[cgma-dev] CGM Instance
Grindeanu, Iulian R.
iulian at mcs.anl.gov
Wed Jan 15 15:29:02 CST 2014
Isn't this related to heavy use of "singleton" pattern by CGM ?
I think that it is hard to get rid of some of the classes in cgm. so even if you have a new moab instance, some cgm classes might linger around.
Although, I thought that a new moab instance would automatically mean a new cgm instance. Probably you can check in the debugger if you are really getting an old cgm class.
Iulian
From: cgma-dev-bounces at mcs.anl.gov [cgma-dev-bounces at mcs.anl.gov] on behalf of Patrick Shriwise [shriwise at wisc.edu]
Sent: Wednesday, January 15, 2014 3:28 PM
To: cgma-dev at mcs.anl.gov
Subject: [cgma-dev] CGM Instance
Hi all,
I'm currently writing tests for MOAB's Read_CGM. In this process I'm
loading an ACIS file multiple times in different MOAB instances. This
causes the file loads to 'stack' upon one another when I do this
however. Any recommendations on how to clear the CGM data if I want to
load a file more than once?
Thank you,
Patrick C. Shriwise
Research Assistant
University of Wisconsin - Madison
Engineering Research Building - Rm. 428
1500 Engineering Drive
Madison, WI 53706
(608) 446-8173
More information about the cgma-dev
