[Cookie-users] icc license problem
Sri Hari Krishna Narayanan
snarayan at mcs.anl.gov
Tue Sep 29 22:58:24 CDT 2009
Hi Albert,
Here is a snippet of a mail Rick Bradshaw sent out :
This is just a heads up for those of you using commercial software on
our Linux machines. If you have trouble getting a license today all
you will have to do is update your environment, which should just be
running "resoft"
Hope this solves the issues.
Krishna
On Sep 29, 2009, at 9:54 PM, Albert Hartono wrote:
> Hello,
> I suddenly received the following error when running Intel C compiler.
> Thanks,
> --Albert
> % icc
> Error: A license for CCompL is not available now (-96,482).
> A connection to the license server could not be made. You should
> make sure that your license daemon process is running: both an
> lmgrd.intel process and an INTEL process should be running
> if your license limits you to a specified number of licenses in use
> at a time. Also, check to see if the wrong port at host or the wrong
> license file is being used, or if the port or hostname in the license
> file has changed.
> License file(s) used were (in this order):
> 1. /disks/large/soft/intel/cce/10.1.018/licenses/*.lic
> 2. /opt/intel/licenses/514213548_USE_SERVER.lic
> 3. /opt/intel/licenses/802951607_USE_SERVER.lic
> 4. /opt/intel/licenses/97648560_USE_SERVER.lic
> 5. /opt/intel/licenses/USE_SERVER.lic
> 6. /opt/intel/licenses/l_vt_comFG4F4P5F.lic
> 7. /homes/hartono/intel/licenses
> 8. /Users/Shared/Library/Application Support/Intel/Licenses
> 9. /disks/large/soft/intel/cce/10.1.018/bin/*.lic
> Please visit http://support.intel.com/support/performancetools/
> support.htm
> if you require technical assistance.
> icc: error #10052: could not checkout FLEXlm license
> Cookie-users mailing list
> Cookie-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/cookie-users
More information about the Cookie-users
