[codes-ross-users] CODES 1.1.0 installation issue
Caitlin Ross caitlinross25 at gmail.com
Mon Jul 29 13:51:55 CDT 2019
Can you send the commit hash you are using for both ROSS and CODES?  Also,
the CODES repo has been moved to here: https://github.com/codes-org/codes
If you have the most recent versions of both repos, you shouldn't be seeing
this error.
On Mon, Jul 29, 2019 at 2:45 PM Sayan Ghosh <zsayanz at gmail.com> wrote:
> Hi Caitlin - I built ROSS from the GitHub repo.
> On Mon, Jul 29, 2019 at 10:19 AM Caitlin Ross <caitlinross25 at gmail.com>
> wrote:
>> I think you'll need to ensure you have the most recent ROSS version. v
>> 7.1.0 or 7.1.1 should both work.
>> On Mon, Jul 29, 2019 at 10:13 AM Sayan Ghosh via codes-ross-users <
>> codes-ross-users at lists.mcs.anl.gov> wrote:
>>> I am reporting CODES build issue with Intel 19 and GCC 6.3, please
>>> suggest a workaround. I downloaded the software from:
>>> https://press3.mcs.anl.gov/codes/downloads/
>>> .././src/util/codes_mapping.c(465): error: argument of type "tw_pe" is
>>> incompatible with parameter of type "tw_pe *"
>>>   tw_kp_onpe(kpid, g_tw_pe[0]);
>>> .././src/util/codes_mapping.c(477): warning #266: function "tw_getpe"
>>> declared implicitly
>>>   pe = tw_getpe(kpid % g_tw_npe);
>>> .././src/util/codes_mapping.c(477): error: identifier "g_tw_npe" is
>>> undefined
>>> .././src/util/codes_mapping.c(477): warning #556: a value of type "int"
>>> cannot be assigned to an entity of type "tw_pe *"
>>> Thanks,
>>> Sayan | https://sg0.github.io/
>>> _______________________________________________
>>> codes-ross-users mailing list
>>> https://lists.mcs.anl.gov/mailman/listinfo/codes-ross-users
URL: <http://lists.mcs.anl.gov/pipermail/codes-ross-users/attachments/20190729/f885458d/attachment-0001.html>
More information about the codes-ross-users mailing list
