[cgma-dev] CGM Instance
David Thompson david.thompson at kitware.com
Wed Jan 15 15:33:04 CST 2014
> I'm currently writing tests for MOAB's Read_CGM. In this process I'm loading an ACIS file multiple times in different MOAB instances. This causes the file loads to 'stack' upon one another when I do this however. Any recommendations on how to clear the CGM data if I want to load a file more than once?
Have you tried
	GeometryQueryTool::instance()->delete_geometry();
or does that not do what you want?
	David
More information about the cgma-dev mailing list
