[cgma-dev] RefGroup question
Tim Tautges (ANL) tautges at mcs.anl.gov
Thu Jan 23 16:51:33 CST 2014
Exporting groups is sort of backwards; if you export the model entities that groups are part of, and attributes are on,
then they'll go with, and (again, if attributes are on) will be restored on import.  Attribute settings are controlled
by CubitAttrib, IIRC.
- tim
On 01/23/2014 04:48 PM, David Thompson wrote:
> Hi all,
> I've been unable to determine from the documentation whether RefGroup instances can be exported along with a solid model by any or all of the backends. It doesn't appear that they can be; my experiments passing groups to CubitCompat_export_solid() have been unsuccessful with "OCC" and "FACET_TYPE" file_type arguments.
> 	Thanks,
> 	David
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
More information about the cgma-dev mailing list
