[Darshan-commits] [Darshan] branch, dev-modular, updated. darshan-2.3.1-91-g1e5a8cb
Service Account
git at mcs.anl.gov
Mon Apr 6 16:03:24 CDT 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
via 1e5a8cb74811c8d5beb93a3409617b3f5466c3f2 (commit)
from 13b92a1f8d0fc3f3e603424e1686cbbfab1b2282 (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit 1e5a8cb74811c8d5beb93a3409617b3f5466c3f2
Author: Phil Carns <carns at mcs.anl.gov>
Date: Mon Apr 6 17:02:46 2015 -0400
add mpiio parser
Summary of changes:
darshan-util/Makefile.in | 9 +-
darshan-util/darshan-mpiio-parser.c | 214 +++++++++++++++++++++++++++++++++++
2 files changed, 221 insertions(+), 2 deletions(-)
create mode 100644 darshan-util/darshan-mpiio-parser.c
Diff of changes:
diff --git a/darshan-util/Makefile.in b/darshan-util/Makefile.in
index c91a434..1f87ea9 100644
--- a/darshan-util/Makefile.in
+++ b/darshan-util/Makefile.in
@@ -1,4 +1,4 @@
-all: libdarshan-util.a darshan-posix-parser
+all: libdarshan-util.a darshan-posix-parser darshan-mpiio-parser
DESTDIR =
srcdir = @srcdir@
@@ -68,6 +68,10 @@ jenkins: util/bin/jenkins.o lookup3.o
darshan-posix-parser: darshan-posix-parser.c darshan-logutils.h darshan-posix-logutils.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-posix-log-format.h libdarshan-util.a | uthash-1.9.2
$(CC) $(CFLAGS) $(LDFLAGS) $^ -o $@ $(LIBS)
+darshan-mpiio-parser: darshan-mpiio-parser.c darshan-logutils.h darshan-mpiio-logutils.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-mpiio-log-format.h libdarshan-util.a | uthash-1.9.2
+ $(CC) $(CFLAGS) $(LDFLAGS) $^ -o $@ $(LIBS)
#darshan-parser: darshan-parser.c $(DARSHAN_LOG_FORMAT) darshan-logutils.h darshan-logutils.o | uthash-1.9.2
# $(CC) $(CFLAGS) $(LDFLAGS) $< darshan-logutils.o -o $@ $(LIBS)
@@ -101,6 +105,7 @@ install:: all
install -d $(pkgconfigdir)
# install -m 755 darshan-parser $(bindir)
install -m 755 darshan-posix-parser $(bindir)
+ install -m 755 darshan-mpiio-parser $(bindir)
# install -m 755 darshan-convert $(bindir)
# install -m 755 darshan-diff $(bindir)
# install -m 755 darshan-analyzer $(bindir)
@@ -123,7 +128,7 @@ endif
clean::
- rm -f *.o *.a darshan-posix-parser
+ rm -f *.o *.a darshan-posix-parser darshan-mpiio-parser
distclean:: clean
rm -f darshan-runtime-config.h aclocal.m4 autom4te.cache/* config.status config.log Makefile util/bin/darshan-job-summary.pl
diff --git a/darshan-util/darshan-mpiio-parser.c b/darshan-util/darshan-mpiio-parser.c
new file mode 100644
index 0000000..683194f
--- /dev/null
+++ b/darshan-util/darshan-mpiio-parser.c
@@ -0,0 +1,214 @@
+ * Copyright (C) 2015 University of Chicago.
+ * See COPYRIGHT notice in top-level directory.
+#include <stdio.h>
+#include <sys/types.h>
+#include <sys/stat.h>
+#include <fcntl.h>
+#include <unistd.h>
+#include <string.h>
+#include <zlib.h>
+#include <time.h>
+#include <stdlib.h>
+#include <getopt.h>
+#include <assert.h>
+#include "darshan-logutils.h"
+#include "darshan-mpiio-logutils.h"
+#include "uthash-1.9.2/src/uthash.h"
+int main(int argc, char **argv)
+ int ret;
+ int i;
+ char *filename;
+ char tmp_string[4096];
+ darshan_fd fd;
+ struct darshan_header header;
+ struct darshan_job job;
+ struct darshan_record_ref *rec_hash = NULL;
+ struct darshan_record_ref *ref;
+ int mount_count;
+ char** mnt_pts;
+ char** fs_types;
+ time_t tmp_time = 0;
+ char *token;
+ char *save;
+ char buffer[DARSHAN_JOB_METADATA_LEN];
+ struct darshan_mpiio_file next_file;
+ assert(argc == 2);
+ filename = argv[1];
+ struct stat sbuf;
+ stat(filename, &sbuf);
+ fd = darshan_log_open(filename, "r");
+ if(!fd)
+ fprintf(stderr, "darshan_log_open() failed to open %s\n.", filename);
+ return(-1);
+ /* TODO: some of this code should be shared or in a separate executable
+ * instead of repeated in each module parser
+ /* read darshan log header */
+ ret = darshan_log_getheader(fd, &header);
+ if(ret < 0)
+ fprintf(stderr, "darshan_log_getheader() failed to read log header.\n");
+ darshan_log_close(fd);
+ return(-1);
+ /* read darshan job info */
+ ret = darshan_log_getjob(fd, &job);
+ if(ret < 0)
+ fprintf(stderr, "darshan_log_getjob() failed to read job data.\n");
+ return(-1);
+ /* get the original command line for this job */
+ ret = darshan_log_getexe(fd, tmp_string);
+ if(ret < 0)
+ fprintf(stderr, "Error: unable to read trailing job information.\n");
+ return(-1);
+ /* print job summary */
+ printf("# darshan log version: %s\n", header.version_string);
+ printf("# size of MPIIO file statistics: %zu bytes\n", sizeof(struct darshan_mpiio_file));
+ printf("# size of job statistics: %zu bytes\n", sizeof(struct darshan_job));
+ printf("# exe: %s\n", tmp_string);
+ printf("# uid: %" PRId64 "\n", job.uid);
+ printf("# jobid: %" PRId64 "\n", job.jobid);
+ printf("# start_time: %" PRId64 "\n", job.start_time);
+ tmp_time += job.start_time;
+ printf("# start_time_asci: %s", ctime(&tmp_time));
+ printf("# end_time: %" PRId64 "\n", job.end_time);
+ tmp_time = 0;
+ tmp_time += job.end_time;
+ printf("# end_time_asci: %s", ctime(&tmp_time));
+ printf("# nprocs: %" PRId64 "\n", job.nprocs);
+ printf("# run time: %" PRId64 "\n", job.end_time - job.start_time + 1);
+ for(token=strtok_r(job.metadata, "\n", &save);
+ token != NULL;
+ token=strtok_r(NULL, "\n", &save))
+ char *key;
+ char *value;
+ /* NOTE: we intentionally only split on the first = character.
+ * There may be additional = characters in the value portion
+ * (for example, when storing mpi-io hints).
+ strcpy(buffer, token);
+ key = buffer;
+ value = index(buffer, '=');
+ if(!value)
+ continue;
+ /* convert = to a null terminator to split key and value */
+ value[0] = '\0';
+ value++;
+ printf("# metadata: %s = %s\n", key, value);
+ /* get the mount information for this log */
+ ret = darshan_log_getmounts(fd, &mnt_pts, &fs_types, &mount_count);
+ if(ret < 0)
+ fprintf(stderr, "darshan_log_getmounts() failed to read mount information.\n");
+ return(-1);
+ /* print table of mounted file systems */
+ printf("\n# mounted file systems (mount point and fs type)\n");
+ printf("# -------------------------------------------------------\n");
+ for(i=0; i<mount_count; i++)
+ printf("# mount entry:\t%s\t%s\n", mnt_pts[i], fs_types[i]);
+ /* read hash of darshan records */
+ ret = darshan_log_gethash(fd, &rec_hash);
+ if(ret < 0)
+ fprintf(stderr, "darshan_log_getmap() failed to read record map.\n");
+ return(-1);
+ /* end TODO */
+ printf("\n*** FILE RECORD DATA ***\n");
+ ret = darshan_log_get_mpiio_file(fd, &next_file);
+ if(ret < 0)
+ fprintf(stderr, "darshan_log_get_mpiio_file() failed to read next record.\n");
+ return(-1);
+ if(ret == 0)
+ printf("# no files opened.\n");
+ return(0);
+ /* loop over each stored MPIIO file record and print counters */
+ i = 1;
+ do
+ /* get the pathname for this record */
+ HASH_FIND(hlink, rec_hash, &next_file.f_id, sizeof(darshan_record_id), ref);
+ assert(ref);
+ printf("\tRecord %d: id=%"PRIu64" (path=%s, rank=%"PRId64")\n",
+ i, next_file.f_id, ref->rec.name, next_file.rank);
+ /* TODO: does it make sense to put these in a header or something?
+ * Down side of listing them here is ordering dependency between enum
+ * in header and names here.
+ printf(
+ "\t\tMPIIO_INDEP_OPENS:\t%"PRIu64"\n"
+ "\t\tMPIIO_COLL_OPENS:\t%"PRIu64"\n"
+ "\t\tMPIIO_HINTS:\t%"PRIu64"\n"
+ "\t\tMPIIO_F_META_TIME:\t%lf\n"
+ "\t\tMPIIO_F_OPEN_TIMESTAMP:\t%lf\n",
+ next_file.counters[DARSHAN_MPIIO_INDEP_OPENS],
+ next_file.counters[DARSHAN_MPIIO_COLL_OPENS],
+ next_file.counters[DARSHAN_MPIIO_HINTS],
+ next_file.fcounters[DARSHAN_MPIIO_F_META_TIME],
+ next_file.fcounters[DARSHAN_MPIIO_F_OPEN_TIMESTAMP]);
+ i++;
+ } while((ret = darshan_log_get_mpiio_file(fd, &next_file)) == 1);
+ /* free mount info */
+ free(mnt_pts[i]);
+ free(fs_types[i]);
+ if(mount_count > 0)
+ free(mnt_pts);
+ free(fs_types);
+ return(0);
hooks/post-receive
More information about the Darshan-commits
