[codes-ross-users] using OTF2 traces
Sayan Ghosh
zsayanz at gmail.com
Fri Sep 27 18:42:32 CDT 2019
I think I missed to use Tracer, as I understand now, OTF2 traces can be
replayed using Tracer on CODES/ROSS model networks.
On Thu, Sep 26, 2019 at 10:23 PM Sayan Ghosh <zsayanz at gmail.com> wrote:
> How do I use OTF2 traces generated from Score-P as a model workload type?
> I know DUMPI is the default, but I cannot seem to specify the other case.
> Also, I am passing the Score-P measurement directory with the trace files
> (one per process), hopefully that is the correct usage.
> model-net-mpi-replay --sync=1 --workload_type=<???>
> --workload_file=scorep-measurement-folder --num_net_traces=1024 --
> modelnet-test-dragonfly.conf
> Thanks,
> Sayan | https://sg0.github.io/
URL: <http://lists.mcs.anl.gov/pipermail/codes-ross-users/attachments/20190927/48d4dcb0/attachment.html>
More information about the codes-ross-users
