[codes-ross-users] Replaying OTF2 traces
Ghosh, Sayan
sayan.ghosh at pnnl.gov
Wed Sep 25 10:51:45 CDT 2019
Hi – I am trying to use CODES/ROSS to replay OTF2 traces (generated using ScoreP) on network models, after consulting the latest CODES/ROSS tutorial: https://www.mcs.anl.gov/projects/codes/files/2017/08/codes-hoti-tutorial-v4.pdf
I had used 1024 processes to generate OTF2 traces of my application (assuming it will run in serial mode without mpiexec). Ideally I would like to run the replay on my local machine using 1024 logical processes, without using mpiexec. Perhaps my understanding is not right here, please help.
WE38523:codes-bw ghos167$ ~/builds/CODES/bin/model-net-mpi-replay --sync=3 --workload_type="online" --workload_file=scorep-measurement-tmp/ --num_net_traces=1024 -- ~/sources/CODES/tests/conf/modelnet-test-dragonfly.conf
/Users/ghos167/builds/CODES/bin/model-net-mpi-replay --sync=3 --workload_type=online --workload_file=scorep-measurement-tmp/ --num_net_traces=1024 -- /Users/ghos167/sources/CODES/tests/conf/modelnet-test-dragonfly.conf
Wed Sep 25 08:43:31 2019
ROSS Version: v7.1.1
tw_net_start: Found world size to be 1
Warning: Defaulting to Sequential Simulation, not enough PEs defined.
NIC num injection port not specified, setting to 1
NIC seq delay not specified, setting to 10.000000
NIC num copy queues not specified, setting to 1
Total nodes 72 routers 36 groups 9 radix 8
within node transfer per byte delay is 0.190476
Within-node eager limit (node_eager_limit) not specified, setting to 16000
ROSS Core Configuration:
Total PEs 1
Total KPs [Nodes (1) x KPs (16)] 16
Total LPs 180
Simulation End Time 3600000000000.00
LP-to-PE Mapping model defined
ROSS Event Memory Allocation:
Model events 46081
Network events 16
Total events 46096
Assertion failed: (num_net_traces <= num_mpi_lps), function nw_test_init, file src/network-workloads/model-net-mpi-replay.c, line 2107.
Abort trap: 6
Sayan
Data Sciences
Pacific Northwest National Laboratory
URL: <http://lists.mcs.anl.gov/pipermail/codes-ross-users/attachments/20190925/1da1f9e2/attachment-0001.html>
More information about the codes-ross-users
