[codes-ross-users] using OTF2 traces
Sayan Ghosh
zsayanz at gmail.com
Fri Sep 27 00:23:23 CDT 2019
How do I use OTF2 traces generated from Score-P as a model workload type? I
know DUMPI is the default, but I cannot seem to specify the other case.
Also, I am passing the Score-P measurement directory with the trace files
(one per process), hopefully that is the correct usage.
model-net-mpi-replay --sync=1 --workload_type=<???>
--workload_file=scorep-measurement-folder --num_net_traces=1024 --
modelnet-test-dragonfly.conf
Sayan | https://sg0.github.io/
URL: <http://lists.mcs.anl.gov/pipermail/codes-ross-users/attachments/20190926/8e03e24a/attachment-0001.html>
More information about the codes-ross-users
