[codes-ross-users] Fat-tree configuration support oversubscription >1?
Nikhil Jain
nikhil.jain at acm.org
Wed Feb 1 10:35:00 CST 2017
Hi Peixin,
We have an updated version of the fat-tree model in CODES that supports oversubscription and we plan to contribute it back to CODES soon.
Nikhil Jain
Postdoctoral Fellow, Lawrence Livermore National Laboratory
nikhil.jain at acm.org, http://nikhil-jain.github.io/
> On Jan 31, 2017, at 09:02, Peixin Qiao <pqiao at hawk.iit.edu> wrote:
> Hi there,
> When I do research about fat-tree topology uisng CODES, the fat-tree.conf shows that the topology is with an oversubscription of 1:1, which indicates that all hosts may potentially communicate with arbitrary other hosts at the full bandwidth of their network interface. But the Stampede systems, which I simulated is with an oversubscription of 1.25:1, which means that each leaf switch with 36 ports is directly connected to 20 hosts and 16 ports in the core switch. So, does CODES support this configuration? And how should I modify the configuration file?
> Best Regards,
> Peixin Qiao
> codes-ross-users mailing list
> codes-ross-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/codes-ross-users
URL: <http://lists.mcs.anl.gov/pipermail/codes-ross-users/attachments/20170201/844e0cf6/attachment.html>
More information about the codes-ross-users
