[cgma-dev] RefGroup question
Paul Wilson
wilsonp at engr.wisc.edu
Sat Jan 25 10:57:13 CST 2014
Hi David,
It doesn't look like you are not using all the right attribute
management here.
I'm not sure where this is documented (Tim?) but there is a reasonable
example in the ReadCGM module of MOAB. Starting at line 178
<https://bitbucket.org/fathomteam/moab/src/1e89e1024c147fd9a617a4a34a698b44c40796d1/src/io/ReadCGM.cpp?at=master#cl-178>,
you will see that if the flag 'act_att' is set to true (it is
initialized to true at line 136), then the attribute_manager is set to
automatically read and apply the attributes upon reading a file.
This is all in CubitAttribManager.hpp
<http://trac.mcs.anl.gov/projects/ITAPS/browser/cgm/trunk/geom/CubitAttribManager.hpp>
which also contains methods for auto_write_flag() that you might need to
establish before you write your file to ensure that they are written in
your file.
I hope this helps,
Paul
On 01/24/2014 05:12 PM, David Thompson wrote:
> Hi Tim,
>> Exporting groups is sort of backwards; if you export the model entities that groups are part of, and attributes are on, then they'll go with, and (again, if attributes are on) will be restored on import. Attribute settings are controlled by CubitAttrib, IIRC.
> While I have been able to save attributes (UUIDs) on many entities back to a solid model, I am not seeing groups saved, whether they contain entities being written or not. I've attached a test program that demonstrates a group not being saved. Can you see something I am doing wrong?
> David
Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
Faculty Director, Advanced Computing Infrastructure
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20140125/fd724615/attachment.html>
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20140125/fd724615/attachment.bin>
More information about the cgma-dev
