[cgma-dev] buildbot failure in cgm-cubit: failed configure
    Grindeanu, Iulian R.
    iulian at mcs.anl.gov
    Thu Mar  6 12:59:50 CST 2014
last night errors on cgm were my fault
I was playing with the cubit 12.2 installation, and it failed to configure :(
I did not see them until now, sorry about that.
All these builds were using cubit 12.2
Iulian
From: cgma-dev-bounces at mcs.anl.gov [cgma-dev-bounces at mcs.anl.gov] on behalf of cgma-dev at mcs.anl.gov [cgma-dev at mcs.anl.gov]
Sent: Thursday, March 06, 2014 1:13 AM
To: cgma-dev at mcs.anl.gov
Subject: [cgma-dev] buildbot failure in cgm-cubit: failed configure
Fathom<http://gnep.mcs.anl.gov:8010/>: cgm-cubit<http://gnep.mcs.anl.gov:8010/builders/cgm-cubit> build #1451<http://gnep.mcs.anl.gov:8010/builders/cgm-cubit/builds/1451>
Results:        failed configure
Buildslave:     gnep
Revision:       None
Reason: The Nightly scheduler named 'nightly' triggered this build
Log Excerpt
checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC -DPIC
checking if g++ PIC flag -fPIC -DPIC works... yes
checking if g++ static flag -static works... yes
checking if g++ supports -c -o file.o... yes
checking if g++ supports -c -o file.o... (cached) yes
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... no
checking whether to build static libraries... yes
checking for f77 option to produce PIC... -fPIC
checking if f77 PIC flag -fPIC works... yes
checking if f77 static flag -static works... yes
checking if f77 supports -c -o file.o... yes
checking if f77 supports -c -o file.o... (cached) yes
checking whether the f77 linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking for gfortran option to produce PIC... -fPIC
checking if gfortran PIC flag -fPIC works... yes
checking if gfortran static flag -static works... yes
checking if gfortran supports -c -o file.o... yes
checking if gfortran supports -c -o file.o... (cached) yes
checking whether the gfortran linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking for a sed that does not truncate output... (cached) /bin/sed
checking whether byte ordering is bigendian... no
checking for known C compilers... GNU
checking for known compiler/OS combinations... GNU:x86_64
checking for known c++ compilers... GNU
checking if g++ works... yes
checking how to get verbose linking output from gfortran... -v
checking for Fortran libraries of gfortran...  -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../.. -L/usr/lib/x86_64-linux-gnu -lgfortranbegin -lgfortran -lm
checking for dummy main to link with Fortran libraries... none
checking for Fortran name-mangling scheme... lower case, underscore, no extra underscore
configure: creating ./config.lt
config.lt: creating libtool
checking for C++-standard library in std:: namespace... yes
checking for C++-standard I/O in std:: namespace... yes
checking if C++ template definitions should be included... yes
checking for AcisQueryEngine::instance_ in /homes/fathom/3rdparty/cubit/Cubit64/Cubit-12.2/bin/libcubiti19.so... no
configure: error: "Cubit library not found in /homes/fathom/3rdparty/cubit/Cubit64/Cubit-12.2/bin"
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20140306/cc61af3f/attachment.html>
More information about the cgma-dev
