[cgma-dev] iRel missing in MeshKit build
    Alexander Vizard
    avizard at gwmail.gwu.edu
    Tue Jan 14 15:47:23 CST 2014
Hello,
I would like to first thank you for your prompt and thorough assistance in
troubleshooting the issues that I have been experiencing in the install and
implementation of MeshKit. Currently, I have been able to configure, build,
and install CGM, OCE, and moab on my machine, and am in the process of
building the MeshKit currently. If I configure with iGeom, I recieve a
warning that says, "configure: WARNING: iRel not found: camel disabled" ,
and then if i buildbuild using "make", I obtain an error stating:
EdgeMesher.hpp:16:18: error: iRel.h: No such file or directory
building without the iGeom specified leads to the following error:
EdgeMesher.hpp:13:19: error: iGeom.h: No such file or directory
I assume that this iRel represents an additional required library for the
software that is not specified in the download instructions on the website.
Is there a place that I can obtain this software? Also, is it similar to
the others in that I simply configure, build, and install it, then specify
"--with-iRel=/directory/" as is done with imesh and igeom?
Upon completing the installation I intend to further investigate
alterations to SCDMesh so that it can read a data file of specified grid
points and calculate volume fractions for a stretched grid, however I first
need to have the base version of the software functional. Again, I
genuinely appreciate your time and assistance with my troubles, and I look
forward to hearing back from you soon.
Best,
Alexander Vizard
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20140114/ff031daa/attachment.html>
More information about the cgma-dev
