[cgma-dev] Cubit 14
David Thompson david.thompson at kitware.com
Wed Jan 29 09:25:28 CST 2014
Hi all,
I've been bitten by this as well, since I was using an older SVN checkout with local patches applied. It would be nice if some header that was present in old revisions (e.g., geom/GeometryQueryTool.hpp) included cgm_version.h whenever it exists. That way, at compile time, the version number can either be determined or inferred due to the lack of CGM_MAJOR_VERSION without any header checks.
	Just my 2 cents,
	David
On Jan 29, 2014, at 10:19 AM, Grindeanu, Iulian R. <iulian at mcs.anl.gov> wrote:
> buildbot uses these:
> cgmurl    = 'https://svn.mcs.anl.gov/repos/ITAPS/cgm/branches/merge-cubit12.2'  for cubit 12.2
> cgmurlt1311 = 'https://svn.mcs.anl.gov/repos/ITAPS/cgm/tags/13.1.1'  for cubit 13.1
> cgmurltrunk    = 'https://svn.mcs.anl.gov/repos/ITAPS/cgm/trunk'  for Cubit14.0
> What versions are you using?
> What is not compiling for you?
> Iulian
> From: Paul Wilson [wilsonp at engr.wisc.edu]
> Sent: Wednesday, January 29, 2014 9:15 AM
> To: Andrew Davis; Grindeanu, Iulian R.; cgma-dev at mcs.anl.gov
> Subject: Re: [cgma-dev] Cubit 14
> Hi Andy,
> Can you remind me of the specific symptom?  Is it the existence of the
> version file that needs to be backported (perhaps not), or is it the use
> of the version info to change the behavior that needs to be backported
> (perhaps)?
> Paul
> On 01/29/2014 09:10 AM, Andrew Davis wrote:
>> Hi Julian
>> The SVN
>> Andy
>> On 01/29/2014 09:07 AM, Grindeanu, Iulian R. wrote:
>>> I think that current branches (mergecubit12.2, trunk, ) all have that
>>> file; at least buildbot is not complaining.
>>> Are you using a release tar file or svn repo?
>>> From: cgma-dev-bounces at mcs.anl.gov [cgma-dev-bounces at mcs.anl.gov] on
>>> behalf of Andrew Davis [davisa at engr.wisc.edu]
>>> Sent: Wednesday, January 29, 2014 9:05 AM
>>> To: cgma-dev at mcs.anl.gov
>>> Subject: [cgma-dev] Cubit 14
>>> This is question kind of linked to both CGM and MOAB
>>> Jane fixed readCGM.cpp in MOAB, however this fix only works for CGM,
>>> since it relies on cgm_version.h, which was included in CGM14.0,
>>> however, when we compile with any version previous we do not have this
>>> header file availble to us. Would it be possible to back port the
>>> cgm_version.h file back into previous CGM releases?
>>> Thanks
>>> Andy
> Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
> Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
> Faculty Director, Advanced Computing Infrastructure
More information about the cgma-dev mailing list
