[cgma-dev] CGM failing with OCC6.6.0
Grindeanu, Iulian R.
iulian at mcs.anl.gov
Fri Apr 11 11:30:42 CDT 2014
Hello,
Even after recompiling occ660 on ubuntu 12, I got the same errors
The tests to blame are in cgm/master branch:
FAIL: merge_facet
FAIL: merge_occ
FAIL: r_w
FAIL: groups_saved_to_OCC
They fail in optimized mode, and pass in debug mode
They used to work on ubuntu 10 on occ 653, on cgm master, in optimized mode.
They fail in optimized mode on ubuntu 12 on occ 653 and on occ 660.
We did not test before for occ 660 on master , on ubuntu 10.
Iulian
From: cgma-dev-bounces at mcs.anl.gov [cgma-dev-bounces at mcs.anl.gov] on behalf of Grindeanu, Iulian R. [iulian at mcs.anl.gov]
Sent: Friday, April 11, 2014 10:02 AM
To: Paul Wilson; CGMA Development
Subject: Re: [cgma-dev] CGM failing with OCC6.6.0
Hello,
There seems to be another problem with cgm master, uncovered by last night builds
On my machine, it works with occ 653, in debug mode, with mpi.
If I compile without debug mode, several tests fail;
it is the same error on gnep now;
To add to the misery, on ubuntu 10.04, there were no errors in optimized mode. (this is previous build, before gnep was upgraded)
http://gnep.mcs.anl.gov:8010/builders/cgmtr-occ-par-sta/builds/430/steps/test/logs/stdio
But errors pop up on my machine too, like these pointed by buildbot, last night:
http://gnep.mcs.anl.gov:8010/builders/cgmtr-occ-par-sta/builds/431/steps/test/logs/stdio
Jane is on vacation, so I don't know who can figure these out now :(
I will try to rebuild occ 653, on gnep. What kind of errors do you see with 660 on cgm master?
Iulian
Sent: Thursday, April 10, 2014 1:49 PM
Ouch :(
Buildbot was testing only cgm13.1 against occ660. If cgm master fails (I think it is 14.0), it means Jane would have to look at it.
Does anybody build cgm master with occ 660?
Iulian
From: cgma-dev-bounces at mcs.anl.gov [cgma-dev-bounces at mcs.anl.gov] on behalf of Paul Wilson [wilsonp at engr.wisc.edu]
Sent: Thursday, April 10, 2014 12:23 PM
To: CGMA Development
Subject: [cgma-dev] CGM failing with OCC6.6.0
Hello all,
I thought I had overcome these problems last month, but I seem to be
having new problems.
I have successfully built CGM13.1 with OCC 6.6.0, including successful
testing with 'make check'.
When I use the identical installation of OCC 6.6.0 to build the master
CGM branch (14.1?) it fails on 'make check'. I have looked and the
patch to OCC 6.6.0 didn't change between CGM13.1 and master. It
certainly seems that the code did change.
Any tips?
Paul
Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
Faculty Director, Advanced Computing Infrastructure
More information about the cgma-dev
