[Darshan-commits] [Git][darshan/darshan][mmap-dev] modify register_record routine used by modules
Shane Snyder
xgitlab at cels.anl.gov
Fri Dec 4 10:21:02 CST 2015
Shane Snyder pushed to branch mmap-dev at darshan / darshan
Commits:
376eefa8 by Shane Snyder at 2015-12-04T10:20:47Z
Now, register_record() accepts an argument for the size of
the record being registered, and this is used to track how much
data each module has stored in their allocated memory region.
4 changed files:
- darshan-runtime/darshan.h
- darshan-runtime/lib/darshan-core.c
- darshan-runtime/lib/darshan-posix.c
- darshan-util/darshan-parser.c
Changes:
--- a/darshan-runtime/darshan.h
+++ b/darshan-runtime/darshan.h
@@ -127,10 +127,10 @@ void darshan_core_unregister_module(
void darshan_core_register_record(
void *name,
- int len,
+ int name_len,
+ int rec_size,
darshan_module_id mod_id,
int printable_flag,
- int mod_limit_flag,
darshan_record_id *rec_id,
int *file_alignment);
--- a/darshan-runtime/lib/darshan-core.c
+++ b/darshan-runtime/lib/darshan-core.c
@@ -1265,9 +1265,11 @@ void darshan_core_register_module(
return;
- /* XXX how do we assign size and address */
+ /* XXX MMAP: how do we assign size and address */
*mod_buf = darshan_core->log_mod_p;
- *mod_buf_size = 2*1024*1024;
+ *mod_buf_size = DARSHAN_MOD_MEM_MAX;
+ darshan_core->log_hdr_p->mod_map[mod_id].off =
+ ((char *)darshan_core->log_mod_p - (char *)darshan_core->log_hdr_p);
/* this module has not been registered yet, allocate and initialize it */
mod = malloc(sizeof(*mod));
@@ -1315,12 +1317,13 @@ void darshan_core_unregister_module(
return;
+/* TODO: maybe a return code to distinguish between id 0 and a failure */
void *name,
- int len,
+ int name_len,
+ int rec_size,
int printable_flag,
@@ -1328,14 +1331,16 @@ void darshan_core_register_record(
struct darshan_core_record_ref *ref;
*rec_id = 0;
+ *file_alignment = 0;
if(!darshan_core)
return;
/* TODO: what do you do with printable flag? */
+ /* TODO: what about partial flag? */
/* hash the input name to get a unique id for this record */
- tmp_rec_id = darshan_hash(name, len, 0);
+ tmp_rec_id = darshan_hash(name, name_len, 0);
/* check to see if we've already stored the id->name mapping for this record */
DARSHAN_CORE_LOCK();
@@ -1345,28 +1350,26 @@ void darshan_core_register_record(
/* record not found -- add it to the hash if this module has not already used
* all of its memory
-#if 0
- if(mod_limit_flag)
+ darshan_add_record_hashref(darshan_core, name, tmp_rec_id, &ref);
+ if(!ref)
- /* if this module is OOM, set a flag in the header to indicate this */
- DARSHAN_MOD_FLAG_SET(darshan_core->log_header.partial_flag, mod_id);
+ /* just give up and return if adding this record failed */
DARSHAN_CORE_UNLOCK();
return;
-#endif
- darshan_add_record_hashref(darshan_core, name, tmp_rec_id, &ref);
- if(ref)
+ if(!DARSHAN_MOD_FLAG_ISSET(ref->mod_flags, mod_id))
DARSHAN_MOD_FLAG_SET(ref->mod_flags, mod_id);
+ darshan_core->log_hdr_p->mod_map[mod_id].len += rec_size;
if(file_alignment)
darshan_block_size_from_path(name, file_alignment);
- *rec_id = 0; /* XXX */
+ *rec_id = tmp_rec_id;
return;
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -1677,7 +1677,6 @@ static struct posix_file_runtime* posix_file_by_name(const char *name)
char *newname = NULL;
darshan_record_id file_id;
int file_alignment;
- int limit_flag;
if(!posix_runtime || instrumentation_disabled)
return(NULL);
@@ -1686,15 +1685,13 @@ static struct posix_file_runtime* posix_file_by_name(const char *name)
if(!newname)
newname = (char*)name;
- limit_flag = (posix_runtime->file_array_ndx >= posix_runtime->file_array_size);
/* get a unique id for this file from darshan core */
(void*)newname,
strlen(newname),
+ sizeof(struct darshan_posix_file),
DARSHAN_POSIX_MOD,
1,
- limit_flag,
&file_id,
&file_alignment);
@@ -2364,7 +2361,7 @@ static void posix_shutdown()
HASH_CLEAR(hlink, posix_runtime->file_hash); /* these entries are freed all at once below */
free(posix_runtime->file_runtime_array);
- free(posix_runtime->file_record_array);
+ /* XXX: MMAP free(posix_runtime->file_record_array); */
free(posix_runtime);
posix_runtime = NULL;
--- a/darshan-util/darshan-parser.c
+++ b/darshan-util/darshan-parser.c
@@ -310,9 +310,9 @@ int main(int argc, char **argv)
/* print breakdown of each log file region's contribution to file size */
- printf("\n# log file region sizes (compressed)\n");
+ printf("\n# log file region sizes\n");
printf("# -------------------------------------------------------\n");
- printf("# header: %zu bytes (uncompressed)\n", sizeof(struct darshan_header));
+ printf("# header: %zu bytes\n", sizeof(struct darshan_header));
printf("# job data: %zu bytes\n", fd->job_map.len);
printf("# record table: %zu bytes\n", fd->rec_map.len);
for(i=0; i<DARSHAN_MAX_MODS; i++)
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/376eefa8c5e37064148de4ee1c3c5b85c8fd02ea
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20151204/a70bcf8e/attachment.html>
More information about the Darshan-commits
