[cgma-dev] CGM failing with OCC6.6.0
    Paul Wilson
    wilsonp at engr.wisc.edu
    Fri Apr 11 15:24:40 CDT 2014
Hi Iulian,
These are the same errors I see - 6 in total for me.
Paul
On 04/11/2014 11:30 AM, Grindeanu, Iulian R. wrote:
> Hello,
> Even after recompiling occ660 on ubuntu 12, I got the same errors
> The tests to blame are in cgm/master branch:
> FAIL: merge_facet
> FAIL: merge_occ
> FAIL: r_w
> FAIL: groups_saved_to_OCC
> They fail in optimized mode, and pass in debug mode
> They used to work on ubuntu 10 on occ 653, on cgm master, in optimized mode.
> They fail in optimized mode on ubuntu 12 on occ 653 and on occ 660.
> We did not test before for occ 660 on master , on ubuntu 10.
> Iulian
> From: cgma-dev-bounces at mcs.anl.gov [cgma-dev-bounces at mcs.anl.gov] on behalf of Grindeanu, Iulian R. [iulian at mcs.anl.gov]
> Sent: Friday, April 11, 2014 10:02 AM
> To: Paul Wilson; CGMA Development
> Subject: Re: [cgma-dev] CGM failing with OCC6.6.0
> Hello,
> There seems to be another problem with cgm master, uncovered by last night builds
> On my machine, it works with occ 653, in debug mode, with mpi.
> If I compile without debug mode, several tests fail;
> it is the same error on gnep now;
> To add to the misery, on ubuntu 10.04, there were no errors in optimized mode. (this is previous build, before gnep was upgraded)
> http://gnep.mcs.anl.gov:8010/builders/cgmtr-occ-par-sta/builds/430/steps/test/logs/stdio
> But errors pop up on my machine too, like these pointed by buildbot, last night:
> http://gnep.mcs.anl.gov:8010/builders/cgmtr-occ-par-sta/builds/431/steps/test/logs/stdio
> Jane is on vacation, so I don't know who can figure these out now :(
> I will try to rebuild occ 653, on gnep. What kind of errors  do you see with 660 on cgm master?
> Iulian
> Sent: Thursday, April 10, 2014 1:49 PM
> Ouch :(
> Buildbot was testing only cgm13.1 against occ660. If cgm master fails (I think it is 14.0), it means Jane would have to look at it.
> Does anybody build cgm master with  occ 660?
> Iulian
> From: cgma-dev-bounces at mcs.anl.gov [cgma-dev-bounces at mcs.anl.gov] on behalf of Paul Wilson [wilsonp at engr.wisc.edu]
> Sent: Thursday, April 10, 2014 12:23 PM
> To: CGMA Development
> Subject: [cgma-dev] CGM failing with OCC6.6.0
> Hello all,
> I thought I had overcome these problems last month, but I seem to be
> having new problems.
> I have successfully built CGM13.1 with OCC 6.6.0, including successful
> testing with 'make check'.
> When I use the identical installation of OCC 6.6.0 to build the master
> CGM branch (14.1?) it fails on 'make check'.  I have looked and the
> patch to OCC 6.6.0 didn't change between CGM13.1 and master.  It
> certainly seems that the code did change.
> Any tips?
> Paul
> Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
> Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
> Faculty Director, Advanced Computing Infrastructure
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20140411/a7a2a347/attachment.bin>
More information about the cgma-dev
