[Cookie-users] icc license problem
Boyana Norris
norris at mcs.anl.gov
Wed Sep 30 06:33:04 CDT 2009
I'm not sure what the problem is, but right now I get no errors when
icc, perhaps there was something wrong with the license server. It is
extremely slow, however, so I'll email Rick to ask about that.
Boyana
Boyana Norris, Computer Scientist, Argonne National Laboratory
norris at mcs.anl.gov, +1.630.252.7908, http://www.mcs.anl.gov/~norris/
On Sep 30, 2009, at 6:18 AM, Boyana Norris wrote:
> I am copying the latest version of the compilers to cookie, too, v.
> 10.1 worked fine for me over the weekend. The only recent change
> (last week) I was aware of is the license file (and server), which I
> updated several days ago. I'll ask Rick what changed today since it
> obviously is not the license server. It may be that they
> specifically exclude cookie in some way.
> Boyana
> On Sep 29, 2009, at 11:08 PM, Van Bui wrote:
>> We may need to ask Rick to update it for us manually since we don't
>> use the soft environment on cookie.
>> Van
>> On Tue, Sep 29, 2009 at 10:58 PM, Sri Hari Krishna Narayanan <snarayan at mcs.anl.gov
>> > wrote:
>> Hi Albert,
>> Here is a snippet of a mail Rick Bradshaw sent out :
>> This is just a heads up for those of you using commercial software on
>> our Linux machines. If you have trouble getting a license today all
>> you will have to do is update your environment, which should just be
>> running "resoft"
>> Hope this solves the issues.
>> Krishna
>> On Sep 29, 2009, at 9:54 PM, Albert Hartono wrote:
>> Hello,
>> I suddenly received the following error when running Intel C
>> compiler.
>> Thanks,
>> --Albert
>> % icc
>> Error: A license for CCompL is not available now (-96,482).
>> A connection to the license server could not be made. You should
>> make sure that your license daemon process is running: both an
>> lmgrd.intel process and an INTEL process should be running
>> if your license limits you to a specified number of licenses in use
>> at a time. Also, check to see if the wrong port at host or the wrong
>> license file is being used, or if the port or hostname in the license
>> file has changed.
>> License file(s) used were (in this order):
>> 1. /disks/large/soft/intel/cce/10.1.018/licenses/*.lic
>> 2. /opt/intel/licenses/514213548_USE_SERVER.lic
>> 3. /opt/intel/licenses/802951607_USE_SERVER.lic
>> 4. /opt/intel/licenses/97648560_USE_SERVER.lic
>> 5. /opt/intel/licenses/USE_SERVER.lic
>> 6. /opt/intel/licenses/l_vt_comFG4F4P5F.lic
>> 7. /homes/hartono/intel/licenses
>> 8. /Users/Shared/Library/Application Support/Intel/Licenses
>> 9. /disks/large/soft/intel/cce/10.1.018/bin/*.lic
>> Please visit http://support.intel.com/support/performancetools/support.htm
>> if you require technical assistance.
>> icc: error #10052: could not checkout FLEXlm license
>> Cookie-users mailing list
>> Cookie-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/cookie-users
URL: <http://lists.mcs.anl.gov/pipermail/cookie-users/attachments/20090930/f1054427/attachment-0001.htm>
More information about the Cookie-users
