[Darshan-commits] [Git][darshan/darshan][mmap-dev] add new utility to stitch together darshan logs
Shane Snyder
xgitlab at cels.anl.gov
Fri Dec 4 11:10:44 CST 2015
Shane Snyder pushed to branch mmap-dev at darshan / darshan
Commits:
9193b34a by Shane Snyder at 2015-12-04T11:10:14Z
2 changed files:
- darshan-util/Makefile.in
- + darshan-util/darshan-stitch-logs.c
Changes:
--- a/darshan-util/Makefile.in
+++ b/darshan-util/Makefile.in
@@ -1,4 +1,4 @@
-all: libdarshan-util.a darshan-null-logutils.o darshan-analyzer darshan-convert darshan-parser jenkins-hash-gen
+all: libdarshan-util.a darshan-null-logutils.o darshan-analyzer darshan-convert darshan-parser darshan-stitch-logs jenkins-hash-gen
DESTDIR =
srcdir = @srcdir@
@@ -106,6 +106,9 @@ darshan-convert: darshan-convert.c darshan-logutils.h $(DARSHAN_LOG_FORMAT) libd
darshan-parser: darshan-parser.c darshan-logutils.h $(DARSHAN_LOG_FORMAT) $(DARSHAN_MOD_LOGUTIL_HEADERS) $(DARSHAN_MOD_LOG_FORMATS) libdarshan-util.a | uthash-1.9.2
$(CC) $(CFLAGS) $(LDFLAGS) $^ -o $@ $(LIBS)
+darshan-stitch-logs: darshan-stitch-logs.c darshan-logutils.h $(DARSHAN_LOG_FORMAT) libdarshan-util.a | uthash-1.9.2
+ $(CC) $(CFLAGS) $(LDFLAGS) $^ -o $@ $(LIBS)
#test/gztest: test/gztest.c mktestdir
# $(CC) $(CFLAGS) $(LDFLAGS) -lz $< -o $@
--- /dev/null
+++ b/darshan-util/darshan-stitch-logs.c
@@ -0,0 +1,317 @@
+#include <stdio.h>
+#include <stdlib.h>
+#include <fcntl.h>
+#include <glob.h>
+#include <string.h>
+#include <assert.h>
+#include "darshan-logutils.h"
+int logfile_path_comp(const void *a, const void *b)
+ char *pathA = *(char **)a;
+ char *pathB = *(char **)b;
+ char *pathA_rank_s, *pathB_rank_s;
+ int pathA_rank, pathB_rank;
+ /* extract the process rank number from end of each log file path */
+ pathA_rank_s = strrchr(pathA, '.') + 1;
+ pathA_rank = atoi(pathA_rank_s);
+ pathB_rank_s = strrchr(pathB, '.') + 1;
+ pathB_rank = atoi(pathB_rank_s);
+ if(pathA_rank < pathB_rank)
+ return(-1);
+ else if(pathA_rank > pathB_rank)
+ return(1);
+ else
+ return(0);
+int main(int argc, char *argv[])
+ darshan_fd out_fd;
+ char *out_logname; /* XXX default + configurable? */
+ int ret;
+ int i, j;
+ char *tmplog_dir;
+ int job_id;
+ glob_t globbuf;
+ char glob_pstr[512];
+ int tmp_fd;
+ struct darshan_job in_job, out_job;
+ char in_exe_mnt[DARSHAN_EXE_LEN+1];
+ char *mnt_s, *pos;
+ char out_exe[DARSHAN_EXE_LEN+1];
+ char **out_mnt_pts;
+ char **out_fs_types;
+ int out_mnt_count = 0;
+ /* TODO: are there any checks we should do to ensure tmp logs belong to the same job */
+ /* we can't specifically check the job id, since the pid is used if no job scheduler */
+ /* TODO: how do we set the output logfile name to be unique, and have necessary semantic info contained */
+ /* TODO: more thorough way of cleaning up (free, close, etc.) */
+ if(argc != 3)
+ fprintf(stderr, "Usage: ./darshan-stitch-tmplogs <tmp_dir> <job_id>\n"
+ "\t<tmp_dir> is the directory containing the temporary Darshan logs\n"
+ "\t<job_id> is the job id of the logs we are trying to stitch\n");
+ return(0);
+ /* grab command line arguments */
+ tmplog_dir = argv[1];
+ job_id = atoi(argv[2]);
+ /* construct the list of input log files to stitch together */
+ snprintf(glob_pstr, 512, "%s/darshan_job%d*", tmplog_dir, job_id);
+ ret = glob(glob_pstr, GLOB_NOSORT, NULL, &globbuf);
+ if(ret != 0)
+ fprintf(stderr,
+ "Error: unable to construct list of input Darshan log files.\n");
+ return(-1);
+ /* sort the file list according to the rank id appended to each logfile name */
+ /* NOTE: we don't rely on glob's default alphabetic sorting, because it won't
+ * sort by ascending ranks if pid's are used for job ids, for instance
+ qsort(globbuf.gl_pathv, globbuf.gl_pathc, sizeof(char *), logfile_path_comp);
+ memset(&out_job, 0, sizeof(struct darshan_job));
+ /* first pass at stitching together logs:
+ * - compose a final job-level metadata structure
+ for(i = 0; i < globbuf.gl_pathc; i++)
+ memset(&in_job, 0, sizeof(struct darshan_job));
+ tmp_fd = open(globbuf.gl_pathv[i], O_RDONLY);
+ if(tmp_fd < 0)
+ fprintf(stderr,
+ "Error: unable to open Darshan log file %s.\n",
+ globbuf.gl_pathv[i]);
+ return(-1);
+ /* read job-level metadata from the input file */
+ ret = pread(tmp_fd, &in_job, sizeof(struct darshan_job), 0);
+ if(ret < sizeof(struct darshan_job))
+ fprintf(stderr,
+ "Error: unable to read job data from Darshan log file %s\n",
+ return(-1);
+ if(i == 0)
+ /* get all job data from the first input log */
+ memcpy(&out_job, &in_job, sizeof(struct darshan_job));
+ ret = pread(tmp_fd, in_exe_mnt, DARSHAN_EXE_LEN+1, sizeof(struct darshan_job));
+ if(ret < DARSHAN_EXE_LEN+1)
+ fprintf(stderr,
+ "Error: unable to read exe & mount data from Darshan log file %s\n",
+ return(-1);
+ /* get the exe string */
+ mnt_s = strchr(in_exe_mnt, '\n');
+ memcpy(out_exe, in_exe_mnt, mnt_s-in_exe_mnt);
+ out_exe[mnt_s-in_exe_mnt] = '\0';
+ /* build mount structures */
+ pos = mnt_s;
+ while((pos = strchr(pos, '\n')) != NULL)
+ pos++;
+ out_mnt_count++;
+ if(out_mnt_count)
+ out_mnt_pts = malloc(out_mnt_count * sizeof(char *));
+ assert(out_mnt_pts);
+ out_fs_types = malloc(out_mnt_count * sizeof(char *));
+ assert(out_fs_types);
+ /* work backwards through the table and parse each line (except for
+ * first, which holds command line information)
+ j = 0;
+ while((pos = strrchr(in_exe_mnt, '\n')) != NULL)
+ /* overestimate string lengths */
+ out_mnt_pts[j] = malloc(DARSHAN_EXE_LEN);
+ assert(out_mnt_pts[j]);
+ out_fs_types[j] = malloc(DARSHAN_EXE_LEN);
+ assert(out_fs_types[j]);
+ ret = sscanf(++pos, "%s\t%s", out_fs_types[j], out_mnt_pts[j]);
+ if(ret != 2)
+ fprintf(stderr,
+ "Error: poorly formatted mount table in darshan log file %s.\n",
+ return(-1);
+ pos--;
+ *pos = '\0';
+ j++;
+ else
+ /* potentially update job timestamps */
+ if(in_job.start_time < out_job.start_time)
+ out_job.start_time = in_job.start_time;
+ if(in_job.end_time > out_job.end_time)
+ out_job.end_time = in_job.end_time;
+ close(tmp_fd);
+ /* create the output "stitched together" log */
+ out_fd = darshan_log_create("/tmp/test123.darshan", DARSHAN_ZLIB_COMP, 1);
+ if(out_fd == NULL)
+ fprintf(stderr, "Error: unable to create output darshan log.\n");
+ return(-1);
+ /* write the darshan job info, exe string, and mount data to output file */
+ ret = darshan_log_putjob(out_fd, &out_job);
+ if(ret < 0)
+ fprintf(stderr, "Error: unable to write job data to output darshan log.\n");
+ return(-1);
+ ret = darshan_log_putexe(out_fd, out_exe);
+ if(ret < 0)
+ fprintf(stderr, "Error: unable to write exe string to output darshan log.\n");
+ return(-1);
+ ret = darshan_log_putmounts(out_fd, out_mnt_pts, out_fs_types, out_mnt_count);
+ if(ret < 0)
+ fprintf(stderr, "Error: unable to write mount data to output darshan log.\n");
+ return(-1);
+ void *mod_buf = malloc(2*1024*1024);
+ assert(mod_buf);
+ /* second pass at stitching together logs:
+ * - append module data to output log file
+ if(tmp_fd < 0)
+ fprintf(stderr,
+ return(-1);
+ ret = pread(tmp_fd, mod_buf, 2*1024*1024, 4*1024);
+ if(ret < (2*1024*1024))
+ fprintf(stderr,
+ "Error: unable to read module data from Darshan log file %s\n",
+ return(-1);
+ /* iterate and write file records */
+ void *mod_buf_p = mod_buf;
+ while(1)
+#if 0
+ ret = darshan_log_put_posix_file(out_fd, VOID*);
+ if(ret < 0)
+ fprintf(stderr,
+ "Error: unable to write module record to output darshan log.\n");
+ return(-1);
+#endif
+ close(tmp_fd);
+ darshan_log_close(out_fd);
+ free(mod_buf);
+ globfree(&globbuf);
+ return(0);
+#if 0
+ /* print out job info to sanity check */
+ time_t tmp_time = 0;
+ char *token;
+ char *save;
+ char buffer[DARSHAN_JOB_METADATA_LEN];
+ #include <time.h>
+ printf("# exe: %s\n", out_exe);
+ printf("# uid: %" PRId64 "\n", out_job.uid);
+ printf("# jobid: %" PRId64 "\n", out_job.jobid);
+ printf("# start_time: %" PRId64 "\n", out_job.start_time);
+ tmp_time += out_job.start_time;
+ printf("# start_time_asci: %s", ctime(&tmp_time));
+ printf("# end_time: %" PRId64 "\n", out_job.end_time);
+ tmp_time = 0;
+ tmp_time += out_job.end_time;
+ printf("# end_time_asci: %s", ctime(&tmp_time));
+ printf("# nprocs: %" PRId64 "\n", out_job.nprocs);
+ printf("# run time: %" PRId64 "\n", out_job.end_time - out_job.start_time + 1);
+ for(token=strtok_r(out_job.metadata, "\n", &save);
+ token != NULL;
+ token=strtok_r(NULL, "\n", &save))
+ char *key;
+ char *value;
+ /* NOTE: we intentionally only split on the first = character.
+ * There may be additional = characters in the value portion
+ * (for example, when storing mpi-io hints).
+ strcpy(buffer, token);
+ key = buffer;
+ value = index(buffer, '=');
+ if(!value)
+ continue;
+ /* convert = to a null terminator to split key and value */
+ value[0] = '\0';
+ value++;
+ printf("# metadata: %s = %s\n", key, value);
+ /* print table of mounted file systems */
+ printf("\n# mounted file systems (mount point and fs type)\n");
+ printf("# -------------------------------------------------------\n");
+ for(j=0; j<out_mnt_count; j++)
+ printf("# mount entry:\t%s\t%s\n", out_mnt_pts[j], out_fs_types[j]);
+#endif
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/9193b34aaf7e9f9d1e5361dfb44667d14277f23f
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20151204/fe68a324/attachment-0001.html>
More information about the Darshan-commits
