[Darshan-commits] [Git][darshan/darshan][mmap-dev] 3 commits: runtime now stores mnt & exe data at all ranks
Shane Snyder xgitlab at cels.anl.gov
Mon Dec 7 13:27:57 CST 2015
Shane Snyder pushed to branch mmap-dev at darshan / darshan
Commits:
c9618c8a by Shane Snyder at 2015-12-04T13:52:19Z
4ac75905 by Shane Snyder at 2015-12-04T15:18:06Z
modify hash write routine to use new serialization
66a83b03 by Shane Snyder at 2015-12-07T13:25:52Z
first cut at the stitch logs utility
Currently, this tool can take a set of temporary, uncompressed log
files on a given node, and combine into a single darshan log.
Next step would be to modify this code to perform shared file
reduction logic to combine per-node log files into per-job log
files.
3 changed files:
- darshan-runtime/lib/darshan-core.c
- darshan-util/darshan-logutils.c
- darshan-util/darshan-stitch-logs.c
Changes:
--- a/darshan-runtime/lib/darshan-core.c
+++ b/darshan-runtime/lib/darshan-core.c
@@ -91,8 +91,6 @@ static int mnt_data_count = 0;
 /* prototypes for internal helper functions */
 static void darshan_log_record_hints_and_ver(
     struct darshan_core_runtime* core);
-static void darshan_get_exe_and_mounts_root(
-    struct darshan_core_runtime *core, int argc, char **argv);
 static void darshan_get_exe_and_mounts(
 static void darshan_block_size_from_path(
@@ -470,12 +468,12 @@ static void add_entry(char* buf, int* space_left, struct mntent *entry)
     return;
-/* darshan_get_exe_and_mounts_root()
+/* darshan_get_exe_and_mounts()
  * collects command line and list of mounted file systems into a string that
  * will be stored with the job-level metadata
-static void darshan_get_exe_and_mounts_root(struct darshan_core_runtime *core,
+static void darshan_get_exe_and_mounts(struct darshan_core_runtime *core,
     FILE* tab;
@@ -581,7 +579,7 @@ static void darshan_get_exe_and_mounts_root(struct darshan_core_runtime *core,
     endmntent(tab);
-    /* Sort mount points in order of longest path to shortest path.  This is
+    /* sort mount points in order of longest path to shortest path.  This is
      * necessary so that if we try to match file paths to mount points later
      * we don't match on "/" every time.
@@ -589,29 +587,6 @@ static void darshan_get_exe_and_mounts_root(struct darshan_core_runtime *core,
     return;
-/* darshan_get_exe_and_mounts()
- * collects command line and list of mounted file systems into a string that
- * will be stored with the job-level metadata
-static void darshan_get_exe_and_mounts(struct darshan_core_runtime *core,
-    int argc, char **argv)
-    if(my_rank == 0)
-        darshan_get_exe_and_mounts_root(core, argc, argv);
-    /* broadcast mount count to all nodes */
-    DARSHAN_MPI_CALL(PMPI_Bcast)(&mnt_data_count, 1, MPI_INT, 0,
-        MPI_COMM_WORLD);
-    /* broadcast mount data to all nodes */
-    DARSHAN_MPI_CALL(PMPI_Bcast)(mnt_data_array,
-        mnt_data_count*sizeof(mnt_data_array[0]), MPI_BYTE, 0, MPI_COMM_WORLD);
-    return;
 static void darshan_add_record_hashref(struct darshan_core_runtime *core,
     char *name, darshan_record_id id, struct darshan_core_record_ref **ref)
--- a/darshan-util/darshan-logutils.c
+++ b/darshan-util/darshan-logutils.c
@@ -638,13 +638,12 @@ int darshan_log_puthash(darshan_fd fd, struct darshan_record_ref *hash)
     int hash_buf_sz;
     struct darshan_record_ref *ref, *tmp;
     char *buf_ptr;
-    int path_len;
     int wrote;
     assert(state);
     /* allocate memory for largest possible hash record */
-    hash_buf_sz = sizeof(darshan_record_id) + sizeof(uint32_t) + PATH_MAX;
+    hash_buf_sz = sizeof(darshan_record_id) + PATH_MAX + 1;
     hash_buf = malloc(hash_buf_sz);
     if(!hash_buf)
         return(-1);
@@ -654,18 +653,15 @@ int darshan_log_puthash(darshan_fd fd, struct darshan_record_ref *hash)
     HASH_ITER(hlink, hash, ref, tmp)
         buf_ptr = hash_buf;
-        path_len = strlen(ref->rec.name);
         /* the hash buffer has space to serialize this record
          * NOTE: darshan record hash serialization method:
-         *          ... darshan_record_id | (uint32_t) path_len | path ...
+         *          ... darshan_record_id | path '\0' ...
         *((darshan_record_id *)buf_ptr) = ref->rec.id;
         buf_ptr += sizeof(darshan_record_id);
-        *((uint32_t *)buf_ptr) = path_len;
-        buf_ptr += sizeof(uint32_t);
-        memcpy(buf_ptr, ref->rec.name, path_len);
-        buf_ptr += path_len;
+        strcpy(buf_ptr, ref->rec.name);
+        buf_ptr += strlen(ref->rec.name) + 1;
         /* write this hash entry to log file */
         wrote = darshan_log_dzwrite(fd, DARSHAN_REC_MAP_REGION_ID,
--- a/darshan-util/darshan-stitch-logs.c
+++ b/darshan-util/darshan-stitch-logs.c
@@ -1,12 +1,13 @@
-#include <stdio.h>
+    #include <stdio.h>
 #include <stdlib.h>
 #include <fcntl.h>
 #include <glob.h>
 #include <string.h>
-#include <assert.h>
 #include "darshan-logutils.h"
+#define DEF_MOD_BUF_SIZE 1024 /* 1 KiB is enough for all current mod records ... */
 int logfile_path_comp(const void *a, const void *b)
     char *pathA = *(char **)a;
@@ -30,30 +31,30 @@ int logfile_path_comp(const void *a, const void *b)
 int main(int argc, char *argv[])
-    darshan_fd out_fd;
-    char *out_logname; /* XXX default + configurable? */
-    int ret;
-    int i, j;
     char *tmplog_dir;
     int job_id;
     glob_t globbuf;
     char glob_pstr[512];
-    int tmp_fd;
-    struct darshan_job in_job, out_job;
-    char in_exe_mnt[DARSHAN_EXE_LEN+1];
-    char *mnt_s, *pos;
-    char out_exe[DARSHAN_EXE_LEN+1];
-    char **out_mnt_pts;
-    char **out_fs_types;
-    int out_mnt_count = 0;
+    char *stitch_logname = "/tmp/test123.darshan"; /* XXX default + configurable? */
+    darshan_fd in_fd, stitch_fd;
+    struct darshan_job in_job, stitch_job;
+    char stitch_exe[DARSHAN_EXE_LEN+1];
+    char **stitch_mnt_pts;
+    char **stitch_fs_types;
+    int stitch_mnt_count = 0;
+    struct darshan_record_ref *in_hash = NULL;
+    struct darshan_record_ref *stitch_hash = NULL;
+    struct darshan_record_ref *ref, *tmp, *found;
+    darshan_record_id rec_id;
+    char *mod_buf;
+    int i, j;
+    int ret;
     /* TODO: are there any checks we should do to ensure tmp logs belong to the same job */
     /* we can't specifically check the job id, since the pid is used if no job scheduler */
     /* TODO: how do we set the output logfile name to be unique, and have necessary semantic info contained */
-    /* TODO: more thorough way of cleaning up (free, close, etc.) */
     if(argc != 3)
         fprintf(stderr, "Usage: ./darshan-stitch-tmplogs <tmp_dir> <job_id>\n"
@@ -83,235 +84,241 @@ int main(int argc, char *argv[])
     qsort(globbuf.gl_pathv, globbuf.gl_pathc, sizeof(char *), logfile_path_comp);
-    memset(&out_job, 0, sizeof(struct darshan_job));
+    memset(&stitch_job, 0, sizeof(struct darshan_job));
     /* first pass at stitching together logs:
-     *      - compose a final job-level metadata structure
+     *      - compose output job-level metadata structure (including exe & mount data)
+     *      - compose output record_id->file_name mapping
     for(i = 0; i < globbuf.gl_pathc; i++)
         memset(&in_job, 0, sizeof(struct darshan_job));
-        tmp_fd = open(globbuf.gl_pathv[i], O_RDONLY);
-        if(tmp_fd < 0)
+        in_fd = darshan_log_open(globbuf.gl_pathv[i]);
+        if(in_fd == NULL)
             fprintf(stderr,
-                "Error: unable to open Darshan log file %s.\n",
+                "Error: unable to open input Darshan log file %s.\n",
+            globfree(&globbuf);
             return(-1);
         /* read job-level metadata from the input file */
-        ret = pread(tmp_fd, &in_job, sizeof(struct darshan_job), 0);
-        if(ret < sizeof(struct darshan_job))
+        ret = darshan_log_getjob(in_fd, &in_job);
+        if(ret < 0)
             fprintf(stderr,
-                "Error: unable to read job data from Darshan log file %s\n",
+                "Error: unable to read job data from input Darshan log file %s.\n",
+            darshan_log_close(in_fd);
             return(-1);
         if(i == 0)
-            /* get all job data from the first input log */
-            memcpy(&out_job, &in_job, sizeof(struct darshan_job));
+            /* get job data, exe, & mounts directly from the first input log */
+            memcpy(&stitch_job, &in_job, sizeof(struct darshan_job));
-            ret = pread(tmp_fd, in_exe_mnt, DARSHAN_EXE_LEN+1, sizeof(struct darshan_job));
-            if(ret < DARSHAN_EXE_LEN+1)
+            ret = darshan_log_getexe(in_fd, stitch_exe);
+            if(ret < 0)
                 fprintf(stderr,
-                    "Error: unable to read exe & mount data from Darshan log file %s\n",
+                    "Error: unable to read exe string from Darshan log file %s.\n",
                 return(-1);
-            /* get the exe string */
-            mnt_s = strchr(in_exe_mnt, '\n');
-            memcpy(out_exe, in_exe_mnt, mnt_s-in_exe_mnt);
-            out_exe[mnt_s-in_exe_mnt] = '\0';
-            /* build mount structures */
-            pos = mnt_s;
-            while((pos = strchr(pos, '\n')) != NULL)
-                pos++;
-                out_mnt_count++;
-            if(out_mnt_count)
+            ret = darshan_log_getmounts(in_fd, &stitch_mnt_pts,
+                &stitch_fs_types, &stitch_mnt_count);
+            if(ret < 0)
-                out_mnt_pts = malloc(out_mnt_count * sizeof(char *));
-                assert(out_mnt_pts);
-                out_fs_types = malloc(out_mnt_count * sizeof(char *));
-                assert(out_fs_types);
-                /* work backwards through the table and parse each line (except for
-                 * first, which holds command line information)
-                j = 0;
-                while((pos = strrchr(in_exe_mnt, '\n')) != NULL)
-                    /* overestimate string lengths */
-                    out_mnt_pts[j] = malloc(DARSHAN_EXE_LEN);
-                    assert(out_mnt_pts[j]);
-                    out_fs_types[j] = malloc(DARSHAN_EXE_LEN);
-                    assert(out_fs_types[j]);
-                    ret = sscanf(++pos, "%s\t%s", out_fs_types[j], out_mnt_pts[j]);
-                    if(ret != 2)
-                        fprintf(stderr,
-                            "Error: poorly formatted mount table in darshan log file %s.\n",
-                            globbuf.gl_pathv[i]);
-                        return(-1);
-                    pos--;
-                    *pos = '\0';
-                    j++;
+                fprintf(stderr,
+                    "Error: unable to read mount info from Darshan log file %s.\n",
+                    globbuf.gl_pathv[i]);
+                return(-1);
         else
-            /* potentially update job timestamps */
-            if(in_job.start_time < out_job.start_time)
-                out_job.start_time = in_job.start_time;
-            if(in_job.end_time > out_job.end_time)
-                out_job.end_time = in_job.end_time;
+            /* potentially update job timestamps using remaining logs */
+            if(in_job.start_time < stitch_job.start_time)
+                stitch_job.start_time = in_job.start_time;
+            if(in_job.end_time > stitch_job.end_time)
+                stitch_job.end_time = in_job.end_time;
-        close(tmp_fd);
+        ret = darshan_log_gethash(in_fd, &in_hash);
+        if(ret < 0)
+            fprintf(stderr,
+            return(-1);
+        /* iterate the input hash, copying over record_id->file_name mappings
+         * that have not already been copied to the output hash
+        HASH_ITER(hlink, in_hash, ref, tmp)
+            HASH_FIND(hlink, stitch_hash, &(ref->rec.id),
+                sizeof(darshan_record_id), found);
+            if(!found)
+                HASH_ADD(hlink, stitch_hash, rec.id,
+                    sizeof(darshan_record_id), ref);
+            else if(strcmp(ref->rec.name, found->rec.name))
+                fprintf(stderr,
+                    "Error: invalid Darshan record table entry.\n");
+                return(-1);
     /* create the output "stitched together" log */
-    out_fd = darshan_log_create("/tmp/test123.darshan", DARSHAN_ZLIB_COMP, 1);
-    if(out_fd == NULL)
+    stitch_fd = darshan_log_create(stitch_logname, DARSHAN_ZLIB_COMP, 1);
+    if(stitch_fd == NULL)
         fprintf(stderr, "Error: unable to create output darshan log.\n");
         return(-1);
     /* write the darshan job info, exe string, and mount data to output file */
-    ret = darshan_log_putjob(out_fd, &out_job);
+    ret = darshan_log_putjob(stitch_fd, &stitch_job);
     if(ret < 0)
         fprintf(stderr, "Error: unable to write job data to output darshan log.\n");
+        darshan_log_close(stitch_fd);
+        unlink(stitch_logname);
         return(-1);
-    ret = darshan_log_putexe(out_fd, out_exe);
+    ret = darshan_log_putexe(stitch_fd, stitch_exe);
     if(ret < 0)
         fprintf(stderr, "Error: unable to write exe string to output darshan log.\n");
         return(-1);
-    ret = darshan_log_putmounts(out_fd, out_mnt_pts, out_fs_types, out_mnt_count);
+    ret = darshan_log_putmounts(stitch_fd, stitch_mnt_pts, stitch_fs_types, stitch_mnt_count);
     if(ret < 0)
         fprintf(stderr, "Error: unable to write mount data to output darshan log.\n");
         return(-1);
-    void *mod_buf = malloc(2*1024*1024);
-    assert(mod_buf);
+    /* write the stitched together table of records to output file */
+    ret = darshan_log_puthash(stitch_fd, stitch_hash);
+    if(ret < 0)
+        fprintf(stderr, "Error: unable to write record table to output darshan log.\n");
+        return(-1);
-    /* second pass at stitching together logs:
-     *      - append module data to output log file
-    for(i = 0; i < globbuf.gl_pathc; i++)
+    mod_buf = malloc(DEF_MOD_BUF_SIZE);
+    if(!mod_buf)
-        if(tmp_fd < 0)
+        return(-1);
+    memset(mod_buf, 0, DEF_MOD_BUF_SIZE);
+    for(i = 0; i < DARSHAN_MPIIO_MOD; i++)
+        if(!mod_logutils[i]) continue;
+#if 0
+        /* XXX first build shared record list? */
+        for(j = 0; j < globbuf.gl_pathc; j++)
-            fprintf(stderr,
-            return(-1);
-        ret = pread(tmp_fd, mod_buf, 2*1024*1024, 4*1024);
-        if(ret < (2*1024*1024))
+        /* XXX second aggregate shared records ? */
-            fprintf(stderr,
-                "Error: unable to read module data from Darshan log file %s\n",
-            return(-1);
+#endif
-        /* iterate and write file records */
-        void *mod_buf_p = mod_buf;
-        while(1)
+        /* XXX third write each rank's blobs, with rank 0 writing the shared ones ? */
-#if 0
-            ret = darshan_log_put_posix_file(out_fd, VOID*);
+            in_fd = darshan_log_open(globbuf.gl_pathv[j]);
+            if(in_fd == NULL)
+                fprintf(stderr,
+                    globbuf.gl_pathv[j]);
+                free(mod_buf);
+                return(-1);
+            /* loop over module records and write them to output file */
+            while((ret = mod_logutils[i]->log_get_record(in_fd, mod_buf, &rec_id)) == 1)
+                ret = mod_logutils[i]->log_put_record(stitch_fd, mod_buf);
+                if(ret < 0)
+                    fprintf(stderr,
+                        "Error: unable to write %s module record to output log file %s.\n",
+                        darshan_module_names[i], globbuf.gl_pathv[j]);
+                    free(mod_buf);
+                    return(-1);
             if(ret < 0)
                 fprintf(stderr,
-                    "Error: unable to write module record to output darshan log.\n");
+                    "Error: unable to read %s module record from input log file %s.\n",
+                free(mod_buf);
                 return(-1);
-#endif
-        close(tmp_fd);
-    darshan_log_close(out_fd);
-    free(mod_buf);
     globfree(&globbuf);
+    free(mod_buf);
     return(0);
-#if 0
-    /* print out job info to sanity check */
-    time_t tmp_time = 0;
-    char *token;
-    char *save;
-    char buffer[DARSHAN_JOB_METADATA_LEN];
-    #include <time.h>
-    printf("# exe: %s\n", out_exe);
-    printf("# uid: %" PRId64 "\n", out_job.uid);
-    printf("# jobid: %" PRId64 "\n", out_job.jobid);
-    printf("# start_time: %" PRId64 "\n", out_job.start_time);
-    tmp_time += out_job.start_time;
-    printf("# start_time_asci: %s", ctime(&tmp_time));
-    printf("# end_time: %" PRId64 "\n", out_job.end_time);
-    tmp_time = 0;
-    tmp_time += out_job.end_time;
-    printf("# end_time_asci: %s", ctime(&tmp_time));
-    printf("# nprocs: %" PRId64 "\n", out_job.nprocs);
-    printf("# run time: %" PRId64 "\n", out_job.end_time - out_job.start_time + 1);
-    for(token=strtok_r(out_job.metadata, "\n", &save);
-        token != NULL;
-        token=strtok_r(NULL, "\n", &save))
-        char *key;
-        char *value;
-        /* NOTE: we intentionally only split on the first = character.
-         * There may be additional = characters in the value portion
-         * (for example, when storing mpi-io hints).
-        strcpy(buffer, token);
-        key = buffer;
-        value = index(buffer, '=');
-        if(!value)
-            continue;
-        /* convert = to a null terminator to split key and value */
-        value[0] = '\0';
-        value++;
-        printf("# metadata: %s = %s\n", key, value);
-    /* print table of mounted file systems */
-    printf("\n# mounted file systems (mount point and fs type)\n");
-    printf("# -------------------------------------------------------\n");
-    for(j=0; j<out_mnt_count; j++)
-        printf("# mount entry:\t%s\t%s\n", out_mnt_pts[j], out_fs_types[j]);
-#endif
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/9193b34aaf7e9f9d1e5361dfb44667d14277f23f...66a83b0382dade07f600a43bf50707be39e63ef2
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20151207/1be2f532/attachment-0001.html>
More information about the Darshan-commits mailing list
