[cgma-dev] Cubit 14
Andrew Davis davisa at engr.wisc.edu
Wed Jan 29 09:19:14 CST 2014
Hi Paul
Its that readCGM.cpp calls for #include "cgm_version.h", which doesnt
appear in versions of CGM less than 14.0.
Here is the link for svn/cgm13.1
https://svn.mcs.anl.gov/repos/ITAPS/cgm/branches/cubit13.1/, compare
with that of 14.0, https://svn.mcs.anl.gov/repos/ITAPS/cgm/trunk/
cgm_version.h appears in 14.0 and not in 13.1, and thus we fail to build
readCGM when we try to build with 13.1
Andy
On 01/29/2014 09:15 AM, Paul Wilson wrote:
> Hi Andy,
> Can you remind me of the specific symptom?  Is it the existence of the
> version file that needs to be backported (perhaps not), or is it the
> use of the version info to change the behavior that needs to be
> backported (perhaps)?
> Paul
> On 01/29/2014 09:10 AM, Andrew Davis wrote:
>> Hi Julian
>> The SVN
>> Andy
>> On 01/29/2014 09:07 AM, Grindeanu, Iulian R. wrote:
>>> I think that current branches (mergecubit12.2, trunk, ) all have
>>> that file; at least buildbot is not complaining.
>>> Are you using a release tar file or svn repo?
>>> ________________________________________
>>> From: cgma-dev-bounces at mcs.anl.gov [cgma-dev-bounces at mcs.anl.gov] on
>>> behalf of Andrew Davis [davisa at engr.wisc.edu]
>>> Sent: Wednesday, January 29, 2014 9:05 AM
>>> To: cgma-dev at mcs.anl.gov
>>> Subject: [cgma-dev] Cubit 14
>>> This is question kind of linked to both CGM and MOAB
>>> Jane fixed readCGM.cpp in MOAB, however this fix only works for CGM,
>>> since it relies on cgm_version.h, which was included in CGM14.0,
>>> however, when we compile with any version previous we do not have this
>>> header file availble to us. Would it be possible to back port the
>>> cgm_version.h file back into previous CGM releases?
>>> Thanks
>>> Andy
More information about the cgma-dev mailing list
