[codes-ross-users] Cmake fails with reason "include could not find load file:GetGitRevisionDescription"
Elsa Gonsiorowski gonsie at rpi.edu
Thu Jan 29 22:34:12 CST 2015
Once you download the ROSS repo run these two commands:
git submodule init
git submodule update
Then clear out your build directory and try CMake again.
Please let me know if that doesn't work!
Elsa Gonsiorowski
> On 2015/01/29, at 18:57, Sughosh Divanji <sdivanji at hawk.iit.edu> wrote:
> Hi all,
> I am trying to install ROSS and I am following the instructions on "https://github.com/carothersc/ROSS/wiki/Installation".
> git clone is successful. But cmake fails with following reason:
> CMake Error at core/CMakeLists.txt:67 (INCLUDE):
> CMake Error at core/CMakeLists.txt:68 (GET_GIT_HEAD_REVISION):
>   Unknown CMake command "GET_GIT_HEAD_REVISION".
> -- Configuring incomplete, errors occurred!
> At first I tried compiling without DROSS_BUILD_MODELS option because the recent changes are yet to be re-integrated in code base. And also, I am getting the same error with DROSS_BUILD_MODELS option as well.
> Please let me know how to fix this.
> Thanks,
> Sughosh
> codes-ross-users mailing list
> codes-ross-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/codes-ross-users
URL: <http://lists.mcs.anl.gov/pipermail/codes-ross-users/attachments/20150129/bec6ec06/attachment.html>
More information about the codes-ross-users mailing list
