[cgma-dev] Cubit 14
Grindeanu, Iulian R.
iulian at mcs.anl.gov
Wed Jan 29 09:19:22 CST 2014
buildbot uses these:
cgmurl = 'https://svn.mcs.anl.gov/repos/ITAPS/cgm/branches/merge-cubit12.2' for cubit 12.2
cgmurlt1311 = 'https://svn.mcs.anl.gov/repos/ITAPS/cgm/tags/13.1.1' for cubit 13.1
cgmurltrunk = 'https://svn.mcs.anl.gov/repos/ITAPS/cgm/trunk' for Cubit14.0
What versions are you using?
What is not compiling for you?
Iulian
Sent: Wednesday, January 29, 2014 9:15 AM
To: Andrew Davis; Grindeanu, Iulian R.; cgma-dev at mcs.anl.gov
Subject: Re: [cgma-dev] Cubit 14
Hi Andy,
Can you remind me of the specific symptom? Is it the existence of the
version file that needs to be backported (perhaps not), or is it the use
of the version info to change the behavior that needs to be backported
(perhaps)?
Paul
On 01/29/2014 09:10 AM, Andrew Davis wrote:
> Hi Julian
> The SVN
> Andy
> On 01/29/2014 09:07 AM, Grindeanu, Iulian R. wrote:
>> I think that current branches (mergecubit12.2, trunk, ) all have that
>> file; at least buildbot is not complaining.
>> Are you using a release tar file or svn repo?
>> From: cgma-dev-bounces at mcs.anl.gov [cgma-dev-bounces at mcs.anl.gov] on
>> behalf of Andrew Davis [davisa at engr.wisc.edu]
>> Sent: Wednesday, January 29, 2014 9:05 AM
>> To: cgma-dev at mcs.anl.gov
>> Subject: [cgma-dev] Cubit 14
>> This is question kind of linked to both CGM and MOAB
>> Jane fixed readCGM.cpp in MOAB, however this fix only works for CGM,
>> since it relies on cgm_version.h, which was included in CGM14.0,
>> however, when we compile with any version previous we do not have this
>> header file availble to us. Would it be possible to back port the
>> cgm_version.h file back into previous CGM releases?
>> Thanks
>> Andy
Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
Faculty Director, Advanced Computing Infrastructure
More information about the cgma-dev
