[codes-ross-users] Cmake fails with reason "include could not find load file:GetGitRevisionDescription"
Sughosh Divanji
sdivanji at hawk.iit.edu
Fri Jan 30 16:04:04 CST 2015
Hi Elsa,
Thanks a lot for your help. I tried the installation as suggested by you.
Now cmake is failing with the following error,
sughosh at sughosh-Lenovo-G50-45:~/Desktop/IITC/CS597/ross-build/ROSS-build$
cmake ~/Desktop/IITC/CS597/ROSS/
-- Configuring done
-- Generating done
-- Build files have been written to:
/home/sughosh/Desktop/IITC/CS597/ross-build/ROSS-build
make
Scanning dependencies of target ROSS
[ 4%] Building C object core/CMakeFiles/ROSS.dir/queue/splay.c.o
[ 8%] Building C object core/CMakeFiles/ROSS.dir/ross-random.c.o
[ 13%] Building C object core/CMakeFiles/ROSS.dir/rand-clcg4.c.o
[ 17%] Building C object core/CMakeFiles/ROSS.dir/clock/amd64.c.o
[ 21%] Building C object core/CMakeFiles/ROSS.dir/gvt/mpi_allreduce.c.o
[ 26%] Building C object core/CMakeFiles/ROSS.dir/network-mpi.c.o
[ 30%] Building C object core/CMakeFiles/ROSS.dir/hash-quadratic.c.o
/home/sughosh/Desktop/IITC/CS597/ROSS/core/hash-quadratic.c: In function
‘tw_hash_create’:
/home/sughosh/Desktop/IITC/CS597/ROSS/core/hash-quadratic.c:36:3: error:
‘g_avl_node_count’ undeclared (first use in this function)
g_avl_node_count = 1 << g_tw_avl_node_count;
/home/sughosh/Desktop/IITC/CS597/ROSS/core/hash-quadratic.c:36:3: note:
each undeclared identifier is reported only once for each function it
appears in
make[2]: *** [core/CMakeFiles/ROSS.dir/hash-quadratic.c.o] Error 1
make[1]: *** [core/CMakeFiles/ROSS.dir/all] Error 2
make: *** [all] Error 2
Please suggest how to fix this error.
Sughosh
ᐧ
On Thu, Jan 29, 2015 at 10:34 PM, Elsa Gonsiorowski <gonsie at rpi.edu> wrote:
> Once you download the ROSS repo run these two commands:
> git submodule init
> git submodule update
> Then clear out your build directory and try CMake again.
> Please let me know if that doesn't work!
> Elsa Gonsiorowski
> On 2015/01/29, at 18:57, Sughosh Divanji <sdivanji at hawk.iit.edu> wrote:
> Hi all,
> I am trying to install ROSS and I am following the instructions on "
> https://github.com/carothersc/ROSS/wiki/Installation".
> git clone is successful. But cmake fails with following reason:
> CMake Error at core/CMakeLists.txt:67 (INCLUDE):
> CMake Error at core/CMakeLists.txt:68 (GET_GIT_HEAD_REVISION):
> Unknown CMake command "GET_GIT_HEAD_REVISION".
> -- Configuring incomplete, errors occurred!
> At first I tried compiling without DROSS_BUILD_MODELS option because the
> recent changes are yet to be re-integrated in code base. And also, I am
> getting the same error with DROSS_BUILD_MODELS option as well.
> Please let me know how to fix this.
> Thanks,
> Sughosh
> ᐧ
> codes-ross-users mailing list
> codes-ross-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/codes-ross-users
URL: <http://lists.mcs.anl.gov/pipermail/codes-ross-users/attachments/20150130/46c772df/attachment.html>
More information about the codes-ross-users
