[cgma-dev] Inconsistency in getEntities for iGeom interface. Causes problems in iRel.
Paul Wilson wilsonp at engr.wisc.edu
Wed Jul 16 00:09:53 CDT 2014
Hi Rajeev,
Thanks for the response.  I guess it's still not clear what the expected
behavior should be when copying an entity in iGeom.  Should it copy
some/none/all of the tags to the new entity?  Is there a standard for
what gets copied?
Paul
On 07/15/2014 08:26 PM, Rajeev Jain wrote:
> Sorry, I missed this email.
> Yes, you are right. It is for OCC based meshing. The test names
> volumes/surfs etc and then tries to retrieve them.
> You can ignore the test case as we started working on developing other
> missing pieces for OCC geometry based meshing in MeshKit. When
> entities are copied the names can be copied with some an additional
> letter word under some convention.
> Ex. CUBIT uses vol 1 named as mysteel when copied the new vol 2 is
> called mysteel at a etc.
> Rajeev
> *From:* shriwise <shriwise at wisc.edu>
> *To:* Paul Wilson <wilsonp at engr.wisc.edu>; "Jain, Rajeev"
> <jain at mcs.anl.gov>; CGMA Development <cgma-dev at mcs.anl.gov>
> *Sent:* Tuesday, July 15, 2014 10:29 AM
> *Subject:* Re: [cgma-dev] Inconsistency in getEntities for iGeom
> Bump.
> On 07/11/2014 08:15 PM, Paul Wilson wrote:
>> Rajeev,
>> You are mentioned in the git logs as the inspiration for the
>> copy_attrib test that Patrick mentioned.  (a few years ago)
>> I wonder if you have any thoughts on what the purpose and/or
>> requirements are for this capability?  You probably needed it for RGG
>> based on OCC?
>> Paul
>> On 07/11/2014 07:21 PM, Patrick Shriwise wrote:
>>> Hi all,
>>> I'm currently working on the changes to iGeom that Paul previously
>>> proposed. I've hit one test when built with OCC (copy_attrib) that
>>> suggests that tags are expected to be copied along with an entity
>>> when using iGeom functions like copyEnt or subtractEnt. Is this the
>>> case? Are these specifc tags that are supposed to be copied if they
>>> exist on the original entity?
>>> Also to be clear this has become an issue because for volume
>>> entities we now use the RefVolume to get the volume Body and make a
>>> copy of that body using the GeometryModifyTool. The Body we make a
>>> copy of does not have the tags associated with the RefVolume. As a
>>> result the new Body and the corresponding RefVolumethat we return
>>> from the function does not have the original tags.
>>> These tags can be transferred to the new entity before leaving the
>>> function of course, but we're looking for the proper way to handle
>>> this situation. Mainly it would be good to know if there is a
>>> particular tag or tags that should be copied over to new entity upon
>>> it's creation.
>>> Cheers,
>>> Patrick
>>> On 06/23/2014 03:06 PM, Paul Wilson wrote:
>>>> Hi everyone,
>>>> Patrick and I have discussed this and have come up with the
>>>> following proposal for a revision of how iGeom_CGMA handles
>>>> RefVolumes and Body's.
>>>>  1. All references to iBase_REGION will refer only to entities of
>>>>     type RefVolume in CGM.
>>>>  2. All entities that are returned by iGeom will be RefEntities and
>>>>     not CubitEntities
>>>>  3. At the time of loading file, based on an option based to
>>>>     iGeom_load(), all entities of type Body in CGM that contain
>>>>     more than a single volume, will be converted to RefGroup's and
>>>>     tagged to distinguish them from the original RefGroup's
>>>> The last of these may be subject to the most conversation, but it
>>>> seemed like a useful approach to use because it:
>>>>   * had little to no effect on the API of iGeom
>>>>   * preserves access to CGM/ACIS bodies
>>>>   * is the least intrusive in the implementation of iGeom_CGMA
>>>> If a user does NOT pass in the option (e.g.
>>>> "CONVERT_BODY_TO_GROUP"), then no bodies will be accessible through
>>>> iGeom.  If a user does pass in this option, any call to
>>>> iGeom_getEntSets will return both the original RefGroups and the
>>>> additional RefGroups that were generated automatically from
>>>> Bodies.  It will be up to the user to filter between them using the
>>>> available tag.
>>>> Finally, since every RefVolume in ACIS always has a Body in which
>>>> it is a member, it seems best to only convert Bodies that contain
>>>> >1 RefVolume to avoid creating far more RefGroups than necessary.
>>>> We'd like to embark on these changes soon, but welcome any comments
>>>> or feedback.  I'm sure we've missed something!
>>>> Paul
>>>> On 06/17/2014 09:00 AM, Jane Hu wrote:
>>>>> So, I will add RefVolume to the return list
>>>>> of iGeom_get_adjacent_entities() as the result of the discussion.
>>>>> CubitEntity only has derived classes of RefEntity
>>>>> and CubitCoordinateSystem, iGeom_CGMA.cc only uses RefEntity as
>>>>> instance of the object.
>>>>> Jane
>>>>> On Mon, Jun 16, 2014 at 11:35 AM, Jane Hu <janejhu at gmail.com
>>>>> <mailto:janejhu at gmail.com>> wrote:
>>>>>     See comments below...
>>>>>     On Mon, Jun 16, 2014 at 10:22 AM, Paul Wilson
>>>>>     <wilsonp at engr.wisc.edu <mailto:wilsonp at engr.wisc.edu>> wrote:
>>>>>         Hi Jane,
>>>>>         I think this needs a thorough review!  Patrick and I
>>>>>         hunted through iGeom_CGMA and found some inconsistencies
>>>>>         in a few places.
>>>>>         First, there is an inconsistency between returning
>>>>>         pointers to RefEntity and pointers to CubitEntity.  This
>>>>>         is probably less important, but should probably be
>>>>>         resolved in any change.
>>>>>     I see RefEntity is inherited from CubitEntity, and CubitEntity
>>>>>     is a pure virtual class. So even you got pointers to
>>>>>     CubitEntity, you have to instantiate it to RefEntity objects.
>>>>>         Second, there are places where the geometry is queried for
>>>>>         entities of dimension=3 (returning RefVolumes) and places
>>>>>         where the geometry is queried for entities of
>>>>>         type=iGeom_REGION (== Body).
>>>>>     In this case, I can return both bodies and refvolumes, so
>>>>>     after user gets the refentity list back, he can cast to see if
>>>>>     they are bodies or refvolumes, and choose to keep what ever he
>>>>>     needs.
>>>>>         This means that 2 calls into the interface that should
>>>>>         resolve to the same entity may not do so for both reasons.
>>>>>         All of this is related to the fundamental difference
>>>>>         between the iGeom types (equivalent to vertex, edge, face,
>>>>>         volume) and the CGM/ACIS types (equiavlent to vertex,
>>>>>         edge, face, volume, body).  I think Tim's suggestion is
>>>>>         the best, but will require some substantial effort.
>>>>>         Paul
>>>>>         On 06/16/2014 10:14 AM, Jane Hu wrote:
>>>>>>         I see in iGeom_CGMA.cc file,
>>>>>>         function iGeom_get_adjacent_entities, if asks for 3-D
>>>>>>         refentities, it returns body list. In CGM, bodies are not
>>>>>>         necessary to be 3-D entities, it may contain single
>>>>>>         surface or shell. Should we change the return to be only
>>>>>>         refvolumes which are 3-D entities (I prefer this, makes
>>>>>>         more sense)? Or I can return both bodies and refvolumes
>>>>>>         in the returned refentity list. Depending on your user
>>>>>>         case, I can return one of the two choices.
>>>>>>         Jane
>>>>>>         On Mon, Jun 16, 2014 at 9:32 AM, Jane Hu
>>>>>>         <janejhu at gmail.com <mailto:janejhu at gmail.com>> wrote:
>>>>>>             Yes, it returns a list of refVolume's which are
>>>>>>             RefEntities.
>>>>>>             Jane
>>>>>>             On Sun, Jun 15, 2014 at 11:55 PM, Patrick Shriwise
>>>>>>             <shriwise at wisc.edu <mailto:shriwise at wisc.edu>> wrote:
>>>>>>                 Hi Jane,
>>>>>>                 Will the ref_volumes() method return RefEntities?
>>>>>>                 Patrick
>>>>>>                 On Jun 15, 2014, at 3:56 PM, Jane Hu
>>>>>>>                 Look at line 6454, if you have body's pointer,
>>>>>>>                 directly call ref_volumes() will work. It's not
>>>>>>>                 an iGeom interface function, but you can access
>>>>>>>                 it in iGeom.
>>>>>>>                 Good luck!
>>>>>>>                 Jane
>>>>>>>                 On Sat, Jun 14, 2014 at 8:55 AM, Patrick
>>>>>>>                 Shriwise <shriwise at wisc.edu
>>>>>>>                     Hi Jane,
>>>>>>>                     I looked around for this but didn't see it,
>>>>>>>                     is there a specific line/function you were
>>>>>>>                     thinking of? Good to know the ref_volume
>>>>>>>                     information is so easy to get to, but it
>>>>>>>                     doesn't seem that its part of the iGeom
>>>>>>>                     interface. The issue being that there's no
>>>>>>>                     way to access a body's volumes via iGeom.
>>>>>>>                     Cheers,
>>>>>>>                     Patrick
>>>>>>>                     On 06/13/2014 11:26 PM, Jane Hu wrote:
>>>>>>>>                          Is there a way to get volumes within
>>>>>>>>                         bodies via iGeom?
>>>>>>>>                     See example in  iGeom_CGMA.cc,
>>>>>>>>                     body->ref_volumes(volumes).
>>>>>>>>                     Jane
>>>>>>>>                         Patrick C. Shriwise
>>>>>>>>                         Research Assistant
>>>>>>>>                         University of Wisconsin - Madison
>>>>>>>>                         Engineering Research Building - Rm. 428
>>>>>>>>                         1500 Engineering Drive
>>>>>>>>                         Madison, WI 53706
>>>>>>>>                         (608) 446-8173
>>>>>>>>                     Jane Hu
>>>>>>>>                     Asst. Researcher
>>>>>>>>                     Dept. of Engineering Physics
>>>>>>>>                     UW @ Madison
>>>>>>>>                     "And we know that for those who love God,
>>>>>>>>                     that is, for those who are called according
>>>>>>>>                     to his purpose, all things are working
>>>>>>>>                     together for good." (Romans 8:28)
>>>>>>>                 Jane Hu
>>>>>>>                 Asst. Researcher
>>>>>>>                 UW @ Madison
>>>>>>>                 "And we know that for those who love God, that
>>>>>>>                 is, for those who are called according to his
>>>>>>>                 purpose, all things are working together for
>>>>>>             Jane Hu
>>>>>>             Asst. Researcher
>>>>>>             UW @ Madison
>>>>>>             "And we know that for those who love God, that is,
>>>>>>             for those who are called according to his purpose,
>>>>>>             all things are working together for good." (Romans 8:28)
>>>>>>         Jane Hu
>>>>>>         Asst. Researcher
>>>>>>         UW @ Madison
>>>>>>         "And we know that for those who love God, that is, for
>>>>>>         those who are called according to his purpose, all things
>>>>>         Paul Wilson ~ UW-Madison ~608-263-0807  ~ cal:http://bit.ly/pphw-cal
>>>>>         Professor, Engineering Physics. ~http://cnerg.engr.wisc.edu  <http://cnerg.engr.wisc.edu/>
>>>>>         Faculty Director, Advanced Computing Infrastructure
>>>>>     Jane Hu
>>>>>     Asst. Researcher
>>>>>     UW @ Madison
>>>>>     "And we know that for those who love God, that is, for those
>>>>>     who are called according to his purpose, all things are
>>>>> Jane Hu
>>>>> Asst. Researcher
>>>>> UW @ Madison
>>>>> "And we know that for those who love God, that is, for those who
>>>>> are called according to his purpose, all things are working
>>>> Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal:http://bit.ly/pphw-cal
>>> Patrick C. Shriwise
>>> Research Assistant
>>> Madison, WI 53706
>>> (608) 446-8173
> Patrick C. Shriwise
> Research Assistant
> Madison, WI 53706
> (608) 446-8173
Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20140716/c07dfc5e/attachment-0001.html>
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20140716/c07dfc5e/attachment-0001.bin>
More information about the cgma-dev mailing list
