[cgma-dev] r6143 - cgm/trunk
janehu at mcs.anl.gov
Wed Mar 12 10:08:11 CDT 2014
Author: janehu
Date: 2014-03-12 10:08:11 -0500 (Wed, 12 Mar 2014)
New Revision: 6143
Removed:
cgm/trunk/KNOWN_ISSUES
cgm/trunk/Makefile.am
cgm/trunk/README.CGM
cgm/trunk/README.CONFIGURE
cgm/trunk/README.OCC
cgm/trunk/README.OpenCascade
cgm/trunk/cgm.make
cgm/trunk/cgm.make.in
cgm/trunk/cgm_version.h
cgm/trunk/compat/
cgm/trunk/configure.ac
cgm/trunk/geom/
cgm/trunk/init/
cgm/trunk/itaps/
cgm/trunk/m4/
cgm/trunk/test/
cgm/trunk/util/
Log:
cgm has been moved to bitbucket, removing all source codes.
Deleted: cgm/trunk/KNOWN_ISSUES
--- cgm/trunk/KNOWN_ISSUES 2014-03-12 04:19:30 UTC (rev 6142)
+++ cgm/trunk/KNOWN_ISSUES 2014-03-12 15:08:11 UTC (rev 6143)
@@ -1,35 +0,0 @@
-This is a list of the known issues with CGM on OCC.For more details please see
-the online ticket system at the MOAB website:
- https://trac.mcs.anl.gov/projects/ITAPS/wiki
-ID Severity Summary/Details
-175 critical imprint special cases fail with crash.
-176 minor CGM memory leak
-178 major Unite function doesn't unite smoothly connected surfaces.
-179 major mcnp2cad test suite lat1-3, lat5, lat1,norot not working,
- `needs debugging.
-180 major There are lots new functions or added functions to exsisting
- functions requirements to port OCC to cubit12.
-181 minor Lack of good cases for testing purpose.
-182 minor Dirty geometry/imported geometry is not tested for read/repair yet
-183 minor Don't have proper tool to visualize the TopoDS_Shapes, debugging
- process is long preparing for graphics to understand the issue
-185 major mcnp2cad/tests/INP-torus test case fails on imprinting 2 spline
- surfaces.
-247 major Uniting of two shapes failed in Opencascade
-251 major imprint mesh bug by Boyd Tidwell
-265 major step file read crash
Deleted: cgm/trunk/Makefile.am
--- cgm/trunk/Makefile.am 2014-03-12 04:19:30 UTC (rev 6142)
+++ cgm/trunk/Makefile.am 2014-03-12 15:08:11 UTC (rev 6143)
@@ -1,69 +0,0 @@
-AUTOMAKE_OPTIONS = foreign
-# Don't loose the autoconf include path
-ACLOCAL_AMFLAGS = -I m4
-# Automake doesn't seem to have a directory defined for
More information about the cgma-dev
