[Cookie-users] icc license problem
Van Bui coscbui at gmail.com
Tue Sep 29 23:08:50 CDT 2009
We may need to ask Rick to update it for us manually since we don't use the
soft environment on cookie.
Van
On Tue, Sep 29, 2009 at 10:58 PM, Sri Hari Krishna Narayanan <
snarayan at mcs.anl.gov> wrote:
> Hi Albert,
> Here is a snippet of a mail Rick Bradshaw sent out :
> This is just a heads up for those of you using commercial software on
> our Linux machines. If you have trouble getting a license today all
> you will have to do is update your environment, which should just be
> running "resoft"
> Hope this solves the issues.
> Krishna
> On Sep 29, 2009, at 9:54 PM, Albert Hartono wrote:
>  Hello,
>> I suddenly received the following error when running Intel C compiler.
>> Thanks,
>> --Albert
>> % icc
>> Error: A license for CCompL is not available now (-96,482).
>> A connection to the license server could not be made.  You should
>> make sure that your license daemon process is running: both an
>> lmgrd.intel process and an INTEL process should be running
>> if your license limits you to a specified number of licenses in use
>> at a time.  Also, check to see if the wrong port at host or the wrong
>> license file is being used, or if the port or hostname in the license
>> file has changed.
>> License file(s) used were (in this order):
>>    1.  /disks/large/soft/intel/cce/10.1.018/licenses/*.lic
>>    2.  /opt/intel/licenses/514213548_USE_SERVER.lic
>>    3.  /opt/intel/licenses/802951607_USE_SERVER.lic
>>    4.  /opt/intel/licenses/97648560_USE_SERVER.lic
>>    5.  /opt/intel/licenses/USE_SERVER.lic
>>    6.  /opt/intel/licenses/l_vt_comFG4F4P5F.lic
>>    7.  /homes/hartono/intel/licenses
>>    8.  /Users/Shared/Library/Application Support/Intel/Licenses
>>    9.  /disks/large/soft/intel/cce/10.1.018/bin/*.lic
>> Please visit http://support.intel.com/support/performancetools/
>> support.htm
>> if you require technical assistance.
>> icc: error #10052: could not checkout FLEXlm license
>> Cookie-users mailing list
>> Cookie-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/cookie-users
URL: <http://lists.mcs.anl.gov/pipermail/cookie-users/attachments/20090929/7cef9676/attachment.htm>
More information about the Cookie-users mailing list
