[Darshan-commits] [Darshan] branch, dev-modular, updated. darshan-2.3.1-92-g37d5884
Service Account
git at mcs.anl.gov
Mon Apr 6 16:09:35 CDT 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
via 37d5884986e9d072d61cb94bef8885f2482019b0 (commit)
from 1e5a8cb74811c8d5beb93a3409617b3f5466c3f2 (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit 37d5884986e9d072d61cb94bef8885f2482019b0
Author: Phil Carns <carns at mcs.anl.gov>
Date: Mon Apr 6 17:09:29 2015 -0400
remove old code
Summary of changes:
darshan-runtime/lib/darshan-mpiio.c | 517 -----------------------------------
1 files changed, 0 insertions(+), 517 deletions(-)
Diff of changes:
diff --git a/darshan-runtime/lib/darshan-mpiio.c b/darshan-runtime/lib/darshan-mpiio.c
index ff67ee5..3487564 100644
--- a/darshan-runtime/lib/darshan-mpiio.c
+++ b/darshan-runtime/lib/darshan-mpiio.c
@@ -377,523 +377,6 @@ static struct mpiio_file_runtime* mpiio_file_by_name_setfh(const char* name, MPI
return(file);
-#if 0
-static struct posix_runtime_file* posix_file_by_name(const char *name);
-static struct posix_runtime_file* posix_file_by_name_setfd(const char* name, int fd);
-static struct posix_runtime_file* posix_file_by_fd(int fd);
-static void posix_file_close_fd(int fd);
-static void posix_prepare_for_reduction(darshan_record_id *shared_recs,
- int *shared_rec_count, void **send_buf, void **recv_buf, int *rec_size);
-static void posix_record_reduction_op(void* infile_v, void* inoutfile_v,
- int *len, MPI_Datatype *datatype);
-static void posix_get_output_data(void **buffer, int *size);
-static void posix_shutdown(void);
-#define POSIX_SET(__file, __counter, __value) do {\
- (__file)->file_record->counters[__counter] = __value; \
-} while(0)
-#define POSIX_F_SET(__file, __counter, __value) do {\
- (__file)->file_record->fcounters[__counter] = __value; \
-} while(0)
-#define POSIX_INC(__file, __counter, __value) do {\
- (__file)->file_record->counters[__counter] += __value; \
-} while(0)
-#define POSIX_F_INC(__file, __counter, __value) do {\
- (__file)->file_record->fcounters[__counter] += __value; \
-} while(0)
-#define POSIX_F_INC_NO_OVERLAP(__file, __tm1, __tm2, __last, __counter) do { \
- if(__tm1 > __last) \
- POSIX_F_INC(__file, __counter, (__tm2-__tm1)); \
- else \
- POSIX_F_INC(__file, __counter, (__tm2 - __last)); \
- if(__tm2 > __last) \
- __last = __tm2; \
-} while(0)
-#define POSIX_VALUE(__file, __counter) \
- ((__file)->file_record->counters[__counter])
-#define POSIX_F_VALUE(__file, __counter) \
- ((__file)->file_record->fcounters[__counter])
-#define POSIX_MAX(__file, __counter, __value) do {\
- if((__file)->file_record->counters[__counter] < __value) \
-} while(0)
-#define POSIX_RECORD_OPEN(__ret, __path, __mode, __stream_flag, __tm1, __tm2) do { \
- struct posix_runtime_file* file; \
- char* exclude; \
- int tmp_index = 0; \
- if(__ret < 0) break; \
- while((exclude = darshan_path_exclusions[tmp_index])) { \
- if(!(strncmp(exclude, __path, strlen(exclude)))) \
- break; \
- tmp_index++; \
- if(exclude) break; \
- file = posix_file_by_name_setfd(__path, __ret); \
- if(!file) break; \
- file->file_record->rank = my_rank; \
- if(__mode) \
- POSIX_SET(file, CP_MODE, __mode); \
- if(__stream_flag)\
- POSIX_INC(file, CP_POSIX_FOPENS, 1); \
- else \
- POSIX_INC(file, CP_POSIX_OPENS, 1); \
- if(POSIX_F_VALUE(file, CP_F_OPEN_TIMESTAMP) == 0) \
- POSIX_F_SET(file, CP_F_OPEN_TIMESTAMP, __tm1); \
-} while(0)
-int DARSHAN_DECL(open)(const char *path, int flags, ...)
- int mode = 0;
- int ret;
- double tm1, tm2;
- MAP_OR_FAIL(open);
- if(flags & O_CREAT)
- va_list arg;
- va_start(arg, flags);
- mode = va_arg(arg, int);
- va_end(arg);
- tm1 = darshan_core_wtime();
- ret = __real_open(path, flags, mode);
- tm2 = darshan_core_wtime();
- else
- ret = __real_open(path, flags);
- POSIX_LOCK();
- posix_runtime_initialize();
- POSIX_RECORD_OPEN(ret, path, mode, 0, tm1, tm2);
- POSIX_UNLOCK();
- return(ret);
-int DARSHAN_DECL(open64)(const char *path, int flags, ...)
- int mode = 0;
- int ret;
- double tm1, tm2;
- MAP_OR_FAIL(open64);
- va_list arg;
- va_end(arg);
- ret = __real_open64(path, flags, mode);
- else
- ret = __real_open64(path, flags);
- POSIX_LOCK();
- POSIX_UNLOCK();
- return(ret);
-int DARSHAN_DECL(close)(int fd)
- double tm1, tm2;
- int ret;
- MAP_OR_FAIL(close);
- ret = __real_close(fd);
- POSIX_LOCK();
- file = posix_file_by_fd(fd);
- if(file)
- POSIX_F_SET(file, CP_F_CLOSE_TIMESTAMP, darshan_core_wtime());
- posix_file_close_fd(fd);
- POSIX_UNLOCK();
- return(ret);
-static void posix_runtime_initialize()
- char *alignstr;
- int tmpval;
- int ret;
- int mem_limit;
- struct darshan_module_funcs posix_mod_fns =
- .disable_instrumentation = &posix_disable_instrumentation,
- .prepare_for_reduction = &posix_prepare_for_reduction,
- .record_reduction_op = &posix_record_reduction_op,
- .get_output_data = &posix_get_output_data,
- .shutdown = &posix_shutdown
- /* don't do anything if already initialized or instrumenation is disabled */
- if(posix_runtime || instrumentation_disabled)
- return;
- /* register the posix module with darshan core */
- darshan_core_register_module(
- DARSHAN_POSIX_MOD,
- &posix_mod_fns,
- &mem_limit);
- /* return if no memory assigned by darshan core */
- if(mem_limit == 0)
- return;
- posix_runtime = malloc(sizeof(*posix_runtime));
- if(!posix_runtime)
- return;
- memset(posix_runtime, 0, sizeof(*posix_runtime));
- /* set maximum number of file records according to max memory limit */
- /* NOTE: maximum number of records is based on the size of a posix file record */
- posix_runtime->file_array_size = mem_limit / sizeof(struct darshan_posix_file);
- posix_runtime->file_array_ndx = 0;
- /* allocate array of runtime file records */
- posix_runtime->file_runtime_array = malloc(posix_runtime->file_array_size *
- sizeof(struct posix_runtime_file));
- posix_runtime->file_record_array = malloc(posix_runtime->file_array_size *
- sizeof(struct darshan_posix_file));
- if(!posix_runtime->file_runtime_array || !posix_runtime->file_record_array)
- posix_runtime->file_array_size = 0;
- return;
- memset(posix_runtime->file_runtime_array, 0, posix_runtime->file_array_size *
- memset(posix_runtime->file_record_array, 0, posix_runtime->file_array_size *
- /* TODO: can we move this out of here? perhaps register_module returns rank? */
- DARSHAN_MPI_CALL(PMPI_Comm_rank)(MPI_COMM_WORLD, &my_rank);
- return;
- struct posix_runtime_file *file = NULL;
- char *newname = NULL;
- darshan_record_id file_id;
- if(!posix_runtime || instrumentation_disabled)
- return(NULL);
- newname = darshan_clean_file_path(name);
- if(!newname)
- newname = (char*)name;
- /* get a unique id for this file from darshan core */
- darshan_core_register_record(
- (void*)newname,
- strlen(newname),
- 1,
- &file_id,
- NULL);
- /* search the hash table for this file record, and return if found */
- HASH_FIND(hlink, posix_runtime->file_hash, &file_id, sizeof(darshan_record_id), file);
- if(file)
- if(newname != name)
- free(newname);
- return(file);
- if(posix_runtime->file_array_ndx < posix_runtime->file_array_size);
- /* no existing record, assign a new file record from the global array */
- file = &(posix_runtime->file_runtime_array[posix_runtime->file_array_ndx]);
- file->file_record = &(posix_runtime->file_record_array[posix_runtime->file_array_ndx]);
- file->file_record->f_id = file_id;
- /* add new record to file hash table */
- HASH_ADD(hlink, posix_runtime->file_hash, file_record->f_id, sizeof(darshan_record_id), file);
- posix_runtime->file_array_ndx++;
- free(newname);
- return(file);
- struct posix_runtime_file_ref* ref;
- return(NULL);
- /* find file record by name first */
- file = posix_file_by_name(name);
- if(!file)
- return(NULL);
- /* search hash table for existing file ref for this fd */
- HASH_FIND(hlink, posix_runtime->fd_hash, &fd, sizeof(int), ref);
- if(ref)
- /* we have a reference. Make sure it points to the correct file
- * and return it
- ref->file = file;
- return(file);
- /* if we hit this point, then we don't have a reference for this fd
- * in the table yet. Add it.
- ref = malloc(sizeof(*ref));
- if(!ref)
- return(NULL);
- memset(ref, 0, sizeof(*ref));
- ref->file = file;
- ref->fd = fd;
- HASH_ADD(hlink, posix_runtime->fd_hash, fd, sizeof(int), ref);
- return(file);
- return(NULL);
- if(ref)
- return(ref->file);
- return(NULL);
- return;
- /* search hash table for this fd */
- if(ref)
- /* we have a reference, delete it */
- HASH_DELETE(hlink, posix_runtime->fd_hash, ref);
- free(ref);
- return;
-static int posix_file_compare(const void* a, const void* b)
- const struct darshan_posix_file* f_a = a;
- const struct darshan_posix_file* f_b = b;
- if(f_a->rank < f_b->rank)
- return 1;
- if(f_a->rank > f_b->rank)
- return -1;
- return 0;
- darshan_record_id *shared_recs,
- void **send_buf,
- void **recv_buf,
- int *rec_size)
- struct posix_runtime_file *file;
- struct darshan_posix_file *tmp_array;
- int i;
- assert(posix_runtime);
- /* necessary initialization of shared records (e.g., change rank to -1) */
- for(i = 0; i < *shared_rec_count; i++)
- HASH_FIND(hlink, posix_runtime->file_hash, &shared_recs[i],
- sizeof(darshan_record_id), file);
- assert(file);
- /* TODO: any initialization before reduction */
- file->file_record->rank = -1;
- /* sort the array of files descending by rank so that we get all of the
- * shared files (marked by rank -1) in a contiguous portion at end
- * of the array
- qsort(posix_runtime->file_record_array, posix_runtime->file_array_ndx,
- sizeof(struct darshan_posix_file), posix_file_compare);
- /* make *send_buf point to the shared files at the end of sorted array */
- *send_buf =
- &(posix_runtime->file_record_array[posix_runtime->file_array_ndx-(*shared_rec_count)]);
- /* allocate memory for the reduction output on rank 0 */
- if(my_rank == 0)
- *recv_buf = malloc(*shared_rec_count * sizeof(struct darshan_posix_file));
- if(!(*recv_buf))
- return;
- *rec_size = sizeof(struct darshan_posix_file);
- /* TODO: cleaner way to do this? */
- if(my_rank == 0)
- posix_runtime->red_buf = *recv_buf;
- posix_runtime->shared_rec_count = *shared_rec_count;
- return;
- void* infile_v,
- void* inoutfile_v,
- int *len,
- MPI_Datatype *datatype)
- struct darshan_posix_file tmp_file;
- struct darshan_posix_file *infile = infile_v;
- struct darshan_posix_file *inoutfile = inoutfile_v;
- int i;
- for(i = 0; i < *len; i++)
- memset(&tmp_file, 0, sizeof(struct darshan_posix_file));
- tmp_file.f_id = infile->f_id;
- tmp_file.rank = -1;
- tmp_file.counters[CP_POSIX_OPENS] = infile->counters[CP_POSIX_OPENS] +
- inoutfile->counters[CP_POSIX_OPENS];
- if((infile->fcounters[CP_F_OPEN_TIMESTAMP] > inoutfile->fcounters[CP_F_OPEN_TIMESTAMP]) &&
- (inoutfile->fcounters[CP_F_OPEN_TIMESTAMP] > 0))
- tmp_file.fcounters[CP_F_OPEN_TIMESTAMP] = inoutfile->fcounters[CP_F_OPEN_TIMESTAMP];
- else
- tmp_file.fcounters[CP_F_OPEN_TIMESTAMP] = infile->fcounters[CP_F_OPEN_TIMESTAMP];
- if(infile->fcounters[CP_F_CLOSE_TIMESTAMP] > inoutfile->fcounters[CP_F_CLOSE_TIMESTAMP])
- tmp_file.fcounters[CP_F_CLOSE_TIMESTAMP] = infile->fcounters[CP_F_CLOSE_TIMESTAMP];
- else
- tmp_file.fcounters[CP_F_CLOSE_TIMESTAMP] = inoutfile->fcounters[CP_F_CLOSE_TIMESTAMP];
- /* update pointers */
- *inoutfile = tmp_file;
- inoutfile++;
- infile++;
- return;
- void **buffer,
- int *size)
- /* clean up reduction state */
- if(my_rank == 0)
- int tmp_ndx = posix_runtime->file_array_ndx - posix_runtime->shared_rec_count;
- memcpy(&(posix_runtime->file_record_array[tmp_ndx]), posix_runtime->red_buf,
- posix_runtime->shared_rec_count * sizeof(struct darshan_posix_file));
- free(posix_runtime->red_buf);
- else
- posix_runtime->file_array_ndx -= posix_runtime->shared_rec_count;
- *buffer = (void *)(posix_runtime->file_record_array);
- *size = posix_runtime->file_array_ndx * sizeof(struct darshan_posix_file);
- return;
-static void posix_shutdown()
- struct posix_runtime_file_ref *ref, *tmp;
- HASH_ITER(hlink, posix_runtime->fd_hash, ref, tmp)
- free(ref);
- HASH_CLEAR(hlink, posix_runtime->file_hash); /* these entries are freed all at once below */
- free(posix_runtime->file_runtime_array);
- free(posix_runtime->file_record_array);
- free(posix_runtime);
- posix_runtime = NULL;
- return;
-#endif
* Local variables:
* c-indent-level: 4
hooks/post-receive
More information about the Darshan-commits
