[cgma-dev] r6138 - cgm/trunk/itaps
iulian at mcs.anl.gov
Tue Mar 11 10:43:26 CDT 2014
Author: iulian
Date: 2014-03-11 10:43:25 -0500 (Tue, 11 Mar 2014)
New Revision: 6138
Modified:
cgm/trunk/itaps/Makefile.am
Log:
move partest from TESTS
partest is a test that should be launched in parallel, but not
by make check
move it from TESTS variable to check_PROGRAMS variable
it will be compiled by make check, but not run
Modified: cgm/trunk/itaps/Makefile.am
--- cgm/trunk/itaps/Makefile.am 2014-03-03 19:52:22 UTC (rev 6137)
+++ cgm/trunk/itaps/Makefile.am 2014-03-11 15:43:25 UTC (rev 6138)
@@ -40,10 +40,11 @@
-I$(top_srcdir)/geom \
-I$(top_srcdir)/init
+check_PROGRAMS = chaman $(TESTS)
if USE_MPI
AM_CPPFLAGS += -I$(top_srcdir)/geom/parallel -DUSE_MPI
libiGeom_la_LIBADD += $(top_builddir)/geom/parallel/libcubit_parallel.la
- TESTS += partest
+ check_PROGRAMS += partest
partest_SOURCES = partest.cpp
partest_CPPFLAGS = $(testgeom_occ_CPPFLAGS)
endif
@@ -74,8 +75,6 @@
iGeom_f.h
endif
-check_PROGRAMS = chaman $(TESTS)
AM_LDFLAGS += $(CGM_EXT_LTFLAGS) $(CGM_EXT_LDFLAGS)
testgeom_SOURCES = testgeom.cc
testgeom_occ_SOURCES = $(testgeom_SOURCES)
More information about the cgma-dev
