[cgma-dev] CGM Instance
Patrick Shriwise shriwise at wisc.edu
Wed Jan 15 15:28:47 CST 2014
Hi all,
I'm currently writing tests for MOAB's Read_CGM. In this process I'm
loading an ACIS file multiple times in different MOAB instances. This
causes the file loads to 'stack' upon one another when I do this
however. Any recommendations on how to clear the CGM data if I want to
load a file more than once?
Thank you,
Patrick C. Shriwise
Research Assistant
University of Wisconsin - Madison
Engineering Research Building - Rm. 428
1500 Engineering Drive
Madison, WI 53706
(608) 446-8173
More information about the cgma-dev mailing list
