[codes-ross-users] CODES 1.1.0 installation issue
Sayan Ghosh
zsayanz at gmail.com
Mon Jul 29 13:45:12 CDT 2019
Hi Caitlin - I built ROSS from the GitHub repo.
On Mon, Jul 29, 2019 at 10:19 AM Caitlin Ross <caitlinross25 at gmail.com>
wrote:
> I think you'll need to ensure you have the most recent ROSS version. v
> 7.1.0 or 7.1.1 should both work.
> On Mon, Jul 29, 2019 at 10:13 AM Sayan Ghosh via codes-ross-users <
> codes-ross-users at lists.mcs.anl.gov> wrote:
>> I am reporting CODES build issue with Intel 19 and GCC 6.3, please
>> suggest a workaround. I downloaded the software from:
>> https://press3.mcs.anl.gov/codes/downloads/
>> .././src/util/codes_mapping.c(465): error: argument of type "tw_pe" is
>> incompatible with parameter of type "tw_pe *"
>> tw_kp_onpe(kpid, g_tw_pe[0]);
>> .././src/util/codes_mapping.c(477): warning #266: function "tw_getpe"
>> declared implicitly
>> pe = tw_getpe(kpid % g_tw_npe);
>> .././src/util/codes_mapping.c(477): error: identifier "g_tw_npe" is
>> undefined
>> .././src/util/codes_mapping.c(477): warning #556: a value of type "int"
>> cannot be assigned to an entity of type "tw_pe *"
>> Thanks,
>> Sayan | https://sg0.github.io/
>> codes-ross-users mailing list
>> https://lists.mcs.anl.gov/mailman/listinfo/codes-ross-users
URL: <http://lists.mcs.anl.gov/pipermail/codes-ross-users/attachments/20190729/3504676c/attachment-0001.html>
More information about the codes-ross-users
