[Cookie-users] Using PAPI on Cookie
Van Bui coscbui at gmail.com
Wed May 6 14:49:34 CDT 2009
Hi Albert,
There can also be internal hardware conflicts with using too many memory
counters in a single run. I often have to try out different sets of counters
that can be counted together in a single run.
Other performance tools on the system that can also access the PAPI counters
include PerfSuite and TAU.
/disks/large/soft/tau-2.18
/disks/large/soft/perfsuite-0.6.2b3
I have not tried using PAPI directly, but that is of course another option.
Let me know if you have any questions about using these tools.
-Van
On Fri, May 1, 2009 at 10:31 PM, Boyana Norris <norris at mcs.anl.gov> wrote:
> Hi Albert,
> Yes, we've been using PAPI quite extensively -- the most recent installed
> version is 3.6.2 and you can check whether the counters you are interested
> are supported by running
>  /disks/soft/papi-3.6.2/bin/papi_avail
> and if there is an event that's not supported, it is most likely still
> available natively -- you can check those names with papi_native_avail.
> Boyana
> Boyana Norris, Computer Scientist       |   Email: norris at mcs.anl.gov
> Argonne National Laboratory             |   Phone: +1 (630) 252 7908
> http://www.mcs.anl.gov/~norris/ <http://www.mcs.anl.gov/%7Enorris/>
>   |   Fax:   +1 (630) 252 5986
> From: "Albert Hartono" <hartonoa at cse.ohio-state.edu>
> To: "cookie-users" <cookie-users at lists.mcs.anl.gov>
> Sent: Friday, May 1, 2009 6:59:44 PM GMT -06:00 US/Canada Central
> Subject: [Cookie-users] Using PAPI on Cookie
> Hi All,
> Has anybody successfully tried using PAPI on Cookie to perform hardware
> counting (e.g., cache hits/misses)? I tried it a couple months ago, but
> (if my memory is not mistaken) some low-level instructions are not
> supported by PAPI for the Xeon architecture, thus can't assess the cache
> behavior.
> Thanks,
> --Albert
> Cookie-users mailing list
> Cookie-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/cookie-users
URL: <http://lists.mcs.anl.gov/pipermail/cookie-users/attachments/20090506/97dc64ac/attachment.htm>
More information about the Cookie-users mailing list
