[cgma-dev] Inconsistency in getEntities for iGeom interface.	Causes problems in iRel.
    Rajeev Jain
    jain at mcs.anl.gov
    Wed Jul 16 02:35:02 CDT 2014
I think all of the tags should get copied, but there might be use cases (in-future, I can't think of a case now) where making things more general and allowing a user option for selective or complete copying of tags might prove useful.
Rajeev
To: "Jain, Rajeev" <jain at mcs.anl.gov>; shriwise <shriwise at wisc.edu>; CGMA Development <cgma-dev at mcs.anl.gov>
Sent: Wednesday, July 16, 2014 12:09 AM
Subject: Re: [cgma-dev] Inconsistency in getEntities for iGeom interface. Causes problems in iRel.
Hi Rajeev,
Thanks for the response.  I guess it's still not clear what the
    expected behavior should be when copying an entity in iGeom.  Should
    it copy some/none/all of the tags to the new entity?  Is there a
    standard for what gets copied?
Paul
On 07/15/2014 08:26 PM, Rajeev Jain wrote:
Sorry, I missed this email.
>Yes, you are right. It is for OCC based meshing. The test names volumes/surfs etc and then tries to retrieve them.
>You can ignore the test case as we started working on developing other missing pieces for OCC geometry based meshing in MeshKit. When entities are copied the names can be copied with some an additional letter word under some convention.
>Ex. CUBIT uses vol 1 named as mysteel when copied the new vol 2 is called mysteel at a etc.
>Rajeev
>________________________________
> From: shriwise <shriwise at wisc.edu>
>To: Paul Wilson <wilsonp at engr.wisc.edu>; "Jain, Rajeev" <jain at mcs.anl.gov>; CGMA Development <cgma-dev at mcs.anl.gov>
>Sent: Tuesday, July 15, 2014 10:29 AM
>Bump.
>On 07/11/2014 08:15 PM, Paul Wilson wrote:
>Rajeev,
>>You are mentioned in the git logs as the inspiration
                    for the copy_attrib test that Patrick mentioned.  (a
                    few years ago)
>>I wonder if you have any thoughts on what the
                    purpose and/or requirements are for this
                    capability?  You probably needed it for RGG based on
                    OCC?
>>Paul
>>On 07/11/2014 07:21 PM, Patrick Shriwise wrote:
>>Hi all,
>>>I'm currently working on the changes to iGeom that
                      Paul previously proposed. I've hit one test when
                      built with OCC (copy_attrib) that suggests that
                      tags are expected to be copied along with an
                      entity when using iGeom functions like copyEnt or
                      subtractEnt. Is this the case? Are these specifc
                      tags that are supposed to be copied if they exist
                      on the original entity?
>>>Also to be clear this has become an issue because
                      for volume entities we now use the RefVolume to
                      get the volume Body and make a copy of that body
                      using the GeometryModifyTool. The Body we make a
                      copy of does not have the tags associated with the
                      RefVolume. As a result the new Body and the
                      corresponding RefVolumethat we return from the
                      function does not have the original tags.
>>>These tags can be transferred to the new entity
                      before leaving the function of course, but we're
                      looking for the proper way to handle this
                      situation. Mainly it would be good to know if
                      there is a particular tag or tags that should be
                      copied over to new entity upon it's creation.
>>>Cheers,
>>>Patrick
>>>On 06/23/2014 03:06 PM, Paul Wilson wrote:
>>>Hi everyone,
>>>>Patrick and I have discussed this and have come
                        up with the following proposal for a revision of
                        how iGeom_CGMA handles RefVolumes and Body's.
>>>>	1. All references to iBase_REGION will refer only to entities of type RefVolume in CGM.
>>>>	2. All entities that are returned by iGeom will be RefEntities and not CubitEntities
>>>>	3. At the time of loading file, based on an option based to iGeom_load(), all entities of type Body in CGM that contain more than a single volume, will be converted to RefGroup's and tagged to distinguish them from the original RefGroup's
>>>>The last of these may be subject to the most conversation, but it seemed like a useful approach to use because it:
>>>>	* had little to no effect on the API of iGeom
>>>>	* preserves access to CGM/ACIS bodies
>>>>	* is the least intrusive in the implementation of iGeom_CGMA
>>>>If a user does NOT pass in the option (e.g. "CONVERT_BODY_TO_GROUP"), then no bodies will be accessible through iGeom.  If a user does pass in this option, any call to iGeom_getEntSets will return both the original RefGroups and the additional RefGroups that were generated automatically from Bodies.  It will be up to the user to filter between them using the available tag.
>>>>Finally, since every RefVolume in ACIS always has a Body in which it is a member, it seems best to only convert Bodies that contain >1 RefVolume to avoid creating far more RefGroups than necessary.
>>>>We'd like to embark on these changes soon, but welcome any comments or feedback.  I'm sure we've missed something!
>>>>Paul
>>>>On 06/17/2014 09:00 AM, Jane Hu wrote:
>>>>So, I will add RefVolume to the return list of iGeom_get_adjacent_entities() as the result of the discussion.
>>>>>CubitEntity only has derived classes of RefEntity and CubitCoordinateSystem, iGeom_CGMA.cc only uses RefEntity as instance of the object.
>>>>>Jane
>>>>>On Mon, Jun 16, 2014 at 11:35 AM, Jane Hu <janejhu at gmail.com> wrote:
>>>>>See comments below...
>>>>>>On Mon, Jun 16, 2014 at 10:22 AM, Paul Wilson <wilsonp at engr.wisc.edu> wrote:
>>>>>>Hi Jane,
>>>>>>>I think this needs a
                                            thorough review!  Patrick
                                            and I hunted through
                                            iGeom_CGMA and found some
                                            inconsistencies in a few
                                            places.
>>>>>>>First, there is an
                                            inconsistency between
                                            returning pointers to
                                            RefEntity and pointers to
                                            CubitEntity.  This is
                                            probably less important, but
                                            should probably be resolved
                                            in any change.
>>>>>>I see RefEntity is inherited from CubitEntity, and CubitEntity is a pure virtual class. So even you got pointers to CubitEntity, you have to instantiate it to RefEntity objects.
>>>>>>>Second, there are places
                                            where the geometry is
                                            queried for entities of
                                            dimension=3 (returning
                                            RefVolumes) and places where
                                            the geometry is queried for
                                            entities of
                                            type=iGeom_REGION (== Body).
>>>>>>In this case, I can return both bodies and refvolumes, so after user gets the refentity list back, he can cast to see if they are bodies or refvolumes, and choose to keep what ever he needs.
>>>>>>>This means that 2 calls
                                              into the interface that
                                              should resolve to the same
                                              entity may not do so for
                                              both reasons.
>>>>>>>All of this is related to
                                              the fundamental difference
                                              between the iGeom types
                                              (equivalent to vertex,
                                              edge, face, volume) and
                                              the CGM/ACIS types
                                              (equiavlent to vertex,
                                              edge, face, volume,
                                              body).  I think Tim's
                                              suggestion is the best,
                                              but will require some
                                              substantial effort.
>>>>>>>Paul
>>>>>>>On 06/16/2014 10:14 AM, Jane Hu wrote:
>>>>>>>I see in iGeom_CGMA.cc file, function iGeom_get_adjacent_entities, if asks for 3-D refentities, it returns body list. In CGM, bodies are not necessary to be 3-D entities, it may contain single surface or shell. Should we change the return to be only refvolumes which are 3-D entities (I prefer this, makes more sense)? Or I can return both bodies and refvolumes in the returned refentity list. Depending on your user case, I can return one of the two choices.
>>>>>>>>Jane
>>>>>>>>On Mon, Jun 16, 2014 at 9:32 AM, Jane Hu <janejhu at gmail.com> wrote:
>>>>>>>>Yes, it returns a list of refVolume's which are RefEntities.
>>>>>>>>>Jane
>>>>>>>>>On Sun, Jun 15, 2014 at 11:55 PM, Patrick Shriwise <shriwise at wisc.edu> wrote:
>>>>>>>>>Hi Jane,
>>>>>>>>>>Will the ref_volumes() method return RefEntities?
>>>>>>>>>>Patrick
>>>>>>>>>>On Jun 15,
                                                          2014, at 3:56
                                                          PM, Jane Hu
>>>>>>>>>>Look at line 6454, if you have body's pointer, directly call ref_volumes() will work. It's not an iGeom interface function, but you can access it in iGeom.
>>>>>>>>>>>Good luck!
>>>>>>>>>>>Jane
>>>>>>>>>>>On Sat, Jun 14, 2014 at 8:55 AM, Patrick Shriwise <shriwise at wisc.edu> wrote:
>>>>>>>>>>>Hi Jane,
>>>>>>>>>>>>I looked
                                                          around for
                                                          this but
                                                          didn't see it,
                                                          is there a
                                                          specific
                                                          line/function
                                                          you were
                                                          thinking of?
                                                          Good to know
                                                          the ref_volume
                                                          information is
                                                          so easy to get
                                                          to, but it
                                                          doesn't seem
                                                          that its part
                                                          of the iGeom
                                                          interface. The
                                                          issue being
                                                          that there's
                                                          no way to
                                                          access a
                                                          body's volumes
                                                          via iGeom.
>>>>>>>>>>>>Cheers,
>>>>>>>>>>>>Patrick
>>>>>>>>>>>>On 06/13/2014 11:26 PM, Jane Hu wrote:
>>>>>>>>>>>>>> Is there a
                                                          way to get
                                                          volumes within
                                                          bodies via
                                                          iGeom?
>>>>>>>>>>>>>See example in  iGeom_CGMA.cc,
body->ref_volumes(volumes).
>>>>>>>>>>>>>Jane
Patrick C. Shriwise
Research Assistant
University of Wisconsin - Madison
Engineering Research Building - Rm. 428
1500 Engineering Drive
Madison, WI 53706 (608) 446-8173
>>>>>>>>>>>>>Jane Hu
>>>>>>>>>>>>>Asst.
                                                          Researcher
>>>>>>>>>>>>>Dept. of
                                                          Engineering
                                                          Physics
>>>>>>>>>>>>>UW @ Madison
>>>>>>>>>>>>>"And we know
                                                          that for those
                                                          who love God,
                                                          that is, for
                                                          those who are
                                                          called
                                                          according to
                                                          his purpose,
                                                          all things are
                                                          working
                                                          together for
                                                          good." (Romans
                                                          8:28)
>>>>>>>>>>>Jane Hu
>>>>>>>>>>>Asst.
                                                          Researcher
>>>>>>>>>>>Dept. of
                                                          Engineering
                                                          Physics
>>>>>>>>>>>UW @ Madison
>>>>>>>>>>>"And we know
                                                          that for those
                                                          who love God,
                                                          that is, for
                                                          those who are
                                                          called
                                                          according to
                                                          his purpose,
                                                          all things are
                                                          working
                                                          together for
                                                          good." (Romans
                                                          8:28)
>>>>>>>>>Jane Hu
>>>>>>>>>Asst.
                                                          Researcher
>>>>>>>>>Dept. of
                                                          Engineering
                                                          Physics
>>>>>>>>>UW @ Madison
>>>>>>>>>"And we know
                                                          that for those
                                                          who love God,
                                                          that is, for
                                                          those who are
                                                          called
                                                          according to
                                                          his purpose,
                                                          all things are
                                                          working
                                                          together for
                                                          good." (Romans
                                                          8:28)
>>>>>>>>Jane Hu
>>>>>>>>Asst. Researcher
>>>>>>>>Dept. of
                                                      Engineering
                                                      Physics
>>>>>>>>UW @ Madison
>>>>>>>>"And we know that
                                                      for those who love
                                                      God, that is, for
                                                      those who are
                                                      called according
                                                      to his purpose,
                                                      all things are
                                                      working together
                                                      for good." (Romans
                                                      8:28)
Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu Faculty Director, Advanced Computing Infrastructure
>>>>>>Jane Hu
>>>>>>Asst. Researcher
>>>>>>Dept. of Engineering Physics
>>>>>>UW @ Madison
>>>>>>"And we know that for those who
                                        love God, that is, for those who
                                        are called according to his
                                        purpose, all things are working
                                        together for good." (Romans
                                        8:28)
>>>>>Jane Hu
>>>>>Asst. Researcher
>>>>>UW @ Madison
>>>>>"And we know that for those who love God,
                            that is, for those who are called according
                            to his purpose, all things are working
                            together for good." (Romans 8:28)
Patrick C. Shriwise
Research Assistant
Madison, WI 53706
(608) 446-8173
Patrick C. Shriwise
Research Assistant
Madison, WI 53706
(608) 446-8173
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20140716/6ee8a8ad/attachment-0001.html>
More information about the cgma-dev
