[cgma-dev] RefGroup question
    David Thompson
    david.thompson at kitware.com
    Fri Jan 24 17:12:57 CST 2014
Hi Tim,
> Exporting groups is sort of backwards; if you export the model entities that groups are part of, and attributes are on, then they'll go with, and (again, if attributes are on) will be restored on import.  Attribute settings are controlled by CubitAttrib, IIRC.
While I have been able to save attributes (UUIDs) on many entities back to a solid model, I am not seeing groups saved, whether they contain entities being written or not. I've attached a test program that demonstrates a group not being saved. Can you see something I am doing wrong?
	David
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20140124/0508a4d5/attachment.obj>
More information about the cgma-dev
