[Darshan-commits] [Darshan] branch, dev-modular, updated. darshan-2.3.1-90-g13b92a1
Service Account
git at mcs.anl.gov
Mon Apr 6 15:36:28 CDT 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
via 13b92a1f8d0fc3f3e603424e1686cbbfab1b2282 (commit)
from b70229e4c9d745170efca03084c3b3b244792eb5 (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit 13b92a1f8d0fc3f3e603424e1686cbbfab1b2282
Author: Shane Snyder <ssnyder at mcs.anl.gov>
Date: Mon Apr 6 15:36:11 2015 -0500
adding posix common access/stride counters
Summary of changes:
darshan-posix-log-format.h | 76 ++++-----
darshan-runtime/darshan.h | 23 +++
darshan-runtime/lib/darshan-posix.c | 321 +++++++++++++++++++++++++++++++----
darshan-util/darshan-posix-parser.c | 72 ++++++++
4 files changed, 420 insertions(+), 72 deletions(-)
Diff of changes:
diff --git a/darshan-posix-log-format.h b/darshan-posix-log-format.h
index 68f2ecf..23b5bf9 100644
--- a/darshan-posix-log-format.h
+++ b/darshan-posix-log-format.h
@@ -39,47 +39,45 @@ enum darshan_posix_indices
POSIX_FILE_ALIGNMENT, /* file alignment in bytes */
POSIX_MAX_READ_TIME_SIZE,
POSIX_MAX_WRITE_TIME_SIZE,
-#if 0
/* buckets */
- SIZE_READ_0_100, /* count of posix read size ranges */
- SIZE_READ_100_1K,
- SIZE_READ_1K_10K,
- SIZE_READ_10K_100K,
- SIZE_READ_100K_1M,
- SIZE_READ_1M_4M,
- SIZE_READ_4M_10M,
- SIZE_READ_10M_100M,
- SIZE_READ_100M_1G,
- SIZE_READ_1G_PLUS,
+ POSIX_SIZE_READ_0_100, /* count of posix read size ranges */
+ POSIX_SIZE_READ_100_1K,
+ POSIX_SIZE_READ_1K_10K,
+ POSIX_SIZE_READ_10K_100K,
+ POSIX_SIZE_READ_100K_1M,
+ POSIX_SIZE_READ_1M_4M,
+ POSIX_SIZE_READ_4M_10M,
+ POSIX_SIZE_READ_10M_100M,
+ POSIX_SIZE_READ_100M_1G,
+ POSIX_SIZE_READ_1G_PLUS,
/* buckets */
- SIZE_WRITE_0_100, /* count of posix write size ranges */
- SIZE_WRITE_100_1K,
- SIZE_WRITE_1K_10K,
- SIZE_WRITE_10K_100K,
- SIZE_WRITE_100K_1M,
- SIZE_WRITE_1M_4M,
- SIZE_WRITE_4M_10M,
- SIZE_WRITE_10M_100M,
- SIZE_WRITE_100M_1G,
- SIZE_WRITE_1G_PLUS,
- /* counters */
- STRIDE1_STRIDE, /* the four most frequently appearing strides */
- STRIDE2_STRIDE,
- STRIDE3_STRIDE,
- STRIDE4_STRIDE,
- STRIDE1_COUNT, /* count of each of the most frequent strides */
- STRIDE2_COUNT,
- STRIDE3_COUNT,
- STRIDE4_COUNT,
- ACCESS1_ACCESS, /* the four most frequently appearing access sizes */
- ACCESS2_ACCESS,
- ACCESS3_ACCESS,
- ACCESS4_ACCESS,
- ACCESS1_COUNT, /* count of each of the most frequent access sizes */
- ACCESS2_COUNT,
- ACCESS3_COUNT,
- ACCESS4_COUNT,
-#endif
+ POSIX_SIZE_WRITE_0_100, /* count of posix write size ranges */
+ POSIX_SIZE_WRITE_100_1K,
+ POSIX_SIZE_WRITE_1K_10K,
+ POSIX_SIZE_WRITE_10K_100K,
+ POSIX_SIZE_WRITE_100K_1M,
+ POSIX_SIZE_WRITE_1M_4M,
+ POSIX_SIZE_WRITE_4M_10M,
+ POSIX_SIZE_WRITE_10M_100M,
+ POSIX_SIZE_WRITE_100M_1G,
+ POSIX_SIZE_WRITE_1G_PLUS,
+ /* stride/access counters */
+ POSIX_STRIDE1_STRIDE, /* the four most frequently appearing strides */
+ POSIX_STRIDE2_STRIDE,
+ POSIX_STRIDE3_STRIDE,
+ POSIX_STRIDE4_STRIDE,
+ POSIX_STRIDE1_COUNT, /* count of each of the most frequent strides */
+ POSIX_STRIDE2_COUNT,
+ POSIX_STRIDE3_COUNT,
+ POSIX_STRIDE4_COUNT,
+ POSIX_ACCESS1_ACCESS, /* the four most frequently appearing access sizes */
+ POSIX_ACCESS2_ACCESS,
+ POSIX_ACCESS3_ACCESS,
+ POSIX_ACCESS4_ACCESS,
+ POSIX_ACCESS1_COUNT, /* count of each of the most frequent access sizes */
+ POSIX_ACCESS2_COUNT,
+ POSIX_ACCESS3_COUNT,
+ POSIX_ACCESS4_COUNT,
POSIX_FASTEST_RANK,
POSIX_FASTEST_RANK_BYTES,
POSIX_SLOWEST_RANK,
diff --git a/darshan-runtime/darshan.h b/darshan-runtime/darshan.h
index eff89b9..b9c7066 100644
--- a/darshan-runtime/darshan.h
+++ b/darshan-runtime/darshan.h
@@ -102,6 +102,29 @@
(__rec_p)->counters[__counter] = __value; \
} while(0)
+#define DARSHAN_BUCKET_INC(__rec_p, __counter_base, __value) do {\
+ if(__value < 101) \
+ (__rec_p)->counters[__counter_base] += 1; \
+ else if(__value < 1025) \
+ (__rec_p)->counters[__counter_base+1] += 1; \
+ else if(__value < 10241) \
+ (__rec_p)->counters[__counter_base+2] += 1; \
+ else if(__value < 102401) \
+ (__rec_p)->counters[__counter_base+3] += 1; \
+ else if(__value < 1048577) \
+ (__rec_p)->counters[__counter_base+4] += 1; \
+ else if(__value < 4194305) \
+ (__rec_p)->counters[__counter_base+5] += 1; \
+ else if(__value < 10485761) \
+ (__rec_p)->counters[__counter_base+6] += 1; \
+ else if(__value < 104857601) \
+ (__rec_p)->counters[__counter_base+7] += 1; \
+ else if(__value < 1073741825) \
+ (__rec_p)->counters[__counter_base+8] += 1; \
+ else \
+ (__rec_p)->counters[__counter_base+9] += 1; \
+} while(0)
/* module developers provide the following functions to darshan-core */
struct darshan_module_funcs
diff --git a/darshan-runtime/lib/darshan-posix.c b/darshan-runtime/lib/darshan-posix.c
index 2a97aff..a647f0e 100644
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -4,6 +4,9 @@
+#define _XOPEN_SOURCE 500
+#define _GNU_SOURCE
#include "darshan-runtime-config.h"
#include <stdio.h>
#include <unistd.h>
@@ -21,7 +24,6 @@
#include <assert.h>
#include <libgen.h>
#include <aio.h>
-#define __USE_GNU
#include <pthread.h>
#include "uthash.h"
@@ -35,6 +37,7 @@ typedef int64_t off64_t;
#define aiocb64 aiocb
#endif
+/* TODO: this probably shouldn't be here long term -- MPI symbols mess up LD_PRELOAD */
#ifdef DARSHAN_PRELOAD
extern double (*__real_PMPI_Comm_rank)(MPI_Comm comm, int *rank);
#endif
@@ -79,19 +82,11 @@ DARSHAN_FORWARD_DECL(fclose, int, (FILE *fp));
/* TODO aio */
/* TODO listio */
-static void posix_runtime_initialize(void);
-static struct posix_file_runtime* posix_file_by_name(const char *name);
-static struct posix_file_runtime* posix_file_by_name_setfd(const char* name, int fd);
-static struct posix_file_runtime* posix_file_by_fd(int fd);
-static void posix_file_close_fd(int fd);
-static void posix_disable_instrumentation(void);
-static void posix_prepare_for_reduction(darshan_record_id *shared_recs,
- int *shared_rec_count, void **send_buf, void **recv_buf, int *rec_size);
-static void posix_record_reduction_op(void* infile_v, void* inoutfile_v,
- int *len, MPI_Datatype *datatype);
-static void posix_get_output_data(void **buffer, int *size);
-static void posix_shutdown(void);
+/* maximum number of access sizes and stride sizes that darshan will track
+ * per file at runtime; at log time they will be reduced into the 4 most
+ * frequently occurring ones
+#define POSIX_MAX_ACCESS_COUNT_RUNTIME 32
enum posix_io_type
@@ -99,6 +94,18 @@ enum posix_io_type
POSIX_WRITE = 2,
+enum posix_counter_type
+ POSIX_COUNTER_ACCESS,
+ POSIX_COUNTER_STRIDE
+struct posix_access_counter
+ int64_t size;
+ int freq;
/* The posix_file_runtime structure maintains necessary runtime metadata
* for the POSIX file record (darshan_posix_file structure, defined in
* darshan-posix-log-format.h) pointed to by 'file_record'. This metadata
@@ -132,6 +139,10 @@ struct posix_file_runtime
double last_meta_end;
double last_read_end;
double last_write_end;
+ void* access_root;
+ int access_count;
+ void* stride_root;
+ int stride_count;
UT_hash_handle hlink;
@@ -187,9 +198,59 @@ static int instrumentation_disabled = 0;
static int my_rank = -1;
static int darshan_mem_alignment = 1;
+/* global variables for determining 4 most common accesses/strides */
+static struct posix_file_runtime* walker_file = NULL;
+static int walker_validx;
+static int walker_cntidx;
+static void posix_runtime_initialize(void);
+static struct posix_file_runtime* posix_file_by_name(const char *name);
+static struct posix_file_runtime* posix_file_by_name_setfd(const char* name, int fd);
+static struct posix_file_runtime* posix_file_by_fd(int fd);
+static void posix_file_close_fd(int fd);
+static void posix_access_counter(struct posix_file_runtime* file, ssize_t size,
+ enum posix_counter_type type);
+static void posix_access_walker(const void* nodep, const VISIT which, const int depth);
+static void posix_walk_file_accesses(void);
+static int posix_access_compare(const void* a_p, const void* b_p);
+static int posix_file_compare(const void* a, const void* b);
+static void posix_disable_instrumentation(void);
+static void posix_prepare_for_reduction(darshan_record_id *shared_recs,
+ int *shared_rec_count, void **send_buf, void **recv_buf, int *rec_size);
+static void posix_record_reduction_op(void* infile_v, void* inoutfile_v,
+ int *len, MPI_Datatype *datatype);
+static void posix_get_output_data(void **buffer, int *size);
+static void posix_shutdown(void);
#define POSIX_LOCK() pthread_mutex_lock(&posix_runtime_mutex)
#define POSIX_UNLOCK() pthread_mutex_unlock(&posix_runtime_mutex)
+#define POSIX_COMMON_COUNTER_INC(__rec_p, __value, __count, __validx, __cntidx) do {\
+ int i; \
+ int set = 0; \
+ int64_t min = DARSHAN_COUNTER_VALUE(__rec_p, __cntidx); \
+ int min_index = 0; \
+ if(__value == 0) break; \
+ for(i=0; i<4; i++) { \
+ /* increment bucket if already exists */ \
+ if(DARSHAN_COUNTER_VALUE(__rec_p, __validx + i) == __value) { \
+ DARSHAN_COUNTER_INC(__rec_p, __cntidx + i, __count); \
+ set = 1; \
+ break; \
+ /* otherwise find the least frequently used bucket */ \
+ else if(DARSHAN_COUNTER_VALUE(__rec_p, __cntidx + i) < min) { \
+ min = DARSHAN_COUNTER_VALUE(__rec_p, __cntidx + i); \
+ min_index = i; \
+ if(!set && (__count > min)) { \
+ DARSHAN_COUNTER_SET(__rec_p, __cntidx+min_index, __count); \
+ DARSHAN_COUNTER_SET(__rec_p, __validx+min_index, __value); \
+} while(0)
#define POSIX_RECORD_OPEN(__ret, __path, __mode, __stream_flag, __tm1, __tm2) do { \
struct posix_file_runtime* file; \
char* exclude; \
@@ -219,7 +280,7 @@ static int darshan_mem_alignment = 1;
} while(0)
#define POSIX_RECORD_READ(__ret, __fd, __pread_flag, __pread_offset, __aligned, __stream_flag, __tm1, __tm2) do{ \
- /* size_t stride; */\
+ size_t stride; \
int64_t this_offset; \
int64_t file_alignment; \
@@ -235,11 +296,11 @@ static int darshan_mem_alignment = 1;
DARSHAN_COUNTER_INC(file->file_record, POSIX_SEQ_READS, 1); \
if(this_offset == (file->last_byte_read + 1)) \
DARSHAN_COUNTER_INC(file->file_record, POSIX_CONSEC_READS, 1); \
- /* if(this_offset > 0 && this_offset > file->last_byte_read \
+ if(this_offset > 0 && this_offset > file->last_byte_read \
&& file->last_byte_read != 0) \
stride = this_offset - file->last_byte_read - 1; \
else \
- stride = 0; */\
+ stride = 0; \
file->last_byte_read = this_offset + __ret - 1; \
file->offset = this_offset + __ret; \
DARSHAN_COUNTER_MAX(file->file_record, POSIX_MAX_BYTE_READ, (this_offset + __ret - 1)); \
@@ -248,9 +309,9 @@ static int darshan_mem_alignment = 1;
DARSHAN_COUNTER_INC(file->file_record, POSIX_FREADS, 1); \
else\
DARSHAN_COUNTER_INC(file->file_record, POSIX_READS, 1); \
- /* CP_BUCKET_INC(file, CP_SIZE_READ_0_100, __ret); \
- cp_access_counter(file, __ret, CP_COUNTER_ACCESS); \
- cp_access_counter(file, stride, CP_COUNTER_STRIDE); */\
+ DARSHAN_BUCKET_INC(file->file_record, POSIX_SIZE_READ_0_100, __ret); \
+ posix_access_counter(file, __ret, POSIX_COUNTER_ACCESS); \
+ posix_access_counter(file, stride, POSIX_COUNTER_STRIDE); \
if(!__aligned) \
DARSHAN_COUNTER_INC(file->file_record, POSIX_MEM_NOT_ALIGNED, 1); \
file_alignment = DARSHAN_COUNTER_VALUE(file->file_record, POSIX_FILE_ALIGNMENT); \
@@ -269,7 +330,7 @@ static int darshan_mem_alignment = 1;
} while(0)
#define POSIX_RECORD_WRITE(__ret, __fd, __pwrite_flag, __pwrite_offset, __aligned, __stream_flag, __tm1, __tm2) do{ \
+ size_t stride; \
@@ -285,11 +346,11 @@ static int darshan_mem_alignment = 1;
DARSHAN_COUNTER_INC(file->file_record, POSIX_SEQ_WRITES, 1); \
if(this_offset == (file->last_byte_written + 1)) \
DARSHAN_COUNTER_INC(file->file_record, POSIX_CONSEC_WRITES, 1); \
- /* if(this_offset > 0 && this_offset > file->last_byte_written \
+ if(this_offset > 0 && this_offset > file->last_byte_written \
&& file->last_byte_written != 0) \
stride = this_offset - file->last_byte_written - 1; \
else \
- stride = 0; */\
+ stride = 0; \
file->last_byte_written = this_offset + __ret - 1; \
DARSHAN_COUNTER_MAX(file->file_record, POSIX_MAX_BYTE_WRITTEN, (this_offset + __ret - 1)); \
@@ -298,9 +359,9 @@ static int darshan_mem_alignment = 1;
DARSHAN_COUNTER_INC(file->file_record, POSIX_FWRITES, 1); \
else \
DARSHAN_COUNTER_INC(file->file_record, POSIX_WRITES, 1); \
- /* CP_BUCKET_INC(file, CP_SIZE_WRITE_0_100, __ret); \
- cp_access_counter(file, stride, CP_COUNTER_STRIDE); */ \
+ DARSHAN_BUCKET_INC(file->file_record, POSIX_SIZE_WRITE_0_100, __ret); \
if(!__aligned) \
@@ -1420,15 +1481,143 @@ static void posix_file_close_fd(int fd)
return;
+ struct posix_access_counter* counter;
+ struct posix_access_counter* found;
+ void* tmp;
+ void** root;
+ int* count;
+ struct posix_access_counter tmp_counter;
+ /* don't count sizes or strides of 0 */
+ if(size == 0)
+ return;
+ switch(type)
+ case POSIX_COUNTER_ACCESS:
+ root = &file->access_root;
+ count = &file->access_count;
+ break;
+ case POSIX_COUNTER_STRIDE:
+ root = &file->stride_root;
+ count = &file->stride_count;
+ break;
+ default:
+ return;
+ /* check to see if this size is already recorded */
+ tmp_counter.size = size;
+ tmp_counter.freq = 1;
+ tmp = tfind(&tmp_counter, root, posix_access_compare);
+ if(tmp)
+ found = *(struct posix_access_counter**)tmp;
+ found->freq++;
+ return;
+ /* we can add a new one as long as we haven't hit the limit */
+ if(*count < POSIX_MAX_ACCESS_COUNT_RUNTIME)
+ counter = malloc(sizeof(*counter));
+ if(!counter)
+ return;
+ counter->size = size;
+ counter->freq = 1;
+ tmp = tsearch(counter, root, posix_access_compare);
+ /* if we get a new answer out here we are in trouble; this was
+ * already checked with the tfind()
+ assert(found == counter);
+ (*count)++;
+ return;
+ switch (which)
+ case postorder:
+ case leaf:
+ counter = *(struct posix_access_counter**)nodep;
+ POSIX_COMMON_COUNTER_INC(walker_file->file_record, counter->size, counter->freq,
+ walker_validx, walker_cntidx);
+ default:
+ break;
+ return;
+/* posix_walk_file_accesses()
+ * goes through runtime collections of accesses sizes and chooses the 4 most
+ * common for logging
+static void posix_walk_file_accesses()
+ int i;
+ for(i=0; i<posix_runtime->file_array_ndx; i++)
+ /* walk trees for both access sizes and stride sizes to pick 4 most
+ * common of each
+ /* NOTE: setting global variables here for cp_access_walker() */
+ walker_file = &posix_runtime->file_runtime_array[i];
+ walker_validx = POSIX_ACCESS1_ACCESS;
+ walker_cntidx = POSIX_ACCESS1_COUNT;
+ twalk(walker_file->access_root,
+ posix_access_walker);
+ tdestroy(walker_file->access_root, free);
+ walker_validx = POSIX_STRIDE1_STRIDE;
+ walker_cntidx = POSIX_STRIDE1_COUNT;
+ twalk(walker_file->stride_root,
+ tdestroy(walker_file->stride_root, free);
+ return;
+ const struct posix_access_counter* a = a_p;
+ const struct posix_access_counter* b = b_p;
+ if(a->size < b->size)
+ return(-1);
+ if(a->size > b->size)
+ return(1);
+ return(0);
/* compare function for sorting file records by descending rank */
-static int posix_file_compare(const void* a, const void* b)
+static int posix_file_compare(const void* a_p, const void* b_p)
- const struct darshan_posix_file* f_a = a;
- const struct darshan_posix_file* f_b = b;
+ const struct darshan_posix_file* a = a_p;
+ const struct darshan_posix_file* b = b_p;
- if(f_a->rank < f_b->rank)
+ if(a->rank < b->rank)
return 1;
- if(f_a->rank > f_b->rank)
+ if(a->rank > b->rank)
return -1;
return 0;
@@ -1443,6 +1632,9 @@ static void posix_disable_instrumentation()
assert(posix_runtime);
POSIX_LOCK();
+ posix_walk_file_accesses();
instrumentation_disabled = 1;
POSIX_UNLOCK();
@@ -1535,8 +1727,7 @@ static void posix_record_reduction_op(
struct darshan_posix_file tmp_file;
struct darshan_posix_file *infile = infile_v;
struct darshan_posix_file *inoutfile = inoutfile_v;
- int i;
- int j;
+ int i, j, k;
@@ -1587,6 +1778,70 @@ static void posix_record_reduction_op(
inoutfile->counters[j];
+ /* skip POSIX_MAX_*_TIME_SIZE; handled in floating point section */
+ for(j=POSIX_SIZE_READ_0_100; j<=POSIX_SIZE_WRITE_1G_PLUS; j++)
+ tmp_file.counters[j] = infile->counters[j] +
+ inoutfile->counters[j];
+ /* first collapse any duplicates */
+ for(j=POSIX_STRIDE1_STRIDE; j<=POSIX_STRIDE4_STRIDE; j++)
+ for(k=POSIX_STRIDE1_STRIDE; k<=POSIX_STRIDE4_STRIDE; k++)
+ if(infile->counters[j] == inoutfile->counters[k])
+ infile->counters[j+4] += inoutfile->counters[k+4];
+ inoutfile->counters[k] = 0;
+ inoutfile->counters[k+4] = 0;
+ /* first set */
+ POSIX_COMMON_COUNTER_INC(&tmp_file, infile->counters[j],
+ infile->counters[j+4], POSIX_STRIDE1_STRIDE, POSIX_STRIDE1_COUNT);
+ /* second set */
+ POSIX_COMMON_COUNTER_INC(&tmp_file, inoutfile->counters[j],
+ inoutfile->counters[j+4], POSIX_STRIDE1_STRIDE, POSIX_STRIDE1_COUNT);
+ /* same for access counts */
+ for(j=POSIX_ACCESS1_ACCESS; j<=POSIX_ACCESS4_ACCESS; j++)
+ for(k=POSIX_ACCESS1_ACCESS; k<=POSIX_ACCESS4_ACCESS; k++)
+ /* first set */
+ infile->counters[j+4], POSIX_ACCESS1_ACCESS, POSIX_ACCESS1_COUNT);
+ /* second set */
+ inoutfile->counters[j+4], POSIX_ACCESS1_ACCESS, POSIX_ACCESS1_COUNT);
/* min non-zero (if available) value */
for(j=POSIX_F_OPEN_TIMESTAMP; j<=POSIX_F_WRITE_START_TIMESTAMP; j++)
diff --git a/darshan-util/darshan-posix-parser.c b/darshan-util/darshan-posix-parser.c
index 1a9638c..9c9dbd0 100644
--- a/darshan-util/darshan-posix-parser.c
+++ b/darshan-util/darshan-posix-parser.c
@@ -198,6 +198,42 @@ int main(int argc, char **argv)
"\t\tPOSIX_FILE_ALIGNMENT:\t%"PRIu64"\n"
"\t\tPOSIX_MAX_READ_TIME_SIZE:\t%"PRIu64"\n"
"\t\tPOSIX_MAX_WRITE_TIME_SIZE:\t%"PRIu64"\n"
+ "\t\tPOSIX_SIZE_READ_0_100:\t%"PRIu64"\n"
+ "\t\tPOSIX_SIZE_READ_100_1K:\t%"PRIu64"\n"
+ "\t\tPOSIX_SIZE_READ_1K_10K:\t%"PRIu64"\n"
+ "\t\tPOSIX_SIZE_READ_10K_100K:\t%"PRIu64"\n"
+ "\t\tPOSIX_SIZE_READ_100K_1M:\t%"PRIu64"\n"
+ "\t\tPOSIX_SIZE_READ_1M_4M:\t%"PRIu64"\n"
+ "\t\tPOSIX_SIZE_READ_4M_10M:\t%"PRIu64"\n"
+ "\t\tPOSIX_SIZE_READ_10M_100M:\t%"PRIu64"\n"
+ "\t\tPOSIX_SIZE_READ_100M_1G:\t%"PRIu64"\n"
+ "\t\tPOSIX_SIZE_READ_1G_PLUS:\t%"PRIu64"\n"
+ "\t\tPOSIX_SIZE_WRITE_0_100:\t%"PRIu64"\n"
+ "\t\tPOSIX_SIZE_WRITE_100_1K:\t%"PRIu64"\n"
+ "\t\tPOSIX_SIZE_WRITE_1K_10K:\t%"PRIu64"\n"
+ "\t\tPOSIX_SIZE_WRITE_10K_100K:\t%"PRIu64"\n"
+ "\t\tPOSIX_SIZE_WRITE_100K_1M:\t%"PRIu64"\n"
+ "\t\tPOSIX_SIZE_WRITE_1M_4M:\t%"PRIu64"\n"
+ "\t\tPOSIX_SIZE_WRITE_4M_10M:\t%"PRIu64"\n"
+ "\t\tPOSIX_SIZE_WRITE_10M_100M:\t%"PRIu64"\n"
+ "\t\tPOSIX_SIZE_WRITE_100M_1G:\t%"PRIu64"\n"
+ "\t\tPOSIX_SIZE_WRITE_1G_PLUS:\t%"PRIu64"\n"
+ "\t\tPOSIX_STRIDE1_STRIDE:\t%"PRIu64"\n"
+ "\t\tPOSIX_STRIDE2_STRIDE:\t%"PRIu64"\n"
+ "\t\tPOSIX_STRIDE3_STRIDE:\t%"PRIu64"\n"
+ "\t\tPOSIX_STRIDE4_STRIDE:\t%"PRIu64"\n"
+ "\t\tPOSIX_STRIDE1_COUNT:\t%"PRIu64"\n"
+ "\t\tPOSIX_STRIDE2_COUNT:\t%"PRIu64"\n"
+ "\t\tPOSIX_STRIDE3_COUNT:\t%"PRIu64"\n"
+ "\t\tPOSIX_STRIDE4_COUNT:\t%"PRIu64"\n"
+ "\t\tPOSIX_ACCESS1_ACCESS:\t%"PRIu64"\n"
+ "\t\tPOSIX_ACCESS2_ACCESS:\t%"PRIu64"\n"
+ "\t\tPOSIX_ACCESS3_ACCESS:\t%"PRIu64"\n"
+ "\t\tPOSIX_ACCESS4_ACCESS:\t%"PRIu64"\n"
+ "\t\tPOSIX_ACCESS1_COUNT:\t%"PRIu64"\n"
+ "\t\tPOSIX_ACCESS2_COUNT:\t%"PRIu64"\n"
+ "\t\tPOSIX_ACCESS3_COUNT:\t%"PRIu64"\n"
+ "\t\tPOSIX_ACCESS4_COUNT:\t%"PRIu64"\n"
"\t\tPOSIX_FASTEST_RANK:\t%"PRIu64"\n"
"\t\tPOSIX_FASTEST_RANK_BYTES:\t%"PRIu64"\n"
"\t\tPOSIX_SLOWEST_RANK:\t%"PRIu64"\n"
@@ -243,6 +279,42 @@ int main(int argc, char **argv)
next_file.counters[POSIX_FILE_ALIGNMENT],
next_file.counters[POSIX_MAX_READ_TIME_SIZE],
next_file.counters[POSIX_MAX_WRITE_TIME_SIZE],
+ next_file.counters[POSIX_SIZE_READ_0_100],
+ next_file.counters[POSIX_SIZE_READ_100_1K],
+ next_file.counters[POSIX_SIZE_READ_1K_10K],
+ next_file.counters[POSIX_SIZE_READ_10K_100K],
+ next_file.counters[POSIX_SIZE_READ_100K_1M],
+ next_file.counters[POSIX_SIZE_READ_1M_4M],
+ next_file.counters[POSIX_SIZE_READ_4M_10M],
+ next_file.counters[POSIX_SIZE_READ_10M_100M],
+ next_file.counters[POSIX_SIZE_READ_100M_1G],
+ next_file.counters[POSIX_SIZE_READ_1G_PLUS],
+ next_file.counters[POSIX_SIZE_WRITE_0_100],
+ next_file.counters[POSIX_SIZE_WRITE_100_1K],
+ next_file.counters[POSIX_SIZE_WRITE_1K_10K],
+ next_file.counters[POSIX_SIZE_WRITE_10K_100K],
+ next_file.counters[POSIX_SIZE_WRITE_100K_1M],
+ next_file.counters[POSIX_SIZE_WRITE_1M_4M],
+ next_file.counters[POSIX_SIZE_WRITE_4M_10M],
+ next_file.counters[POSIX_SIZE_WRITE_10M_100M],
+ next_file.counters[POSIX_SIZE_WRITE_100M_1G],
+ next_file.counters[POSIX_SIZE_WRITE_1G_PLUS],
+ next_file.counters[POSIX_STRIDE1_STRIDE],
+ next_file.counters[POSIX_STRIDE2_STRIDE],
+ next_file.counters[POSIX_STRIDE3_STRIDE],
+ next_file.counters[POSIX_STRIDE4_STRIDE],
+ next_file.counters[POSIX_STRIDE1_COUNT],
+ next_file.counters[POSIX_STRIDE2_COUNT],
+ next_file.counters[POSIX_STRIDE3_COUNT],
+ next_file.counters[POSIX_STRIDE4_COUNT],
+ next_file.counters[POSIX_ACCESS1_ACCESS],
+ next_file.counters[POSIX_ACCESS2_ACCESS],
+ next_file.counters[POSIX_ACCESS3_ACCESS],
+ next_file.counters[POSIX_ACCESS4_ACCESS],
+ next_file.counters[POSIX_ACCESS1_COUNT],
+ next_file.counters[POSIX_ACCESS2_COUNT],
+ next_file.counters[POSIX_ACCESS3_COUNT],
+ next_file.counters[POSIX_ACCESS4_COUNT],
next_file.counters[POSIX_FASTEST_RANK],
next_file.counters[POSIX_FASTEST_RANK_BYTES],
next_file.counters[POSIX_SLOWEST_RANK],
hooks/post-receive
More information about the Darshan-commits
