[codes-ross-users] Fat-tree configuration support oversubscription >1?
noah wolfe nwolfey21 at gmail.com
Wed Feb 1 10:19:51 CST 2017
Hi Peixin,
The current implementation of the CODES fat-tree model only supports 1:1
port mapping for leaf level switches to maintain the standard full
bisection fat-tree layout (i.e. half the ports go down to hosts and the
other half go up to the next level switches). However, the mapping of
ports can be adjusted for leaf level switches (and all levels of
switches) in the switch_init() function. Perhaps adding another ft_type
for oversubscription of leaf switches would be the best approach. The
mapping of hosts to switches which is done in the ft_terminal_init()
would also need to be adjusted for the increased number of host
connections to leaf switches. Both functions are found in
src/networks/model-net/fattree.c.
By the way, recently updated documentation for the CODES fat-tree model
can be found on the wiki:
https://xgitlab.cels.anl.gov/codes/codes/wikis/codes-fattree
Noah
From: <codes-ross-users-bounces at lists.mcs.anl.gov
<mailto:codes-ross-users-bounces at lists.mcs.anl.gov>> on behalf of Peixin
Qiao <pqiao at hawk.iit.edu <mailto:pqiao at hawk.iit.edu>>
Date: Tuesday, January 31, 2017 at 12:02 PM
To: "codes-ross-users at lists.mcs.anl.gov
<mailto:codes-ross-users at lists.mcs.anl.gov>"
<codes-ross-users at lists.mcs.anl.gov
<mailto:codes-ross-users at lists.mcs.anl.gov>>
Subject: [codes-ross-users] Fat-tree configuration support
Hi there,
When I do research about fat-tree topology uisng CODES, the
fat-tree.conf shows that the topology is with an oversubscription of
1:1, which indicates that all hosts may potentially communicate with
arbitrary other hosts at the full bandwidth of their network interface.
But the Stampede systems, which I simulated is with an oversubscription
of 1.25:1, which means that each leaf switch with 36 ports is directly
connected to 20 hosts and 16 ports in the core switch. So, does CODES
support this configuration? And how should I modify the configuration file?
Best Regards,
Peixin Qiao
URL: <http://lists.mcs.anl.gov/pipermail/codes-ross-users/attachments/20170201/1552032a/attachment.html>
More information about the codes-ross-users mailing list
