[Cookie-users] icc license problem
Boyana Norris norris at mcs.anl.gov
Wed Sep 30 06:48:10 CDT 2009
Albert,
Make sure you use the settings in /disks/soft/.common.bash
or .common.cshrc -- the license server changed recently.
Boyana
Boyana Norris, Computer Scientist, Argonne National Laboratory
norris at mcs.anl.gov, +1.630.252.7908, http://www.mcs.anl.gov/~norris/
On Sep 29, 2009, at 9:54 PM, Albert Hartono wrote:
> Hello,
> I suddenly received the following error when running Intel C compiler.
> Thanks,
> --Albert
> % icc
> Error: A license for CCompL is not available now (-96,482).
> A connection to the license server could not be made.  You should
> make sure that your license daemon process is running: both an
> lmgrd.intel process and an INTEL process should be running
> if your license limits you to a specified number of licenses in use
> at a time.  Also, check to see if the wrong port at host or the wrong
> license file is being used, or if the port or hostname in the license
> file has changed.
> License file(s) used were (in this order):
>    1.  /disks/large/soft/intel/cce/10.1.018/licenses/*.lic
>    2.  /opt/intel/licenses/514213548_USE_SERVER.lic
>    3.  /opt/intel/licenses/802951607_USE_SERVER.lic
>    4.  /opt/intel/licenses/97648560_USE_SERVER.lic
>    5.  /opt/intel/licenses/USE_SERVER.lic
>    6.  /opt/intel/licenses/l_vt_comFG4F4P5F.lic
>    7.  /homes/hartono/intel/licenses
>    8.  /Users/Shared/Library/Application Support/Intel/Licenses
>    9.  /disks/large/soft/intel/cce/10.1.018/bin/*.lic
> Please visit http://support.intel.com/support/performancetools/support.htm
> if you require technical assistance.
> icc: error #10052: could not checkout FLEXlm license
> Cookie-users mailing list
> Cookie-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/cookie-users
More information about the Cookie-users mailing list
