[cgma-dev] CGM Instance
Patrick Shriwise
shriwise at wisc.edu
Thu Jan 16 11:30:41 CST 2014
On 01/15/2014 03:33 PM, David Thompson wrote:
>> I'm currently writing tests for MOAB's Read_CGM. In this process I'm loading an ACIS file multiple times in different MOAB instances. This causes the file loads to 'stack' upon one another when I do this however. Any recommendations on how to clear the CGM data if I want to load a file more than once?
> Have you tried
> GeometryQueryTool::instance()->delete_geometry();
> or does that not do what you want?
> David
Haven't tried that yet. Going to give it a shot today. Do you think the
function is accessible from within a MOAB instance?
Patrick C. Shriwise
Research Assistant
University of Wisconsin - Madison
Engineering Research Building - Rm. 428
1500 Engineering Drive
Madison, WI 53706
(608) 446-8173
More information about the cgma-dev
