[cgma-dev] CMake build system
Tim Tautges (ANL) tautges at mcs.anl.gov
Tue Jan 21 14:55:09 CST 2014
Actually, ideally, we'd like to get to the point of using the same CMakeLists.txt files as cubit uses, possibly modulo
including / not including some of the init stuff unique to ANL's version of CGM (presumably controllable using a CMake
variable/option).
Sandia/CSimsoft peple, feel free to chime in here...
- tim
On 01/21/2014 11:01 AM, Jane Hu wrote:
> David,
> The CMakeLists.txt files were from cubit14.0 codes, and were used for a reference when we integrated cgm on cubit for
> file lists. But not actually used on CGM part. Please disregard this part of code.
> Jane
> On Tue, Jan 21, 2014 at 10:49 AM, David Thompson <david.thompson at kitware.com <mailto:david.thompson at kitware.com>> wrote:
>     Hi all,
>     Now that I can build the most modern cgm on my machine, I see that some subdirectories of CGM now have
>     CMakeLists.txt files -- each creating a separate project, and with no toplevel project. When I add a toplevel
>     project, it does not quite build. When I fix it so things compile, there is no libcgm created; instead a separate
>     library exists for each subdirectory (I guess autoconf builds libcgm from these "convenience libraries"?).
>     Are the CMake files work in progress or remnants that have been abandoned?
>              Thanks,
>              David
> Jane Hu
> Asst. Researcher
> Dept. of Engineering Physics
> UW @ Madison
> "And we know that for those who love God, that is, for those who are called according to his purpose, all things are
> working together for good." (Romans 8:28)
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
More information about the cgma-dev mailing list
