[cgma-dev] CGM failing with OCC6.6.0
Jane Hu
janejhu at gmail.com
Tue Apr 22 14:23:11 CDT 2014
I double checked my configuration, I used opencascade 6.7.0 for trunk cgm
build. I didn't realize that it wasn't comparable with 6.6.0. Working on it
now.
Jane
On Fri, Apr 11, 2014 at 3:24 PM, Paul Wilson <wilsonp at engr.wisc.edu> wrote:
> Hi Iulian,
> These are the same errors I see - 6 in total for me.
> Paul
> On 04/11/2014 11:30 AM, Grindeanu, Iulian R. wrote:
>> Hello,
>> Even after recompiling occ660 on ubuntu 12, I got the same errors
>> The tests to blame are in cgm/master branch:
>> FAIL: merge_facet
>> FAIL: merge_occ
>> FAIL: r_w
>> FAIL: groups_saved_to_OCC
>> They fail in optimized mode, and pass in debug mode
>> They used to work on ubuntu 10 on occ 653, on cgm master, in optimized
>> mode.
>> They fail in optimized mode on ubuntu 12 on occ 653 and on occ 660.
>> We did not test before for occ 660 on master , on ubuntu 10.
>> Iulian
>> ________________________________________
>> From: cgma-dev-bounces at mcs.anl.gov [cgma-dev-bounces at mcs.anl.gov] on
>> behalf of Grindeanu, Iulian R. [iulian at mcs.anl.gov]
>> Sent: Friday, April 11, 2014 10:02 AM
>> To: Paul Wilson; CGMA Development
>> Subject: Re: [cgma-dev] CGM failing with OCC6.6.0
>> Hello,
>> There seems to be another problem with cgm master, uncovered by last
>> night builds
>> On my machine, it works with occ 653, in debug mode, with mpi.
>> If I compile without debug mode, several tests fail;
>> it is the same error on gnep now;
>> To add to the misery, on ubuntu 10.04, there were no errors in optimized
>> mode. (this is previous build, before gnep was upgraded)
>> http://gnep.mcs.anl.gov:8010/builders/cgmtr-occ-par-sta/
>> builds/430/steps/test/logs/stdio
>> But errors pop up on my machine too, like these pointed by buildbot, last
>> night:
>> builds/431/steps/test/logs/stdio
>> Jane is on vacation, so I don't know who can figure these out now :(
>> I will try to rebuild occ 653, on gnep. What kind of errors do you see
>> with 660 on cgm master?
>> Iulian
>> Sent: Thursday, April 10, 2014 1:49 PM
>> Ouch :(
>> Buildbot was testing only cgm13.1 against occ660. If cgm master fails (I
>> think it is 14.0), it means Jane would have to look at it.
>> Does anybody build cgm master with occ 660?
>> Iulian
>> behalf of Paul Wilson [wilsonp at engr.wisc.edu]
>> Sent: Thursday, April 10, 2014 12:23 PM
>> To: CGMA Development
>> Subject: [cgma-dev] CGM failing with OCC6.6.0
>> Hello all,
>> I thought I had overcome these problems last month, but I seem to be
>> having new problems.
>> I have successfully built CGM13.1 with OCC 6.6.0, including successful
>> testing with 'make check'.
>> When I use the identical installation of OCC 6.6.0 to build the master
>> CGM branch (14.1?) it fails on 'make check'. I have looked and the
>> patch to OCC 6.6.0 didn't change between CGM13.1 and master. It
>> certainly seems that the code did change.
>> Any tips?
>> Paul
>> Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
>> Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
>> Faculty Director, Advanced Computing Infrastructure
Jane Hu
Asst. Researcher
Dept. of Engineering Physics
UW @ Madison
"And we know that for those who love God, that is, for those who are called
according to his purpose, all things are working together for good."
(Romans 8:28)
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20140422/7b7e7e54/attachment.html>
More information about the cgma-dev
