[cgma-dev] CGM doc
Grindeanu, Iulian R.
iulian at mcs.anl.gov
Thu Mar 10 09:59:35 CST 2016
Hello,
CGM alone would not be enough to generate a mesh
CGM is mostly a wrapper around other geometry kernels, ACIS or OCC/OCE based.
To generate a mesh you would need the SIGMA stack.
http://sigma.mcs.anl.gov/
I am not familiar with what format you need your mesh for EFISPEC3D; I assume it is similar to NEK5000 solver, which is a spectral element method too. (so Nek needs a hexahedral mesh)
And what is the input geometry format? Terrain data?
We have some capabilities developed for ice sheet modeling. At the core, they do need a quadrilateral mesher for surfaces, which are then extruded/swept to form hexahedral elements. Also, it is assumed that the domain of interest does not have internal caves/tunnels, so the sweeping in vertical direction is trivial.
I am not sure how these would help your project.
Iulian
From: cgma-dev-bounces at mcs.anl.gov [cgma-dev-bounces at mcs.anl.gov] on behalf of De Martin Florent [F.DeMartin at brgm.fr]
Sent: Thursday, March 10, 2016 9:19 AM
To: cgma-dev at mcs.anl.gov
Subject: [cgma-dev] CGM doc
Dear CGM support,
I am interested to generate large scale finite element meshes for the spectral-element code EFISPEC3D (http://efispec.free.fr)
I have downloaded (from git) and compiled CGM, but I can hardly find a user documentation. Would you please send it to me ?
Best regards,
Florent DE MARTIN
P Pensez à l'environnement avant d'imprimer ce message
Think Environment before printing
Le contenu de ce mél et de ses pièces jointes est destiné à l'usage exclusif du (des) destinataire(s) désigné(s) comme tel(s).
En cas de réception par erreur, le signaler à son expéditeur et ne pas en divulguer le contenu.
L'absence de virus a été vérifiée à l'émission, il convient néanmoins de s'assurer de l'absence de contamination à sa réception.
The contents of this email and any attachments are confidential. They are intended for the named recipient(s) only.
If you have received this email in error please notify the system manager or the sender immediately and do not disclose the contents to
anyone or make copies.
This email was scanned for viruses, vandals and malicious content.
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20160310/04fa617c/attachment.html>
More information about the cgma-dev
