[cgma-dev] CGM and Cubit13.1 Bug
Jane Hu janejhu at gmail.com
Mon Dec 2 13:09:40 CST 2013
Hi, David:
Can you attach your test file and acis file? I am not sure where cubit13.1
changed for faceting, but am wondering if we need to call a separate
function to let the curves tessellated. It's hard to imagine tessellating a
surface without tessellating curves.
Thanks.
Jane
On Mon, Dec 2, 2013 at 11:59 AM, Tim Tautges (ANL) <tautges at mcs.anl.gov>wrote:
> Now and in the future, best to email the cgm email list (cc'd).
> - tim
> On 11/14/2013 04:13 PM, Andrew Davis wrote:
>> Hi Tim
>> I cant seem to find where I should submit bugs to CGM, I looked on
>> bitbucket but theres not code there yet. So the issue
>> is that CGM v13.1 compiled and linked against Cubit 13.1 does not facet
>> curves. By which I mean not a single curve, even
>> curves that connect the vertices of a cube. I discovered this by running
>> dagmc_preproc on an acis file.
>> This is an issue for make_watertight which relies on the faceted curve
>> information in order to repair volumes. There are
>> facets produced which are good, but there are no faceted curves.
>> This was ok in Cubit12.2, I have no idea if this was already raised as a
>> bug.
>> Thanks
>> Andy
> "You will keep in perfect peace him whose mind is
>   steadfast, because he trusts in you."               Isaiah 26:3
>              Tim Tautges            Argonne National Laboratory
>          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
>             fax: (608) 263-4499      Madison, WI 53706
Jane Hu
Asst. Researcher
Dept. of Engineering Physics
UW @ Madison
"And we know that for those who love God, that is, for those who are called
according to his purpose, all things are working together for good."
(Romans 8:28)
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20131202/720a314f/attachment.html>
More information about the cgma-dev mailing list
