[Cookie-users] icc license problem
Albert Hartono albert.hartono at gmail.com
Tue Sep 29 21:54:49 CDT 2009
Hello,
I suddenly received the following error when running Intel C compiler.
--Albert
% icc
Error: A license for CCompL is not available now (-96,482).
A connection to the license server could not be made.  You should
make sure that your license daemon process is running: both an
lmgrd.intel process and an INTEL process should be running
if your license limits you to a specified number of licenses in use
at a time.  Also, check to see if the wrong port at host or the wrong
license file is being used, or if the port or hostname in the license
file has changed.
License file(s) used were (in this order):
    1.  /disks/large/soft/intel/cce/10.1.018/licenses/*.lic
    2.  /opt/intel/licenses/514213548_USE_SERVER.lic
    3.  /opt/intel/licenses/802951607_USE_SERVER.lic
    4.  /opt/intel/licenses/97648560_USE_SERVER.lic
    5.  /opt/intel/licenses/USE_SERVER.lic
    6.  /opt/intel/licenses/l_vt_comFG4F4P5F.lic
    7.  /homes/hartono/intel/licenses
    8.  /Users/Shared/Library/Application Support/Intel/Licenses
    9.  /disks/large/soft/intel/cce/10.1.018/bin/*.lic
Please visit http://support.intel.com/support/performancetools/support.htm
if you require technical assistance.
icc: error #10052: could not checkout FLEXlm license
More information about the Cookie-users mailing list
