[codes-ross-users] CODES 1.1.0 installation issue
Sayan Ghosh
zsayanz at gmail.com
Mon Jul 29 14:12:45 CDT 2019
I had originally downloaded the CODES tarball from the ANL page (
https://press3.mcs.anl.gov/codes/downloads/). After cloning CODES from the
GitHub repo as you had suggested, the build issues went away. Thanks for
your help.
On Mon, Jul 29, 2019 at 11:52 AM Caitlin Ross <caitlinross25 at gmail.com>
wrote:
> Can you send the commit hash you are using for both ROSS and CODES? Also,
> the CODES repo has been moved to here: https://github.com/codes-org/codes
> If you have the most recent versions of both repos, you shouldn't be
> seeing this error.
> On Mon, Jul 29, 2019 at 2:45 PM Sayan Ghosh <zsayanz at gmail.com> wrote:
>> Hi Caitlin - I built ROSS from the GitHub repo.
>> On Mon, Jul 29, 2019 at 10:19 AM Caitlin Ross <caitlinross25 at gmail.com>
>> wrote:
>>> I think you'll need to ensure you have the most recent ROSS version. v
>>> 7.1.0 or 7.1.1 should both work.
>>> On Mon, Jul 29, 2019 at 10:13 AM Sayan Ghosh via codes-ross-users <
>>> codes-ross-users at lists.mcs.anl.gov> wrote:
>>>> I am reporting CODES build issue with Intel 19 and GCC 6.3, please
>>>> suggest a workaround. I downloaded the software from:
>>>> .././src/util/codes_mapping.c(465): error: argument of type "tw_pe" is
>>>> incompatible with parameter of type "tw_pe *"
>>>> tw_kp_onpe(kpid, g_tw_pe[0]);
>>>> .././src/util/codes_mapping.c(477): warning #266: function "tw_getpe"
>>>> declared implicitly
>>>> pe = tw_getpe(kpid % g_tw_npe);
>>>> .././src/util/codes_mapping.c(477): error: identifier "g_tw_npe" is
>>>> undefined
>>>> .././src/util/codes_mapping.c(477): warning #556: a value of type "int"
>>>> cannot be assigned to an entity of type "tw_pe *"
>>>> Thanks,
>>>> Sayan | https://sg0.github.io/
>>>> _______________________________________________
>>>> codes-ross-users mailing list
>>>> https://lists.mcs.anl.gov/mailman/listinfo/codes-ross-users
URL: <http://lists.mcs.anl.gov/pipermail/codes-ross-users/attachments/20190729/8e3fa995/attachment.html>
More information about the codes-ross-users
