[codes-ross-users] CODES 1.1.0 installation issue
Caitlin Ross
caitlinross25 at gmail.com
Mon Jul 29 12:19:23 CDT 2019
I think you'll need to ensure you have the most recent ROSS version. v
7.1.0 or 7.1.1 should both work.
On Mon, Jul 29, 2019 at 10:13 AM Sayan Ghosh via codes-ross-users <
codes-ross-users at lists.mcs.anl.gov> wrote:
> I am reporting CODES build issue with Intel 19 and GCC 6.3, please suggest
> a workaround. I downloaded the software from:
> https://press3.mcs.anl.gov/codes/downloads/
> .././src/util/codes_mapping.c(465): error: argument of type "tw_pe" is
> incompatible with parameter of type "tw_pe *"
> tw_kp_onpe(kpid, g_tw_pe[0]);
> .././src/util/codes_mapping.c(477): warning #266: function "tw_getpe"
> declared implicitly
> pe = tw_getpe(kpid % g_tw_npe);
> .././src/util/codes_mapping.c(477): error: identifier "g_tw_npe" is
> undefined
> .././src/util/codes_mapping.c(477): warning #556: a value of type "int"
> cannot be assigned to an entity of type "tw_pe *"
> Thanks,
> Sayan | https://sg0.github.io/
> codes-ross-users mailing list
> https://lists.mcs.anl.gov/mailman/listinfo/codes-ross-users
URL: <http://lists.mcs.anl.gov/pipermail/codes-ross-users/attachments/20190729/344fb071/attachment.html>
More information about the codes-ross-users
