[cgma-dev] CGM and Cubit13.1 Bug
    Tim Tautges (ANL)
    tautges at mcs.anl.gov
    Mon Dec  2 11:59:04 CST 2013
Now and in the future, best to email the cgm email list (cc'd).
- tim
On 11/14/2013 04:13 PM, Andrew Davis wrote:
> Hi Tim
> I cant seem to find where I should submit bugs to CGM, I looked on bitbucket but theres not code there yet. So the issue
> is that CGM v13.1 compiled and linked against Cubit 13.1 does not facet curves. By which I mean not a single curve, even
> curves that connect the vertices of a cube. I discovered this by running dagmc_preproc on an acis file.
> This is an issue for make_watertight which relies on the faceted curve information in order to repair volumes. There are
> facets produced which are good, but there are no faceted curves.
> This was ok in Cubit12.2, I have no idea if this was already raised as a bug.
> Thanks
> Andy
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
More information about the cgma-dev
