[cgma-dev] CGM Instance
Paul Wilson wilsonp at engr.wisc.edu
Thu Jan 16 11:47:02 CST 2014
On 01/16/2014 11:30 AM, Patrick Shriwise wrote:
> On 01/15/2014 03:33 PM, David Thompson wrote:
>>> I'm currently writing tests for MOAB's Read_CGM. In this process I'm
>>> loading an ACIS file multiple times in different MOAB instances.
>>> This causes the file loads to 'stack' upon one another when I do
>>> this however. Any recommendations on how to clear the CGM data if I
>>> want to load a file more than once?
>> Have you tried
>>     GeometryQueryTool::instance()->delete_geometry();
>> or does that not do what you want?
>>     David
> Haven't tried that yet. Going to give it a shot today. Do you think
> the function is accessible from within a MOAB instance?
Patrick,
This is available through the same (or similar) CGM interface that is
used to to call get_graphics() in ReadCGM.  You'll need to set it up in
your tests probably.
Paul
Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
Faculty Director, Advanced Computing Infrastructure
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20140116/5c8210f7/attachment.bin>
More information about the cgma-dev mailing list
