
- AC_DEFINE_UNQUOTED(__CP_MEM_ALIGNMENT, ${withval}, Memory alignment in bytes)
+ AC_DEFINE_UNQUOTED(__DARSHAN_MEM_ALIGNMENT, ${withval}, Memory alignment in bytes)
GOT_ALIGNMENT=1
fi
@@ -65,8 +65,8 @@ AC_ARG_WITH(log-path-by-env,
AC_MSG_ERROR(--with-log-path-by-env must be given at least one variable name)
else
- AC_DEFINE_UNQUOTED(__CP_LOG_ENV, "${withval}", Comma separated list of env. variables to use for log path)
+ AC_DEFINE_UNQUOTED(__DARSHAN_LOG_ENV, "${withval}", Comma separated list of env. variables to use for log path)
GOT_LOG_PATH=1
fi
@@ -76,8 +76,8 @@ AC_ARG_WITH(log-hints,
AC_MSG_ERROR(--with-log-hints must be given an argument)
else
- AC_DEFINE_UNQUOTED(__CP_LOG_HINTS, "${withval}", Semicolon-separated list of MPI-IO hints for log file write)
+ AC_DEFINE_UNQUOTED(__DARSHAN_LOG_HINTS, "${withval}", Semicolon-separated list of MPI-IO hints for log file write)
GOT_LOG_HINTS=1
fi
@@ -87,8 +87,8 @@ AC_ARG_WITH(log-path,
AC_MSG_ERROR(--with-log-path must be given a pathname)
else
- AC_DEFINE_UNQUOTED(__CP_LOG_PATH, "${withval}", Location to store log files at run time)
+ AC_DEFINE_UNQUOTED(__DARSHAN_LOG_PATH, "${withval}", Location to store log files at run time)
GOT_LOG_PATH=1
fi
@@ -100,8 +100,8 @@ AC_ARG_WITH(jobid-env,
AC_MSG_ERROR(--with-jobid-env must be given a name)
else
- AC_DEFINE_UNQUOTED(CP_JOBID, "${withval}", Name of the environment variable that stores the jobid)
+ AC_DEFINE_UNQUOTED(__DARSHAN_JOBID, "${withval}", Name of the environment variable that stores the jobid)
GOT_JOBID=1
fi
@@ -115,10 +115,10 @@ fi
AC_MSG_ERROR(must provide --with-jobid-env=<name> argument to configure.)
fi
dnl use default hints
- AC_DEFINE_UNQUOTED(__CP_LOG_HINTS, "$__CP_LOG_HINTS_DEFAULT", Comma-separated list of MPI-IO hints for log file write)
+ AC_DEFINE_UNQUOTED(__DARSHAN_LOG_HINTS, "$__DARSHAN_LOG_HINTS_DEFAULT", Comma-separated list of MPI-IO hints for log file write)
fi
# checks to see how we can print 64 bit values on this architecture
@@ -313,7 +313,7 @@ DARSHAN_VERSION="AC_PACKAGE_VERSION"
AC_SUBST(darshan_lib_path)
AC_SUBST(darshan_share_path)
AC_SUBST(LDFLAGS)
-AC_SUBST(__CP_LOG_PATH)
+AC_SUBST(__DARSHAN_LOG_PATH)
AC_SUBST(DISABLE_LDPRELOAD)
AC_SUBST(DARSHAN_VERSION)
AC_SUBST(MPICH_LIB_OLD)
diff --git a/darshan-runtime/darshan-core.h b/darshan-runtime/darshan-core.h
index 7de647f..7437c4f 100644
--- a/darshan-runtime/darshan-core.h
+++ b/darshan-runtime/darshan-core.h
@@ -14,18 +14,17 @@
#include "uthash.h"
#include "darshan-log-format.h"
-/* TODO: drop CP_ and use DARSHAN_ */
-/* Environment variable to override CP_JOBID */
-#define CP_JOBID_OVERRIDE "DARSHAN_JOBID"
+/* Environment variable to override __DARSHAN_JOBID */
+#define DARSHAN_JOBID_OVERRIDE "DARSHAN_JOBID"
-/* Environment variable to override __CP_LOG_PATH */
-#define CP_LOG_PATH_OVERRIDE "DARSHAN_LOGPATH"
+/* Environment variable to override __DARSHAN_LOG_PATH */
+#define DARSHAN_LOG_PATH_OVERRIDE "DARSHAN_LOGPATH"
-#define CP_LOG_HINTS_OVERRIDE "DARSHAN_LOGHINTS"
+/* Environment variable to override __DARSHAN_LOG_HINTS */
+#define DARSHAN_LOG_HINTS_OVERRIDE "DARSHAN_LOGHINTS"
-/* Environment variable to override __CP_MEM_ALIGNMENT */
-#define CP_MEM_ALIGNMENT_OVERRIDE "DARSHAN_MEMALIGN"
+/* Environment variable to override __DARSHAN_MEM_ALIGNMENT */
+#define DARSHAN_MEM_ALIGNMENT_OVERRIDE "DARSHAN_MEMALIGN"
#define DARSHAN_CORE_MAX_RECORDS 1024
diff --git a/darshan-runtime/darshan-mk-log-dirs.pl.in b/darshan-runtime/darshan-mk-log-dirs.pl.in
index f102035..b94b3f1 100644
--- a/darshan-runtime/darshan-mk-log-dirs.pl.in
+++ b/darshan-runtime/darshan-mk-log-dirs.pl.in
@@ -10,7 +10,7 @@ use File::Basename;
# LOGDIR/<year>/<month>/<day>/
# use log dir specified at configure time
-$LOGDIR = "@__CP_LOG_PATH@";
+$LOGDIR = "@__DARSHAN_LOG_PATH@";
my $year = (localtime)[5] + 1900;
diff --git a/darshan-runtime/darshan-runtime-config.h.in b/darshan-runtime/darshan-runtime-config.h.in
index 5ed35b4..ad3e9cc 100644
--- a/darshan-runtime/darshan-runtime-config.h.in
+++ b/darshan-runtime/darshan-runtime-config.h.in
@@ -3,9 +3,6 @@
/* Define if building universal (internal helper macro) */
#undef AC_APPLE_UNIVERSAL_BUILD
-/* Name of the environment variable that stores the jobid */
-#undef CP_JOBID
/* Define if cuserid() should be disabled */
#undef DARSHAN_DISABLE_CUSERID
@@ -91,19 +88,22 @@
#endif
/* Define if Darshan should set log files to be group readable */
-#undef __CP_GROUP_READABLE_LOGS
+#undef __DARSHAN_GROUP_READABLE_LOGS
+/* Name of the environment variable that stores the jobid */
+#undef __DARSHAN_JOBID
/* Comma separated list of env. variables to use for log path */
-#undef __CP_LOG_ENV
+#undef __DARSHAN_LOG_ENV
/* Comma-separated list of MPI-IO hints for log file write */
-#undef __CP_LOG_HINTS
+#undef __DARSHAN_LOG_HINTS
/* Location to store log files at run time */
-#undef __CP_LOG_PATH
+#undef __DARSHAN_LOG_PATH
/* Memory alignment in bytes */
-#undef __CP_MEM_ALIGNMENT
+#undef __DARSHAN_MEM_ALIGNMENT
/* Generalized request type for MPI-IO */
#undef __D_MPI_REQUEST
diff --git a/darshan-runtime/doc/darshan-runtime.txt b/darshan-runtime/doc/darshan-runtime.txt
index bd6b9b2..34849ad 100644
--- a/darshan-runtime/doc/darshan-runtime.txt
+++ b/darshan-runtime/doc/darshan-runtime.txt
@@ -477,7 +477,7 @@ behavior at runtime:
* DARSHAN_DISABLE: disables Darshan instrumentation
* DARSHAN_INTERNAL_TIMING: enables internal instrumentation that will print the time required to startup and shutdown Darshan to stderr at run time.
* DARSHAN_LOGHINTS: specifies the MPI-IO hints to use when storing the Darshan output file. The format is a semicolon-delimited list of key=value pairs, for example: hint1=value1;hint2=value2
-* DARSHAN_MEMALIGN: specifies a value for memory alignment (CP_MEM_ALIGNMENT)
+* DARSHAN_MEMALIGN: specifies a value for system memory alignment
* DARSHAN_JOBID: specifies the name of the environment variable to use for the job identifier, such as PBS_JOBID
* DARSHAN_DISABLE_SHARED_REDUCTION: disables the step in Darshan aggregation
in which files that were accessed by all ranks are collapsed into a single
diff --git a/darshan-runtime/lib/darshan-core.c b/darshan-runtime/lib/darshan-core.c
index b534a1f..17e6b77 100644
--- a/darshan-runtime/lib/darshan-core.c
+++ b/darshan-runtime/lib/darshan-core.c
@@ -140,10 +140,10 @@ void darshan_core_initialize(int argc, char **argv)
/* setup darshan runtime if darshan is enabled and hasn't been initialized already */
if(!getenv("DARSHAN_DISABLE") && !darshan_core)
- #if (__CP_MEM_ALIGNMENT < 1)
+ #if (__DARSHAN_MEM_ALIGNMENT < 1)
#error Darshan must be configured with a positive value for --with-mem-align
#endif
- envstr = getenv("DARSHAN_MEMALIGN");
+ envstr = getenv(DARSHAN_MEM_ALIGNMENT_OVERRIDE);
if(envstr)
ret = sscanf(envstr, "%d", &tmpval);
@@ -155,7 +155,7 @@ void darshan_core_initialize(int argc, char **argv)
else
- darshan_mem_alignment = __CP_MEM_ALIGNMENT;
+ darshan_mem_alignment = __DARSHAN_MEM_ALIGNMENT;
/* avoid floating point errors on faulty input */
@@ -303,11 +303,11 @@ void darshan_core_shutdown()
/* set darshan job id/metadata and constuct log file name on rank 0 */
if(my_rank == 0)
- /* Use CP_JOBID_OVERRIDE for the env var or CP_JOBID */
- envjobid = getenv(CP_JOBID_OVERRIDE);
+ /* Use DARSHAN_JOBID_OVERRIDE for the env var or __DARSHAN_JOBID */
+ envjobid = getenv(DARSHAN_JOBID_OVERRIDE);
if(!envjobid)
- envjobid = CP_JOBID;
+ envjobid = __DARSHAN_JOBID;
/* find a job id */
@@ -590,7 +590,7 @@ void darshan_core_shutdown()
if(getenv("DARSHAN_LOGFILE"))
-#ifdef __CP_GROUP_READABLE_LOGS
+#ifdef __DARSHAN_GROUP_READABLE_LOGS
chmod(logfile_name, (S_IRUSR|S_IRGRP));
#else
chmod(logfile_name, (S_IRUSR));
@@ -612,7 +612,7 @@ void darshan_core_shutdown()
sprintf(tmp_index, "_%d.darshan", (int)(end_log_time-start_log_time+1));
rename(logfile_name, new_logfile_name);
/* set permissions on log file */
chmod(new_logfile_name, (S_IRUSR|S_IRGRP));
#else
chmod(new_logfile_name, (S_IRUSR));
@@ -688,7 +688,7 @@ static void darshan_get_logfile_name(char* logfile_name, int jobid, struct tm* s
char* logpath;
char* logname_string;
char* logpath_override = NULL;
-#ifdef __CP_LOG_ENV
+#ifdef __DARSHAN_LOG_ENV
char env_check[256];
char* env_tok;
#endif
@@ -716,12 +716,12 @@ static void darshan_get_logfile_name(char* logfile_name, int jobid, struct tm* s
/* otherwise, generate the log path automatically */
- /* Use CP_LOG_PATH_OVERRIDE for the value or __CP_LOG_PATH */
- logpath = getenv(CP_LOG_PATH_OVERRIDE);
+ /* Use DARSHAN_LOG_PATH_OVERRIDE for the value or __DARSHAN_LOG_PATH */
+ logpath = getenv(DARSHAN_LOG_PATH_OVERRIDE);
if(!logpath)
-#ifdef __CP_LOG_PATH
- logpath = __CP_LOG_PATH;
+#ifdef __DARSHAN_LOG_PATH
+ logpath = __DARSHAN_LOG_PATH;
#endif
@@ -766,12 +766,12 @@ static void darshan_get_logfile_name(char* logfile_name, int jobid, struct tm* s
* argument, which allows the user to specify an absolute path to
* place logs via an env variable.
/* just silently skip if the environment variable list is too big */
- if(strlen(__CP_LOG_ENV) < 256)
+ if(strlen(__DARSHAN_LOG_ENV) < 256)
/* copy env variable list to a temporary buffer */
- strcpy(env_check, __CP_LOG_ENV);
+ strcpy(env_check, __DARSHAN_LOG_ENV);
/* tokenize the comma-separated list */
env_tok = strtok(env_check, ",");
if(env_tok)
@@ -847,10 +847,10 @@ static void darshan_log_record_hints_and_ver(struct darshan_core_runtime* core)
/* check environment variable to see if the default MPI file hints have
* been overridden
- hints = getenv(CP_LOG_HINTS_OVERRIDE);
+ hints = getenv(DARSHAN_LOG_HINTS_OVERRIDE);
if(!hints)
- hints = __CP_LOG_HINTS;
+ hints = __DARSHAN_LOG_HINTS;
if(!hints || strlen(hints) < 1)
@@ -1153,10 +1153,10 @@ static int darshan_log_open_all(char *logfile_name, MPI_File *log_fh)
MPI_Info_create(&info);
if(!hints)
if(hints && strlen(hints) > 0)
diff --git a/maint/config/check_zlib.m4 b/maint/config/check_zlib.m4
index ba74736..1979f95 100644
--- a/maint/config/check_zlib.m4
+++ b/maint/config/check_zlib.m4
@@ -11,8 +11,8 @@ AC_ARG_WITH(zlib,
else
AC_MSG_WARN([Sorry, $withval does not exist, checking usual places])
fi
hooks/post-receive
More information about the Darshan-commits
