[cgma-dev] Cubit 14
Andrew Davis
davisa at engr.wisc.edu
Wed Jan 29 09:27:22 CST 2014
Hi Iulian
cgmurl I can see, I doubt I have ever used it, why is there more than
one for cubit12.2?
Also I was using 13.1 from branches (no cgm_version.h) , not 13.1.1
from tags (which has cgm_version.h)
Out of curiosity, should there not be a 13.1.1 on branches? Perhaps now
that 13.1 is out of date you could replace it with
13.1.1? Same for 12.2-merge?
Andy
On 01/29/2014 09:19 AM, Grindeanu, Iulian R. wrote:
> buildbot uses these:
> cgmurl = 'https://svn.mcs.anl.gov/repos/ITAPS/cgm/branches/merge-cubit12.2' for cubit 12.2
> cgmurlt1311 = 'https://svn.mcs.anl.gov/repos/ITAPS/cgm/tags/13.1.1' for cubit 13.1
> cgmurltrunk = 'https://svn.mcs.anl.gov/repos/ITAPS/cgm/trunk' for Cubit14.0
> What versions are you using?
> What is not compiling for you?
> Iulian
> From: Paul Wilson [wilsonp at engr.wisc.edu]
> Sent: Wednesday, January 29, 2014 9:15 AM
> To: Andrew Davis; Grindeanu, Iulian R.; cgma-dev at mcs.anl.gov
> Subject: Re: [cgma-dev] Cubit 14
> Hi Andy,
> Can you remind me of the specific symptom? Is it the existence of the
> version file that needs to be backported (perhaps not), or is it the use
> of the version info to change the behavior that needs to be backported
> (perhaps)?
> Paul
> On 01/29/2014 09:10 AM, Andrew Davis wrote:
>> Hi Julian
>> The SVN
>> Andy
>> On 01/29/2014 09:07 AM, Grindeanu, Iulian R. wrote:
>>> I think that current branches (mergecubit12.2, trunk, ) all have that
>>> file; at least buildbot is not complaining.
>>> Are you using a release tar file or svn repo?
>>> From: cgma-dev-bounces at mcs.anl.gov [cgma-dev-bounces at mcs.anl.gov] on
>>> behalf of Andrew Davis [davisa at engr.wisc.edu]
>>> Sent: Wednesday, January 29, 2014 9:05 AM
>>> To: cgma-dev at mcs.anl.gov
>>> Subject: [cgma-dev] Cubit 14
>>> This is question kind of linked to both CGM and MOAB
>>> Jane fixed readCGM.cpp in MOAB, however this fix only works for CGM,
>>> since it relies on cgm_version.h, which was included in CGM14.0,
>>> however, when we compile with any version previous we do not have this
>>> header file availble to us. Would it be possible to back port the
>>> cgm_version.h file back into previous CGM releases?
>>> Thanks
>>> Andy
> Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
> Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
> Faculty Director, Advanced Computing Infrastructure
More information about the cgma-dev
